download voicemail file
Hi All,
Is there a way to download the old and new voicemail file of the user from unity express?
Pawan Arora
Everyone's tags (2)
Blue
HI
If you are talking about backing up the voice mail data you can use the Backing Up and Restoring Data feature of CUE. It will backup voice messages also for the users.
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel2_0/ccm_cli/ch5bkrst.html#wp1043341
Procedure how to do it
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a00802fb58d.shtml
Ronak Patel
Rate helpful posts by clicking stars below the answer.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Hi Ronak,
Thanks for the information, I already knew about the backup and restore. Actually we are migrating from express to connection and we want our old voicemail which are in unity express.
Pawan Arora
Blue
HI
Natively it is not possible. You can see answer in below thread also.
https://supportforums.cisco.com/thread/314188
regards
Ronak patel
Blue
Also for other thing like first name, last name, display name, primary extension, alias and recorded voice name can be exported from CUE and imported in CUC.
http://www.ciscounitytools.com/Applications/CxN/CUEImport/Help/CUEImport.htm
Above tool is not for Voice message.
Ronak Patel
429
