DSP resources
Can anyone guide me how to size the DSP resources in a Cisco router? Say you have a certain number of DSP resources, how you will you divide the same among conferencing, transcoding etc.
How can I verify the same in the Cisco routers ? Can anyone give me a good document for the same?
Pete
1 REPLY
Re: DSP resources
Go under Tools & Resources and check out the DSP calculator. That should keep you busy for awhile.
182
