Dropped calls on IOS h.323 gateway and CUCM 6
Hello everyone,
I've got a very vexing issue.  I converted a router over from MGCP to h.323.  IOS Advanced IP Services 12.4-4(t).  With MGCP there was never an issue with dropped calls.  Ever since switching gateway over to h.323, any calls are dropped with alarming regularity within 5 minutes or less of call being established.  I am using the VIC-2FXO-M1 as my gateway interface.  I've been searching for information on this and have come up with nothing.  Unfortunately, MGCP will not allow CallerID over MGCP using FXO at this time.  I'm not sure what is causing this dropping of calls.  Any ideas?
On another note, is it possible to setup a SIP trunk between CUCM to the router and still use the 79xx phones as SCCP?  Not sure on that either.  If it is something with h.323, that would be an alternative solution but I think unnecessary.  The 79XX (type A) phones don't work as well using SIP unfortunately.  Thanks for any information.
Re: Dropped calls on IOS h.323 gateway and CUCM 6
I changed the router config to act as a sip-server.  Configured a SIP trunk in CUCM and pushed calls through that instead of h.323 gateway.  Seems to have solved the issue.  Still curious as to why that was happening.  Any ideas?
I take back my previous post.  The problem is still not solved.  It seems that no matter what I do, I keep getting dropped calls.  Is it the VIC itself?  And how would I test for such?  Thanks.
Hi Fieryhail  Have you fixed
Hi Fieryhail
Have you fixed your issue ? I had same problem like your one .
1.       Intermittent call drop outs
2.       call hang up / call termination / end call delay issue around 30 second delay
Green
Any Firewall in the middle? between CUCM and IOS GW?
H323 establishes a TCP connection b/w CUCM and IOS GW
if for some reason this connection is dropped either H225 or H245 call is dropped as well
We have a Service parameter that helps to prevent this
Allow Peer to Preserve  H.323 Calls
But is only a workaround, investigation needs to be done if above theory is true.
836
