Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DSP question
I want to connect 2 PRIs to a 2811, I'm using the DSP calculator and it says that for 48 calls all g711 u law I need
2 DSP(s).
one PVDM2-32
or
two PVDM2-16
I have a spare PVDM2-64
that should be enough, right?
or do i need 2 PVDM2-64
thanks
also do you have a document that will explain the pvdm types like 2-32, 2-16, 2-64 and so forth
thank you
1 REPLY
Re: DSP question
Yes, a PDVM2-64 will be enough and you'll also have some channels left.
Each DS0 from the PRI that carries voice uses 1 channel, and you have 64 on that DSP.
Configuring Enhanced Conferencing and Transcoding for Voice Gateway Routers
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/interop/intcnf2.html
High-Density Packet Voice Digital Signal Processor Module for Cisco IP Com Sol
http://www.cisco.com/en/US/partner/prod/collateral/routers/ps5854/product_data_sheet0900aecd8016e845_ps3115_Products_Data_Sheet.html
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
338
