DSP required ?
Hello, my CUCM cluster is connected to a gateway router (running CME). It connects to my ITSP via a SIP trunk.
There is no transcoding taking place, as I am using G711 in my CUCM  cluster and G711 is also being used for between the gateway and the  ITSP.
My question is does this gateway actually need a hardware DSP in order to get calls out to the ITSP and receive calls ?
Can you have functional VOIP gateways without any hardware DSPs installed ?
  • IP Telephony
1 REPLY
VIP Purple
DSP required ?
Basically, DSPs are required if u have PSTN terminated on to your router like E1/T1 PRI or FXS /FXO cards inserted on to your router.
DSPs are also required if u are using Conference with G.729 Codec.
In your case, since u are using G711, no DSPs would be required.
regds,
aman
97
