DSP Resources
Can someone tell me which command I can run on a 2821 router to see how much dsp resources I have available after a pri install?
Re: DSP Resources
I beleive it is show dsp dsp idle, but that only shows how many are not in use.
Re: DSP Resources
you can issue sh voice dsp, it will show resources allocated and which are idle
java
if this helps, please rate
java
www.cisco.com/go/pdi
Re: DSP Resources
The command 'show voice dsp detailed' should give the detail that you require, it shows the voice dsp channels and the dsp each channel is assigned to.
Allan.
Pls rate helpful posts.
Re: DSP Resources
test dsprm 1
278
