dsp issues on isr g2 2951
                   hi!
i have a dsp issue with a 2951 routeur.
We had troubleshoting this issues since a moment.
Fist step - we decide to  upgrade the IOS from version 15.1 to 15.2  but this way we want to upgrade the DSPWare. Result = "same status"
Second Step - we change the DSP with a new one. Result ="same status"
sh voice dsp group slot 0
dsp 13:
  State: BOOTDOWNLOAD, firmware: 0.0.0
  Max signal/voice channel: 32/32
  Max credits: 480
  num_of_sig_chnls_allocated: 6
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 480, reserved credits: 0
    Signaling channels allocated: 6
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  Slot: 0
  Device idx: 0
  PVDM Slot: 2
  Dsp Type: SP2600
Everyone's tags (3)
Did you try to put that PVDM on a different router?
Did you try changing the PVDM to a different slot?
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Hi Jorge,
thanks for your interest.
Did you try to put that PVDM on a different router?   no because i haven't another ISR 2 available
Did you try changing the PVDM to a different slot?  yes, and we replace the old pvdm with a new one with no effect
Rgds!
Re:dsp issues on isr g2 2951
I don't know if you tried testing the dsp but maybe this link could help.
http://www.cisco.com/en/US/products/hw/modules/ps2617/products_tech_note09186a008039c316.shtml
Sent from Cisco Technical Support Android App
HTH Regards, Yosh
thanks for the link.
   the test fail because the State of the PVDM3 is not UP
the PVDM cannot download the DSPware
dsp 13:
VIP Purple
I doubt the firmware in dsp corrupted.There is a procedure to upload .rbf files on DSPs but never did.
https://supportforums.cisco.com/docs/DOC-2199
https://supportforums.cisco.com/thread/183158
I suggest opening a TAC case with cisco.
regds,
aman
i try to updrade the firmware first buy upgrading the IOS version. But the status is still Bootdownload.  After that i load the dsp_c5510_flex.rbf on the flash and try to Download the firmawre.  The message i get is that the PVDM is not C5510 hardware model.
The command "test voice driver" give us the option of SP2600 model DSPware upgrade -
Rgds!
VIP Purple
You have SP2600 as DSP Type instead of C5510.
test voice driver won't work because of SP2600 .If u have  a contract with Cisco, open a case  and ask them to provide Firmware.rbf file.
regds,
aman
591
