DSP question
satish rawat
I need to know a simple way to identify the available dsp resources in a Voice router ( 3845). I am currently using it and not sure if there are available dsps in it that can be used for transcoding and confrencing purpose.
Pls refer me a good cisco doc or way to identify available dsps
Rob Huffman
Hi Satish,
Have you tried;
show voice dsp detailed
Hope this helps!
Rob
Thanks..this looks useful command
Hi Satish,
'show voice dsp group all' is actually a more useful command in determining how many DSPs you have and what they are being used for. You can see if you've run out of DSPs by checking for allocation errors at the bottom of the command.
hth,
nick
