Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DSP channels on 2911 and DTMF issue
Good afternoon Cisco Community,
I've a question about MTP resources and a DTMF issue. In fact, I installed two 2911 routers with both 64 channels. 32 channels are used for our E1 connected to the PSTN provider and 32 used for MTP purposes. Why? Because we have a SIP trunk between the CUCM and a Nortel CS 5.
As we are using MTP for transcoding purposes, I had to check the MTP required checkbox on the trunk. We have also a second trunk with Microsoft Exchange UM 2007 and here we are. This trunk uses the same Media Resource Group List than my Nortel Cisco trunk but I figured out that on the trunk with UM, we cannot use anymore the DTMFs for the authentication.
When I'm calling the UM VoiceMail, no entry is taken in consideration. I'm sure this has something to do with the hardware MTP resources because if I select on the CUCM <->UM Exchange an other Media Resource Group List with only the software MTP of the CUCM, the DTMF works again.
I've a workaround for the moment but I prefer using the hardware MTPs.
Any idea?
Best Regards,
Martin
232
