DSP out of resource
Hi Expert,
I found the error "%FLEXDSPRM-5-OUT_OF_RESOURCES: No dsps found either locally or globally. Need to restart the router to retrieve call again.
I use 1xPVDM2-8 to support 3xVIC2-2E/M as DSP calculator recommended. The error was repeart intermittent. Kindly help to share any idea how can i fix this? Thanks
DSP out of resource
The best way to solve your problem-replace your DSP with PVDM2-64 for example.
What you think?
Also please,take a look for this topic.
https://supportforums.cisco.com/thread/288096?referring_site=kapi?referring_site=smartnav
DSP out of resource
Hi, Rojer-bkk!
Were you able to solve the problem with DSP out of resource for VIC2-2E/M?
I have the same situation - E/M, No dsps found either locally or globally. and only restart the router.
c2811, PVDM2-16, 2xVIC2-2E/M, c2800nm-advipservicesk9-mz.124-25d.bin
No conference bridge or no transcoder is configured on the router.
DSP out of resource
I saw that error a couple of times before. I saw that error related to fax calls, the router using PVDM 3 tries to allocate DSP channel using Cisco FAX Relay, which is not supported on PVDM 3, and the call fails, in such scenario the fix is to apply:
voice service pots
fax rate disable
In this case PVDM 2 should not have this same behavior.
I agree that should be better to add additional DSP resources.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
DSP out of resource
Thanks, but problem with PVDM 2.
We use the low-complex codec, G711ulaw,
Two VIC2-2E/M is four voice ports only. PVDM2-16.
Why need to add DSP?
This is not single bug, We have about 20 branch office with E/M, and we need to reset one router per week approximately.
However, in the case of the VWIC2-1MFT-E1  - no problems.
Hall of Fame Super Gold
DSP out of resource
Update IOS.
831
