DSP Resources
I am configuring 4 no's E1 port's  with mgcp service, On 3rd port it prompts me with the below error.It is a new router with PVDM3 64 and no conferencing and transcoding uptil now has been configured to utilize the DSP.
My question is can i configured 120 channels with PVDM3 64 ?? I have used the DSP calculator and it without transcoding/conferencing it is saying no dsp required, i am confuse so can anybody confirm to me how much  DSP will be required.
% Not enough DSP resources available to configure pri-group on controller E1 0/1/0
% The remaining dsp resources are enough for 4 time slots.
% For current codec complexity, 2 extra 16 channel dsp(s) are required to create this voice port.
yourname(config-controller)#
Mar 13 13:04:47.176: %XCCTSP_VOICE-3-NOSDB: No signaling data block is available to build the
        voice interface(0/0:15) or DSP may not be present
2 ACCEPTED SOLUTIONS
Hi,  There are many possible
There are many possible scenarios that could explain what is going on, before going further, can you please post the output from:
-show diag
-show inventory
-show version
-show voice dsp group all
Remember that you can setup the codec complexity under "voice-card", and if you use "Medium or High" the calculation will be different, in addition, is there any other Voice Interface Card installed on the Router?
Let's recall few things: 1 PVDM3-64 has 480 Credits per core, since the PVDM has two cores, we have a total of 960 credits.
http://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-ip-service-level-agreements-slas/whitepaper_C11-718333.html
One single DSO on a T1-E1 consumes 15 credits if Codec Complexity Flex is being used (Default), now, some math:
E1 = 30 Bchannels
4 E1 = 120 Bchannels
120 * 15 = 1800 Credits
You'll need at least another PVDM3-64 to support the 4 E1 interfaces.
I think you may want to verify the DSP Calculator again:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Router: 2951
IOS: 15.1(4)M
DSP Modules Required:
PVDM3-128: 1
DSP Module Allocation:
Router Slot 0:
120 Voice (94%) 8 Available (6%)
PVDM Slot 0/0: PVDM3-128
Call Volume Allocation:
Router Slot 0
Low
Med
High
Slot 0/0: VWIC3-4MFT-T1/E1(E1)
120
BTW, I created the Calculator Session with Low Complexity, you have to make sure no g729 calls will go through the Router, otherwise, additional resources will be needed.
~jorge
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
VIP Purple
Hi, [+5] to Jorge for
[+5] to Jorge for explaination.
you can also refer the fantatsic DOC by AOK
https://supportforums.cisco.com/document/123126/cisco-pvdm2-and-pvdm3-dsp-creditmips-allocation
regds,
aman
-show diag
-show inventory
-show version
E1 = 30 Bchannels
Router: 2951
IOS: 15.1(4)M
PVDM3-128: 1
Router Slot 0:
Router Slot 0
Low
Med
High
120
~jorge
VIP Purple
regds,
aman
Thanks Aman and george Ur
Ur links helped me a lot.
682
