01-04-2014 05:35 AM - edited 03-16-2019 09:06 PM
I have a bunch of Cisco 7965 handsets running Version 9-2-3. For various reasons i'd like these handsets to downgrade to version 8.
The build version of the handset i'm working on is V11 (also have cisco 7942 on V14 with the same issue)
Does anyone know how to downgrade firmware on handsets that are not the new hardware version stated in the link below.
Thanks in advance for any pointers.
01-04-2014 09:21 PM
Hi Ben,
Have you tried uploading firmware version 8-5-2S on TFTP server and specifying the same load name under 'Phone Load name' on the Phone configuration page of 7965. Restart the TFTP service and reset the phone and see if it works or throws up any errors.
Manish
01-05-2014 02:23 AM
Hi Ben,
Go as per Manish suggestion , since as per the link mentioned by you
7965 G Phones manufactured with hardware versions 13.0 /higher must run Firmware Release 9.3(1)SR1 or later. The phone firmware does not allow the phone to be downgraded to releases earlier than Release 9.3(1)SR1.
In your case,it is V11 for 7965G
for 7942 , it is 15.0 and higher.so, u can also degrade the same because you have got V14
regds,
aman
01-05-2014 02:38 AM
Thanks Gents.
I have already done what you have said just in a slightly different manner as I have a UC520. I'm confident the UC520 is ok as handsets with older firmware upgrade to 8-5-2S. (tested on 7942).
The 7942 are V14, I'm reading this from the reverse of the handset, is that correct? (PID VID CP-7942G V14 & PID VID CP-7965G V11)
I've included some snippets of my running config. They initially look as if they will downgrade and then boot with the version 9??
Any help apprecited as i am stuck!
Russell
UC_520#sh telephony-service
CONFIG (Version=8.6)
Version 8.6
Max phoneload sccp version 17
Max dspfarm sccp version 18
Cisco Unified Communications Manager Express
For on-line documentation please see:
http://www.cisco.com/en/US/products/sw/voicesw/ps4625/tsd_products_support_series_home.html
protocol mode default
ip source-address 10.1.1.1 port 2000
ip qos dscp:
ef (the MS 6 bits, 46, in ToS, 0xB8) for media
cs3 (the MS 6 bits, 24, in ToS, 0x60) for signal
af41 (the MS 6 bits, 34, in ToS, 0x88) for video
default (the MS 6 bits, 0, in ToS, 0x0) for serviceservice directed-pickup
service dnis overlay
service dnis dir-lookup
service dss
load 7942 SCCP42.8-5-2S
load 7945 SCCP45.8-5-2S
load 7962 SCCP42.8-5-2S
load 7965 SCCP45.8-5-2S
01-05-2014 02:46 AM
Find below the TFTP events from each handset. The 7965 does not reboot and attempt to upgrade where the 7942 does.
7965
000185: Jan 5 11:34:11.231: TFTP: Looking for CTLSEPF47F353DC186.tlv
000186: Jan 5 11:34:11.307: TFTP: Looking for ITLSEPF47F353DC186.tlv
000187: Jan 5 11:34:11.391: TFTP: Looking for ITLFile.tlv
000188: Jan 5 11:34:11.667: TFTP: Looking for SEPF47F353DC186.cnf.xml.sgn
000189: Jan 5 11:34:11.819: TFTP: Looking for XMLDefault.cnf.xml.sgn
000190: Jan 5 11:34:12.647: TFTP: Looking for CTLSEPF47F353DC186.tlv
000191: Jan 5 11:34:12.759: TFTP: Looking for ITLSEPF47F353DC186.tlv
000192: Jan 5 11:34:12.871: TFTP: Looking for ITLFile.tlv
000193: Jan 5 11:34:14.591: %IPPHONE-6-REGISTER: ephone-45:SEPF47F353DC186 IP:10.1.1.11 Socket:2 DeviceType:Phone has registered.
000194: Jan 5 11:34:15.935: TFTP: Looking for SEPF47F353DC186.cnf.xml.sgn
000195: Jan 5 11:34:18.135: TFTP: Looking for XMLDefault.cnf.xml.sgn
UC_520#
7942
0.0.0.100
000200: Jan 5 11:36:25.675: TFTP: Looking for CTLSEP5017FF979015.tlv
000201: Jan 5 11:36:25.779: TFTP: Looking for ITLSEP5017FF979015.tlv
000202: Jan 5 11:36:25.891: TFTP: Looking for ITLFile.tlv
000203: Jan 5 11:36:26.115: TFTP: Looking for SEP5017FF979015.cnf.xml
000204: Jan 5 11:36:26.115: TFTP: Opened flash:/its/SEP5017FF979015.cnf.xml, fd 14, size 1594 for process 162
000205: Jan 5 11:36:26.131: TFTP: Finished flash:/its/SEP5017FF979015.cnf.xml, time 00:00:00 for process 162
000206: Jan 5 11:36:39.215: %IPPHONE-6-UNREGISTER_ABNORMAL: ephone-47:SEPC8F9F9687471 IP:10.1.1.12 Socket:1 DeviceType:Phone has unregistered abnormally.
000207: Jan 5 11:36:49.483: TFTP: Looking for SCCP42.8-5-2S.loads
000208: Jan 5 11:36:49.487: TFTP: Opened flash:SCCP42.8-5-2S.loads, fd 14, size 670 for process 162
000209: Jan 5 11:36:49.495: TFTP: Finished flash:SCCP42.8-5-2S.loads, time 00:00:00 for process 162
000210: Jan 5 11:37:25.135: TFTP: Looking for CTLSEP5017FF979015.tlv
000211: Jan 5 11:37:25.247: TFTP: Looking for ITLSEP5017FF979015.tlv
000212: Jan 5 11:37:25.355: TFTP: Looking for ITLFile.tlv
000213: Jan 5 11:37:25.571: TFTP: Looking for SEP5017FF979015.cnf.xml
000214: Jan 5 11:37:25.575: TFTP: Opened flash:/its/SEP5017FF979015.cnf.xml, fd 14, size 1594 for process 162
000215: Jan 5 11:37:25.587: TFTP: Finished flash:/its/SEP5017FF979015.cnf.xml, time 00:00:00 for process 162
000216: Jan 5 11:37:27.859: TFTP: Looking for English_United_States/mk-sccp.jar
000217: Jan 5 11:37:28.135: TFTP: Looking for United_States/g3-tones.xml
000218: Jan 5 11:37:29.795: %IPPHONE-6-REGISTER: ephone-46:SEP5017FF979015 IP:1 0.1.1.10 Socket:1 DeviceType:Phone has registered.
01-06-2014 04:55 AM
Managed to downgrdae the 7965. This was done by deleting CTL files within the trust list within the security section.
However the same does not apply for the 7942/ 7962, these phones do not have CTL files installed and continue to attempt to downgrade and then fail.
