Community Member
DRF stops at SYSLOGAGT.log output
I need help.
My cluster with PUB & x2 SUB begin to fail backup process.
It stops with the following message.
--- CUTTED ---
Log File: 20xx-0x-ab-09-02-10_b_ccm-server_syslogagt.log
Server : SERVER
Feature : CCM
Component : SYSLOGAGT
Time Completed: 20xx-0x-ab-09-02-10
Result Code : 0
Result String : WARNING
/usr/local/conf/cisco_syslog_agt/output/prefs.xml
SYSLOGSUBAGT backup failed
SYSLOGSUBAGT backup is completed
----> BEGIN Standard Output
----> END Standard Output
----> BEGIN Standard Error
Pseudo-terminal will not be allocated because stdin is not a terminal.
/bin/dd: opening `/common/drf/component.tar': Permission denied
----> END Standard Error
--- CUTTED ---
How can this problem be resolved ?
1 REPLY
Community Member
Re: DRF stops at SYSLOGAGT.log output
UP.
Any help will be highly appreciated.
263
