Community Member
DSP sharing for NM-HDV Modue
We are using 3845 Router as Gateway.we are using NM-HDV module for conferencing and this module has two PVDM-12 SIMM's. Presently we configured one Transcoder session and 5 Conference session.
Can it possible to do DSP Sharing, because apart from NM-HDV module we are connected Two NM-HDV2-2T1/E1 network modules with two numbers of PVDM2-64 DSP's on each module.
Is it possible to share these DSP(PVDM2-64) Resources for Conferencing with NM-HDV Module.( Presently we are having two numbers of spare PVDM2-64 modules)
If yes, please tell me how to configure and share the DSP resources for NM-HDV conference module.
Please help me out!!
1 REPLY
Hall of Fame Super Silver
Re: DSP sharing for NM-HDV Modue
You can enabled sharing by applying the following:
voice-card 0
dspfarm
Keep in mind that a single DSP cannot be shared between conference bridge and voice termaination or transcoder, however a DSP can be shared beteen voice termination and transcoding. With this beeing said PVDM-64 has 4 DSPs, so when you enable dspfarm on it one of the 4 DSPs can be usued for conferencing and the rest for voice termination and transcoding for example.
HTH,
Chris
256
