DSP resource question
                             I have a DSP resource question. I am currently looking in my gateway and it is telling me that  the utilization is at 95 % but I only have four active calls on it. Could this mean that my DSP are locking up.  I have 2 PVDM ver 3 (64) on the gateway.
Utilization: 95.31 percent
Total channels: 128
Inuse channels: 122
Disabled channels: 0
Pending channels: 0
Free channels: 6
PORT           CODEC     VAD VTSP STATE            VPM STATE
0/0/0:23.1      g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0/0:23.2      g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0/0:23.3      g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0/0:23.4      g711ulaw   n  S_CONNECT             S_TSP_CONNECT
0/0/0:23.5      -          -  -
0/0/0:23.6      -          -  -
0/0/0:23.7      -          -  -
0/0/0:23.8      -          -  -
0/0/0:23.9      -          -  -
0/0/0:23.10     -          -  -
0/0/0:23.11     -          -  -
0/0/0:23.12     -          -  -
Total channels: 128
Inuse channels: 122
Pending channels: 0
Free channels: 6
0/0/0:23.5      -          -  -
0/0/0:23.6      -          -  -
0/0/0:23.7      -          -  -
0/0/0:23.8      -          -  -
0/0/0:23.9      -          -  -
0/0/0:23.10     -          -  -
0/0/0:23.11     -          -  -
0/0/0:23.12     -          -  -
DSP channels ARE allocated for the FXO/FXS/E1/T1 and for CFB/MTP/XCODER upon configuration.
What do you have configured??
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Silver
To add to this, "show voice dsp group all" should allow you to see how the DSPs are assigned.
    I understand what you are saying about the conferencing ECT, but does it really matter if you only  have 4 active calls 98% utilization is a bit high. The router is a 3900 with 2 64 pvdm 3 cards.
Profile ID = 10, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP   Status : ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 20
Number of Resource Available : 20
Codec Configuration: num_of_codecs:5
Codec : g729r8, Maximum Packetization Period : 60
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Dspfarm Profile Configuration
Profile ID = 11, Service = CONFERENCING, Resource ID = 2
Number of Resource Configured : 3
Number of Resource Available : 3
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    2   28.3.5   UP     N/A  FREE  xcode   1      -         -         -
0    7   28.3.5   UP     N/A  FREE  xcode   1      -         -         -
0    8   28.3.5   UP     N/A  FREE  xcode   1      -         -         -
0    8   28.3.5   UP     N/A  FREE  conf    2      -         -         -
Re: DSP resource question
Do the math, 128 channels, 122 allocated, thats what you're looking at.
java
Thanks for the response would just adding extra DSP resources resolve this issue. What I find wiered is their is only 4 active calls.
Whether theres a call, or not, the channels are allocated.
Do you need to configure something else that requires DSPs??
java
I have agents complaining of poor voice quality and getting disconnected from CTIOS.
Then start by looking at debugs in your gw, cucm and uccx to troubleshoot disconnected calls.
java
370
