DRS Restore in Lab Environment
I have taken a DRS backup of my production CUCM's (PUB and SUB) and am attempting to restore on servers in my Lab.  the servers in the lab are built to the same exact version, IP and name as my production servers.  when I try a DRS restore I get as far as 29% and it seems to hang  at the CCMDB stage for the publisher.  the specific task under CCMDB says "Subscriber" node starting and sits forever.  I let it go overnight with no change.  any ideas on what I'm missing?  My lab has DNS, NTP, etc.
Everyone's tags (4)
1 ACCEPTED SOLUTION
Okay you don't seem to have mentioned the exact callmanger version .
However DRS documentation  clearly states to fresh install a subscriber
after restore is done on the publisher. It seems that in this case
subscriber was fresh installed first and then publisher was DRS
restored.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/drs/5_0_4/drsag504.ht
ml#wp187302
It looks like you haven't followed the above doc.
Hope this helps!
Karthik Sivaram
restored.
ml#wp187302
Hope this helps!
Karthik Sivaram
The version of CUCM is v8.5(1).  the DRS doc that i had found stated that the pub and sub could be restored at the same time,  I will try just the Pub and remove my sub from my lab config to see if that helps.
ok let us know how it goes.
Karthik Sivaram
VIP Purple
As far as I know , u need to have same number of servers while doing restorei.e. if the backup was taken with one pub and one sub, then, u need to have one pub and one sub while restore as well.
regds,
aman
that is what I originally thought, so back to my original issue, why is my restore hanging at the point I specified?
thanks,
Jeff
VIP Purple
Are your CUCM versions exactly same on Production and LAB environment?
Can u share the snapshot or any logs ?
regds,
aman
Do you have DRF local and master running on SUB under network services?
VIP Purple
Hope the subscriber u have built in LAB has reachability from PUB, SUB credentials  have been added to PUB.
regds,
aman
Sub was added to the Pub and then installed.  Db Replication is normal between the PUB and SUB.
PUB:
SUB:
VIP Purple
Can u share the show version active from LAB and production server?
regds,
aman
Issue turned out to be that I installed the subscriber on the LAB publisher before the DRS restore.  the SUB can't exist in the LAB Publisher prior to the restore becasue DRS creates the subscriber instance.
thanks to everyone for their input.
So Karthik was correct.
Yosh
HTH Regards, Yosh
Yes Karthik was correct, but I found DRS documentation newer than v5 that stated both the subscriber and publisher could be restored at the same time.
thanks!
VIP Purple
Hi Karthik,
thanks for correcting me(+5)
regds,
aman
Hall of Fame Super Red
Hey folks,
The documentation is somewhat confusing as to whether this would
be considered a Cluster replacement as described here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/install/8_5_1/cluster/clstr851.html#wp87717
Or a Cluster restore in which Jeff's reference should be fully applicable. In the restore
documentation for CUCM 8.5 there is this clip;
Note
You  can restore the whole cluster as a single operation after you rebuild  the publisher server and the subscriber servers, or to revert to a known  good configuration. You do not need to restore the first node and the  subsequent nodes in two separate operations.
In a Cluster replacement the operation is done in two steps with the PUB done first
followed by Subs, TFTP, MOH servers done in parallel in the second phase.
Maybe this operation is considered more of a Cluster replacement than a Cluster restore
but the documentation is somewhat ambiguous to say the least
Cheers!
Rob
"A smile relieves a heart that grieves"
- Stones
769
