Community Member
DSP problem
Hi all,
I got the following error on 2811V/K9 router configured as H323 gateway. Its the output of sh logging. I have searched for the error but no clue. Any ideas ??
Sheeraz
Apr 21 06:06:43.012: %C5510-1-C5510_HPI_TIMEOUT: HPI Timeout error for pa_bay 0
pump 0 dsp 4.
Apr 21 06:06:44.328: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
lable on slot 0 dsp 4.
Apr 21 06:06:49.340: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 21 06:06:54.340: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 11:57:53.199: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 11:57:56.871: %C5510-1-C5510_CHPI_ERROR: cHPI error for pa_bay 0 pump 0 d
sp 4.
Apr 23 11:57:58.199: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 11:58:03.199: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 11:58:08.199: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 11:58:13.199: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 12:44:17.875: %C5510-1-C5510_CHPI_ERROR: cHPI error for pa_bay 0 pump 0 d
sp 4.
Apr 23 12:44:18.387: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 12:44:23.387: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 12:44:28.387: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Apr 23 12:44:33.387: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors avai
Bronze
Re: DSP problem
There is a bug asociated with this problem CSCse39727
The error message "C5510-1-NO_RING_DESCRIPTORS" may be seen in certain network conditions when analog ports are connected to the PSTN and "supervisory answer" tones are enabled on these ports. The DSP associated with this message will restart affecting all ports associated with it.
Try this workaround
Under the analog voice-port, disable "supervisory answer dualtone xxx".
Community Member
Re: DSP problem
I also hit something similar to that.
The setup is the following :
Voice gateway is the router 3845 connected with E1 to PBX.The IOS is 12.4.15T1
I find the following on the logs
Oct 2 14:28:58 CET: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 1 dsp 13.
Oct 2 14:29:45 CET: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 1 dsp 13.
Oct 2 14:31:56 CET: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 1 dsp 13.
Oct 2 14:32:02 CET: %C5510-1-NO_RING_DESCRIPTORS: No more ring descriptors available on slot 1 dsp 13.
What we experience is that a after some minutes calls fall,can it be related somehow to that ?
Thanks for any help/idea
Community Member
Re: DSP problem
I had a similar issue on a 2801, had to change the version of the IOS I was using and load new microcode onto the DSP's. This took care of the issue for me.
Steve
Community Member
Re: DSP problem
What I can't understand is why the twin voice gateway with same IOS version and same dspware (9.4.0) doesn't experience the issue.
Francesco
4297
