05-09-2014 03:25 PM - edited 03-16-2019 10:44 PM
I have the following scenario for incoming calls:
PSTN ---- E1 ---> Digium Gateway --- SIP ---> Router 2921 ------SIP ----> CUCM
All incoming calls from the PSTN get dropped after 20 seconds. All outgoing calls to the PSTN work fine..
The Router 2921 generates a BYE message with Reason: Q.850;cause=86 to the Digium Gateway.
Attached is the debug, show run and a packet capture with all the SIP messages..
If someone could please give me to a solution.
Thanks!
Solved! Go to Solution.
05-09-2014 11:06 PM
Hello Carlos,
Here is the analysis of the traces....
Timestamp Node / Interface Device IP Direction Protocol Message Name TCP Handle / From Tag Call Ref / ID
05/09/2014 16:52:36.608 172.17.0.6 172.16.50.10 In SIP INVITE as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:36.620 172.17.0.6 172.17.0.3 Out SIP INVITE A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:36.620 172.17.0.6 172.16.50.10 Out SIP 100 Trying as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:36.624 172.17.0.6 172.17.0.3 In SIP 100 Trying A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:36.632 172.17.0.6 172.17.0.3 In SIP 180 Ringing A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:36.632 172.17.0.6 172.16.50.10 Out SIP 180 Ringing as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:39.140 172.17.0.6 172.17.0.3 In SIP 200 OK A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:39.144 172.17.0.6 172.17.0.3 In SIP SUBSCRIBE 844851~97a97412-a383-4ad3-9458-162b2737f313-47291175 AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:39.148 172.17.0.6 172.17.0.3 Out SIP ACK A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:39.148 172.17.0.6 172.17.0.3 Out SIP 200 OK 844851~97a97412-a383-4ad3-9458-162b2737f313-47291175 AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:39.148 172.17.0.6 172.17.0.3 Out SIP NOTIFY A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:39.152 172.17.0.6 172.17.0.3 In SIP 200 OK A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
05/09/2014 16:52:39.152 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:39.652 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:40.652 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:42.652 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:46.652 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:50.652 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:54.652 172.17.0.6 172.16.50.10 Out SIP 200 OK as12f8f5d4 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:58.652 172.17.0.6 172.17.0.6 Out SIP BYE A424AFAC-1EC1 516d02ad77ed3cf82e1afbdd030cc1d1@172.17.0.6
05/09/2014 16:52:58.652 172.17.0.6 172.17.0.3 Out SIP BYE A424AFA0-1D7B AF81DF7A-D6F211E3-967988BC-FD349507@172.17.0.6
The 200 Ok is not being acknowledged by the Digium Gateway . Hence the call is dropped .
Please check why the "Digium" side is not sending an ACK for this transaction.
Hope this helps!
Karthik Sivaram
05-09-2014 11:06 PM
Hello Carlos,
Hope this helps!
Karthik Sivaram
05-10-2014 06:10 AM
Thanks a lot Karthik... based on your analysis.. it makes sense that exactly after 19 o 20 seconds the call gets dropped.. did you make this capture based on the debugs..? or based on the wireshark capture attached?
This wireshark capture was taken directly from the digium gateway.. and in the capture you can see an ACK being generated for every OK received.. could it be that the router isnt processing the ACK generated by the digium ?
05-10-2014 08:38 AM
Hello Carlos,
The packet cap from the Digium does show ACKs being sent .
Would you be able to collect 2 simultaneous packet captures one from the Digium and the other from the cisco gateway at the same time ?
This will show us if the packets are fragmented or if the ack is not processed / received by the gateway also it will give us information on the timestamps for the exchanges on both ends .
Here is the procedure to collect the packet capture from the cisco gateway :-
http://www.cisco.com/c/en/us/support/docs/voice/h323/116078-technologies-technote-commandreference-00.html#anc5
Karthik Sivaram
05-10-2014 09:16 AM
Karthik,
After playing with the options that the digium gateway lets you modified.. I managed to get it working changing the NAT Traversal setting from NO to YES...
Once I did this change.. the incoming calls are not dropping...
If this is all on the same LAN.. why would this NAT parameter affect the ACKs or OKs .??
Thanks for your help!
05-10-2014 09:51 AM
Great to know that !!
So the NAT configuration on Digium possibly corrupted or fragmented the sip packets for ACK.
We can see this if you can collect the packet captures I mentioned in my earlier post this will conclusively prove if there were fragmented / dropped packets when the ACK was sent to the Cisco side or the Cisco gateway didn't even receive it .
Hope this helps!
Karthik Sivaram
01-05-2022 09:10 AM
From where did you perform the trace and what commands have you used ?
06-23-2021 08:42 AM
We were experiencing the same problem. Calls being dropped after 20 seconds. And also had the same call termination code:
Problem was solved by rebooting both of our voice gateways. It seems the CPE had a few seconds power failure. Which seemed to had lost the handshake with CPE.
