Community Member
DRS-In-CCM5
Dear sir ,
i have a CCM 5, i am trying to take a backup of my CCM.after selection disaster and recovery page, when i click on tape drive option it does not show me any drive.
i have two question regarding disaster and recovery,
1) it should be a tape drive on MCS server or it can be anywhere?and why it is not there
2)I was trying to take backup with SFTP but problem is that i cannt find any SFTP server for windows,could u plz tell me SFTP server for windows,i wanna take backup on my windows machine.
or can i use FTP for DRS?
your assistance will be higly appreciated
thanks
1 REPLY
Re: DRS-In-CCM5
not sure what you mean the tape drive is not there, if you have not bought one then how do you expect it to be there? if you do not have one use a network drive. if you have one then you can use it, but you certainly will not receive one if not ordered
have you googled "free SFTP"?????
there are TONS of free applications out there so not sure how you have not found one
you can use one called freeftpd as it's easy to configure
javalenc
if this helps, please rate
java
www.cisco.com/go/pdi
102
