dsfarm configuration help
sccp local GigabitEthernet0/1.20
sccp ccm 172.28.80.10 identifier 1 version 4.1
sccp ccm 172.28.80.11 identifier 2 version 4.1
sccp
sccp ccm group 10
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 10 register TRSBZV-01
associate profile 30 register MTPBZV-01
associate profile 20 register CFBBZV-01
switchover method immediate
switchback method immediate
dspfarm profile 10 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 8
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
dspfarm profile 30 mtp
codec g711ulaw
maximum sessions hardware 3
maximum sessions software 3
I have this configuration on s cisco 2821 relating to Codecs.Not having much voice knoweledge i am unable to understand this configuration. Furthermore, i also want to configure the same on another cisco 2811 for some other remote site.
Any link / resource will be highly appreciated...
Bronze
Re: dsfarm configuration help
So you arent having any problems with the configuration you just want to know what it does? If so then have a read of this guide
it covers the configuration you have. Its pretty long and detailed but it should help you out with your configuration.
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
Just to add you are missing some commands at the top relating to the voice card. This needs to be configured as well before it will work
conf t
voice-card slotx/x
dsp services dspfarm
If you have any questions then please feel free to reply back.
Matt
Yes, it is very hepful link.
Can somebody further enhance the explanation for transcoding and conferencing, so i may develop some basic level understanding.Like y they are used etc etc
121
