Community Member
Dropped calls MGCP Temporary Failure
I am having incoming calls to one specific DID number dropping. Below is the Debug ISDN Q931
Any help would be appreciated
Progress Ind i = 0x8088 - In-band info or appropriate now available
Feb 15 08:36:46.324 EDT: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x03CD
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA9838B
Exclusive, Channel 11
Calling Party Number i = 0x2183, '2158281685'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '6551'
Plan:Unknown, Type:Unknown
DO-VG02#
Feb 15 08:36:46.336 EDT: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x83CD
Feb 15 08:36:46.336 EDT: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x83CD
Cause i = 0x8AA9 - Temporary failure
Feb 15 08:36:46.528 EDT: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x03CD
Feb 15 08:36:46.536 EDT: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x83CD
Feb 15 08:36:46.836 EDT: ISDN Se0/0/0:23 Q931: TX -> CONNECT pd = 8 callref = 0x83C9
Feb 15 08:36:46.848 EDT: ISDN Se0/0/0:23 Q931: RX <- CONNECT_ACK pd = 8 callref = 0x03C9
Community Member
Re: Dropped calls MGCP Temporary Failure
Is the call placed in mute at all? on either end?
Community Member
Can you please provide more informationon your setup please.
Community Member
no it is not muted.
Community Member
I have the same issue, but it happens to all my handsets if the is silence on the line. Can anyone point me in the right direction to fix this issue?
Community Member
To Clarify, My issue is when you call a specific DID from outside, CM sends a disconnect message back and drops the call. Internally the extensions works fine and calls can be made outside from this extension.
Community Member
Did you find the cause/solution?
Thank you.
Yorick
699
