Community Member
DSP state change is causing active calls to drop
I have this issue for quite some time where active call will drop becuase DSP in slot 0 will go down and then come back up.  We have upgraded the IOS, DSP micro code and replaced the DSPs.  The next logical step is to replace the hardware and all its compnents.  But before I do that I'd like to troubleshoot this issue and get to the root cause.  Any help is appreciated.  Also I have listed the documents that I used during this troubleshooting process.
Logs from show logging | i DSP
010075: Jul 31 10:05:28 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010076: Jul 31 10:05:28 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010111: Jul 31 10:14:53 EDT: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
010112: Jul 31 10:14:53 EDT: Warning! DSP 2 in slot 0 is running non-default firmware 28.3.2
010161: Jul 31 10:25:34 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010162: Jul 31 10:25:34 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010202: Jul 31 10:36:25 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010203: Jul 31 10:36:25 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010307: Jul 31 12:19:19 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010308: Jul 31 12:19:19 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010348: Jul 31 12:30:11 EDT: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
010349: Jul 31 12:30:11 EDT: Warning! DSP 2 in slot 0 is running non-default firmware 28.3.2
010413: Jul 31 12:41:49 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010414: Jul 31 12:41:49 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010460: Jul 31 12:51:41 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010461: Jul 31 12:51:41 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010571: Jul 31 14:26:47 EDT: %DSPRM-5-UPDOWN: DSP 1 in slot 0, changed state to up
010572: Jul 31 14:26:47 EDT: Warning! DSP 1 in slot 0 is running non-default firmware 28.3.2
010617: Jul 31 14:37:42 EDT: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
010618: Jul 31 14:37:42 EDT: Warning! DSP 2 in slot 0 is running non-default firmware 28.3.2
010662: Jul 31 14:48:32 EDT: %DSPRM-5-UPDOWN: DSP 2 in slot 0, changed state to up
010663: Jul 31 14:48:32 EDT: Warning! DSP 2 in slot 0 is running non-default firmware 28.3.2
Documents:
http://www.cisco.com/en/US/docs/ios/12_3/vvf_c/voice_troubleshooting/old/dsp_ts.html
http://www.cisco.com/en/US/tech/tk652/tk653/technologies_tech_note09186a00800e66b1.shtml
Fasih Ahmed
Everyone's tags (7)
Green
What is your router type and IOS being used ?
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Community Member
Hi  Alex,
The router is 3825 with IOS 12.2 (24) T5.
Fasih
Green
Fasih,
First of all appologies for the delay.
looking at this link
http://www.cisco.com/en/US/tech/tk652/tk698/technologies_tech_note09186a0080a7af82.shtml
You may be running in to a couple of 3800 series router bugs.
CSCse92174
CSCsu21777
These can be caused by running DSP versions for IOS mainline versions in T Train versions.
Not sure how up to date this link is but I have also seen that TAC do not publish the DSP to IOS version matrix.
Try this
show flash
see if you have a DSP update file in the flsh
If yes then delete it.
Upgrade your router to 12.4.24T7
then Reload.
Hopefully now your DSPs will update to the correct DSP version for T-Train IOS.
If this does not work I can only suggest you open a TAC case.
Alex.
Re: DSP state change is causing active calls to drop
Also make sure there are no .rbf files in flash which will cause the DSPto load this DSPware.
2257
