Community Member
DS0-Group _ Channel Group
For a data T1 (to connect to a providers frame network) can either the DS0-group or Channel Group command be used under the contoller?
We're bringing in a new router for a customer. The provider today brings in a T1 and drops it off on a external CSU/DSU then into the existing router. There are four locations on the frame-network and each is designated 4 timeslots inside the CSU/DSU. For a specific reason, the customer needs to continue this behavior in the new router. But after attempting to configure I'm running up to the problem that a maximum of 2 channel-groups can be created under controlle t1 1/0. I need four groups (eac with 4 timeslots) The DS0-Group command will allow up to 24 groups, but that grabs DSP resources.
If the DS0-group command will work for strictly data T1, we could just add some more DSPs, and it should allow us to add additional DS0-Groups?
Any advise would be apprecaited.
thanks
Hall of Fame Super Gold
Re: DS0-Group _ Channel Group
ds0-group doesn't work for data applications. Which exact platform is that? (show diag).
Community Member
2851 running Enhanced Services
Please send show diag to know the exact hardware.
Community Member
Here you go. thanks
VWIC on the ISR chassis have a limitation of two channel-groups as you noted, and documented:
http://www.cisco.com/en/US/products/hw/routers/ps274/products_tech_note09186a00800f9d37.shtml#two_channel
The ISR routers are not mentioned above but they have the same limitations of the older ones.
If you need more than that, you can get either nm-xce1t1-pri where x = 1 or 2 ports, or the new hwic modules, hwic-xce1t1-pri also available with 1 o 2 ports:
All these supports up to 31 (E1) or 24 (T1) channel-groups per port:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/product_data_sheet0900aecd80710c88.html
Community Member
thank you very much for the help and detailed response.
You are welcome, please remember to use the scrollbox below to rate useful answers.
574
