Community Member
DSP:s needed Router with one E1 and 2FXS
An existing customer has a 2911 Router with one E1 PRI ISDN connected (CSS). (VWIC3-1MFT-T1/E1)
The customer has a PVDM3-32 as far as hardware DSP recources goes.
The customer wants to add an additional card supporting 2FXS interfaces (VIC3-2FXS/DID)
Do the customer also need an additional DSP card for that?
Fredrik
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
That is correct.
Thank you for the nice rating and good luck!
Depends on how many E1 channels are used, and what other features are needed. Check:
http://www.cisco.com/web/applicat/dsprecal/dsp_calc.html
Community Member
The router only serves as an MGCP configured ISDN-Gateway.
Only G711 codec is in use.
I tried out your link and it seems to work, i would want an confirmation on my input:
I inputed the Router Model 2911
Slot0: VWIC3-1MFT-T1/E1 (E1)
Slot1: VIC3-2FXS/DID.
The webpage prefilles voice channel values.
I fill in the same number of channels as "low Complexity". (30 + 2)
(Only G711 codec used).
No additional services.
If everything is correct that means that the current PVDM32 is enough.
output
Router: 2911
IOS: 15.1(3)T
DSP Modules Required:
PVDM3-32: 1
DSP Module Allocation:
Router Slot 0:32 Voice (100%) 0 Available (0%)
PVDM Slot 0/0: PVDM3-32
Call Volume Allocation:
Router Slot 0LowMedHigh
Slot 0/0: VWIC3-1MFT-T1/E1(E1)30
Slot 0/1: VIC3-2FXS/DID2
That is correct.
590
