Bronze
ds0-group ascending/descending question.
I'd like to change the out going calls on this CAS circuit to ascending.  Is there a command to do this?  Below is the config I'm working with..
controller T1 0/1/0
framing esf
linecode b8zs
cablelength short 133
ds0-group 1 timeslots 1-12 type e&m-wink-start dtmf dnis
ds0-group 2 timeslots 13-24 type fxo-ground-start
voice-port 0/1/0:1
translate called 1
input gain 3
output attenuation 3
voice-port 0/1/0:2
input gain 2
output attenuation 0
connection plar 1400
Mike
1 REPLY
Hall of Fame Super Gold
Re: ds0-group ascending/descending question.
Configure a single ds0-group for which you want to control allocation.
Under related voice-port, assign it in a trunk-group named as you choose.
Under said trunk-group, configure the hunt scheme of your choice.
In dial-peer, reference the trunk-group instead of the port.
There are other ways, but this is the cleanest.
162
