DSP Maximum sessions help
I need some help with setting up the maximum sessions on my conference and mtp dspfarm profiles.
Here is a "show inventory" of what I have:
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
PID: CISCO3945-CHASSIS , VID: V05 , SN:
NAME: "Cisco Services Performance Engine 150 for Cisco 3900 ISR on Slot 0", DESC
R: "Cisco Services Performance Engine 150 for Cisco 3900 ISR"
PID: C3900-SPE150/K9   , VID: V05 , SN:
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot
0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1  , VID: V01 , SN:
NAME: "1000BASE-LX SFP", DESCR: "1000BASE-LX SFP"
PID: TRF5735BALB302    , VID: A1A, SN:
1", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
2", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
3", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
NAME: "PVDM3 DSP DIMM with 64 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP D
IMM with 64 Channels"
PID: PVDM3-64          , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP
DIMM with 256 Channels"
PID: PVDM3-256         , VID: V01 , SN:
NAME: "PVDM3 DSP DIMM with 256 Channels on Slot 0 SubSlot 6", DESCR: "PVDM3 DSP
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Ada
pter for SM Slot"
PID: SM-NM-ADPTR       , VID: V01, SN:
NAME: "High Density Voice2 Network module with on board two port interface  on S
lot 1", DESCR: "High Density Voice2 Network module with on board two port interf
ace "
PID: NM-HDV2-2T1/E1    , VID: V05, SN:
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 1 SubSlot
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC       , VID: V01 , SN:
NAME: "C3900 AC Power Supply 2", DESCR: "C3900 AC Power Supply 2"
Here is partial show run of the the media resources along with the codecs I'm using:
sccp local Loopback0
sccp ccm 10.74.215.236 identifier 1 version 7.0
sccp ccm 10.74.15.228 identifier 2 version 7.0
sccp ccm 10.74.215.235 identifier 3 version 7.0
sccp ip precedence 3
sccp
sccp ccm group 1
description Media Resources
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 1 register CFB_RUKUA-B
associate profile 2 register MTP_RUKUA-B-G729BR8
associate profile 3 register MTP_RUKUA-B-G711
associate profile 4 register MTP_RUKUA-B-G729R8
dspfarm profile 1 conference
description OAB_HWCFB_1-B
codec g711ulaw
codec g711alaw
codec g729r8
maximum sessions ?
associate application SCCP
shutdown
dspfarm profile 2 mtp
codec g711ulaw
maximum sessions ?
dspfarm profile 3 mtp
codec g711alaw
maximum sessions software ?
dspfarm profile 4 mtp
codec g729r8
I'm looking to use the IOS router as both a conference bridge and for mtp resources.  I am unsure as to how many maximum sessions to use. Any help would be appreciated.  Thank You!
1 REPLY
VIP Super Bronze
The number of sessions to configure depends on your telephony requirements and also based on your engineering design. Your router seems quite heavily equpped with DSP resources. I belive there is a reason why you have that much DSP. Example. How many conference session are you expecting or do you want to provision for. Each session supports about 8 participants I believe. So if you have 10 sessions then you can have 80 people at a time etc. For MTP its the same. If your engineering need is 10 g729 software MTP session then you configure that. It all depends on your needs / customer requirements
Please rate all useful posts
"There is a wideness in God's mercy Like the wideness of the sea.There's a kindness in His justice Which is more than liberty"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
510
