Downgrade from CallManager 5.1.3 to 5.1.2
iec1088407
I need to make a downgrade from CM 5.1.3 to 5.1.2, but I only have the recovery disc from 5.1.2 and the system says that there is no way to make an Downgrade from the SSH... I also tried from CLI and making a reload with the CD, without success...
Can anyone tell me where I can find the Instalacion DVD (iso) for 5.1.2
gogasca
Level 10
Level 10
If it was a fresh install for 5.1(3) you need to reinstall...
If it was already in 5.1(2) and you upgrade directly from 5.1(2) to 5.1(3) you can switch back to the inactive partition...otherwise:
You need to request your DVD...use this URL
http://cisco.com/en/US/products/sw/voicesw/ps556/products_qanda_item09186a00802262ed.shtml
As a friendly reminder we TAC dont post DVDs
