DSP Transcoder Configuration Issue
Hi All,
       I have to configure Hardware conference on my voice gateway 3845.Currently 3 PRI(30 channels) connection already terminated in our voice gateway and i am having 64+48 PVDM available on the router.As per my understanding 3*32 =96 PVDM is occupied for the PRI connection and 16 PVDM is free on this.But when I tried to configure the conferencing I am getting the error like ......
dspfarm transcoder maximum sessions ?    <0-0>.
Please suggest what configuration I have to do to fix this issue.
Thanks in advance....
Nithin Louis.
  • IP Telephony
Without full details (config and HW) most likely reason is you're out of resources.
Also, you're not talking about PVDMs, you're talking about channels. ie You have a PVDM2-64 which has 64 channels, not 64 PDVMs
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Thanks for your mail javalenc......Here is the Hardware details and Configurations details follows
Configuration
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15 type r2-digital r2-semi-compelled ani
ds0-group 1 timeslots 17-31 type r2-digital r2-semi-compelled ani
controller E1 0/1/1
shutdown
framing NO-CRC4
interface Vlan250
description "Standby connection with WAN Router1"
ip address 10.48.3.6 255.255.255.0
ip flow ingress
ip flow egress
standby 1 ip 10.48.3.1
standby 1 timers 1 4
standby 1 preempt
interface Vlan332
ip address 10.40.31.172 255.255.255.224
ip wccp 61 redirect in
ip flow ingress
ip flow egress
ip route-cache flow
ip ospf network point-to-point
interface Vlan333
ip address 10.40.31.102 255.255.255.224
ip flow ingress
ip flow egress
ip route-cache flow
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.40.31.102
interface Vlan335
ip address 10.40.31.202 255.255.255.224
ip flow ingress
ip flow egress
ip route-cache flow
router ospf 1
router-id 10.254.254.96
log-adjacency-changes
redistribute static subnets
network 10.40.31.102 0.0.0.0 area 0
network 10.40.31.172 0.0.0.0 area 0
network 10.40.31.202 0.0.0.0 area 0
network 10.40.51.2 0.0.0.0 area 0
network 10.254.254.96 0.0.0.0 area 0
router bgp 64519
no synchronization
bgp log-neighbor-changes
neighbor 172.31.186.77 remote-as 65000
no auto-summary
ip forward-protocol nd
ip route 10.32.51.0 255.255.255.0 10.40.128.14
ip route 10.32.64.0 255.255.192.0 10.40.128.14 200
ip route 10.32.128.0 255.255.128.0 10.40.128.14
ip route 10.33.0.0 255.255.192.0 10.40.128.14
ip route 10.33.64.0 255.255.192.0 10.40.128.14 200
ip route 10.34.0.0 255.255.192.0 10.40.128.14
ip route 10.34.1.0 255.255.255.0 10.40.128.14 200
ip route 10.34.64.0 255.255.192.0 10.40.128.14 200
ip route 10.35.0.0 255.255.192.0 10.40.128.14
ip route 10.35.64.0 255.255.192.0 10.40.128.14 200
ip route 10.38.0.0 255.255.192.0 10.40.128.14
ip route 10.38.64.0 255.255.192.0 10.40.128.14 200
ip route 10.48.1.0 255.255.255.0 10.40.128.14
ip route 10.48.2.0 255.255.255.0 10.40.128.14 200
ip route 10.64.1.0 255.255.255.0 10.48.3.2 200
ip route 10.64.1.0 255.255.255.0 10.40.128.14 210
ip route 10.65.0.0 255.255.0.0 10.48.3.2 200
ip route 10.65.0.0 255.255.0.0 10.40.128.14 210
ip route 10.70.0.0 255.255.0.0 10.40.128.14
ip route 10.90.90.0 255.255.255.0 10.48.3.2 200
ip route 10.90.90.0 255.255.255.0 10.40.128.14 210
ip route 10.128.0.0 255.255.0.0 10.48.3.2 200
ip route 10.128.0.0 255.255.0.0 10.40.128.14 210
ip route 10.130.0.0 255.255.0.0 10.48.3.2 200
ip route 10.130.0.0 255.255.0.0 10.40.128.14 210
ip route 10.132.0.0 255.255.0.0 10.48.3.2 200
ip route 10.132.0.0 255.255.0.0 10.40.128.14 210
ip route 10.141.0.0 255.255.0.0 10.48.3.2 200
ip route 10.141.0.0 255.255.0.0 10.40.128.14 210
ip route 10.150.0.0 255.255.0.0 10.48.3.2 200
ip route 10.150.0.0 255.255.0.0 10.40.128.14 210
ip route 10.160.0.0 255.255.0.0 10.48.3.2 200
ip route 10.160.0.0 255.255.0.0 10.40.128.14 210
ip route 10.161.0.0 255.255.0.0 10.48.3.2 200
ip route 10.161.0.0 255.255.0.0 10.40.128.14 210
ip route 10.165.0.0 255.255.0.0 10.48.3.2 200
ip route 10.165.0.0 255.255.0.0 10.40.128.14 210
ip route 10.192.0.0 255.255.0.0 10.48.3.2 200
ip route 10.192.0.0 255.255.0.0 10.40.128.14 210
ip route 10.254.254.5 255.255.255.255 10.40.128.14
ip route 10.254.254.6 255.255.255.255 10.40.128.14
ip route 155.195.0.0 255.255.0.0 10.48.3.2 200
ip route 172.16.0.0 255.255.0.0 10.40.128.14 200
ip route 172.29.12.210 255.255.255.255 10.48.3.2 200
ip route 172.29.12.210 255.255.255.255 10.40.128.14 210
ip route 172.29.20.0 255.255.255.0 10.48.3.2 200
ip route 172.29.20.0 255.255.255.0 10.40.128.14 210
ip route 172.31.1.0 255.255.255.0 10.48.3.2 200
ip route 192.168.204.0 255.255.255.0 10.48.3.2 200
ip route 192.168.204.0 255.255.255.0 10.40.128.14 210
ip route 192.168.206.99 255.255.255.255 10.48.3.2 200
ip route 192.168.206.99 255.255.255.255 10.40.128.14 210
ip route 192.168.206.107 255.255.255.255 10.48.3.2 200
ip route 192.168.206.107 255.255.255.255 10.40.128.14 210
ip route 192.168.210.19 255.255.255.255 10.48.3.2 200
ip route 192.168.210.19 255.255.255.255 10.40.128.14 210
ip flow-cache timeout active 5
ip flow-export source Vlan332
ip flow-export version 5
ip flow-export destination 10.32.174.38 2055
ip flow-export destination 10.34.2.23 2055
no ip http server
no ip http secure-server
ip dns server
ip access-list extended waas-wccp-redirect-list
remark WAAS WCCP RRB Redirect list
deny   tcp any any eq telnet
deny   tcp any any eq 22
deny   tcp any any eq 161
deny   tcp any any eq 162
deny   tcp any any eq 123
deny   tcp any any eq bgp
deny   tcp any any eq tacacs
deny   tcp any any eq 2000
deny   tcp any any eq 5060
deny   tcp any any eq 1718
deny   tcp any any eq 1719
deny   tcp any any eq 1720
deny   tcp any any eq 554
deny   tcp any any eq 1755
deny   tcp any eq telnet any
deny   tcp any eq 22 any
deny   tcp any eq 161 any
deny   tcp any eq 162 any
deny   tcp any eq 123 any
deny   tcp any eq bgp any
deny   tcp any eq tacacs any
deny   tcp any eq 2000 any
deny   tcp any eq 5060 any
deny   tcp any eq 1718 any
deny   tcp any eq 1719 any
deny   tcp any eq 1720 any
deny   tcp any eq 554 any
deny   tcp any eq 1755 any
permit tcp any any
logging origin-id hostname
logging source-interface Loopback51
logging 10.38.20.23
snmp-server community 1nvst@Ncbc RO
control-plane
voice-port 0/1/0:0
voice-port 0/1/0:1
dial-peer voice 7000 voip
description to call manager
preference 1
destination-pattern 7...
voice-class codec 1
voice-class h323 1
session target ipv4:10.40.71.9
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 104 pots
description KSA Outbound Calls
destination-pattern 05........
no digit-strip
port 0/1/0:1
forward-digits all
dial-peer voice 105 pots
description Local RY Calls
destination-pattern [2-8]......
port 0/1/0:1
forward-digits 7
dial-peer voice 221 pots
preference 1
incoming called-number .
direct-inward-dial
port 0/1/0:0
dial-peer voice 160 pots
destination-pattern 0[^05].......
direct-inward-dial
port 0/1/0:1
forward-digits 9
dial-peer voice 7160 pots
destination-pattern 800.......
direct-inward-dial
port 0/1/0:1
forward-digits 10
dial-peer voice 7001 voip
description to call manager-subscriber
preference 2
voice-class codec 1
voice-class h323 1
session target ipv4:10.40.71.10
no vad
dial-peer voice 211 pots
destination-pattern 00.T
direct-inward-dial
port 0/1/0:1
prefix 00
dial-peer voice 9200 pots
destination-pattern 89200.....
direct-inward-dial
port 0/1/0:1
forward-digits 9
dial-peer voice 8002 pots
destination-pattern 8800.......
direct-inward-dial
port 0/1/0:1
forward-digits 10
dial-peer voice 8000 pots
destination-pattern 88002443333
direct-inward-dial
port 0/1/0:1
forward-digits 10
dial-peer voice 8888 pots
destination-pattern 8T
direct-inward-dial
port 0/1/0:1
forward-digits 8
line con 0
password 7 0505050D221D1C5A
logging synchronous
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
login
line vty 5 15
login
scheduler allocate 20000 1000
ntp clock-period 17180075
ntp server 10.40.20.241 prefer
ntp server 10.40.20.242
event manager applet closeloopback
event syslog pattern "%TRACKING-5-STATE: 1 rtr 1 reachability Up->Down"
action 1.0 cli command "enable"
action 1.1 cli command "conf t"
action 1.2 cli command "interface  lo2"
action 1.3 cli command "shut"
action 1.4 cli command "end"
event manager applet openloopback
event syslog pattern "%TRACKING-5-STATE: 1 rtr 1 reachability Down->Up"
action 1.3 cli command "no shut"
action 1.4 cli command "end "
end
Hardware details
3845 Backplane EEPROM:
    Hardware Revision        : 1.0
    Top Assy. Part Number    : 800-23093-01
    Board Revision           : B0
    Deviation Number         : 0
    Fab Version              : 04
    PCB Serial Number        : FOC12173EC8
    RMA Test History         : 00
    RMA Number               : 0-0-0-0
    RMA History              : 00
    Part Number              : 73-8639-04
    CLEI Code                : IPME110BRA
    Chassis Serial Number    : FHK1222F2UZ
    Product (FRU) Number     : CISCO3845
    Version Identifier       : V01
    Hardware date code       : 20080425
    EEPROM format version 4
    EEPROM contents (hex):
      0x00: 04 FF 40 04 2B 41 01 00 C0 46 03 20 00 5A 35 01
      0x10: 42 42 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
      0x20: 32 31 37 33 45 43 38 03 00 81 00 00 00 00 04 00
      0x30: 82 49 21 BF 04 C6 8A 49 50 4D 45 31 31 30 42 52
      0x40: 41 C2 8B 46 48 4B 31 32 32 32 46 32 55 5A CB 92
       0x50: 43 49 53 43 4F 33 38 34 35 20 20 20 20 20 20 20
      0x60: 20 20 89 56 30 31 20 83 01 32 67 29 FF FF FF FF
      0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
       Backplane Registers
   Backplane Revision:              00BE
   Power Supply Status:             F50F
   -48V PS and Env Status:          FFFF
   -48V Isolation Control:          0007
   Backplane Cookie:                000C
   ENM/Backplane FPGA Revision:     00BE
   ENM/Backplane FPGA Int0 Status:  FFFF
   ENM/Backplane FPGA Int2 Status:  00FF
   ENM/Backplane FPGA Int4 Status : EF00
   ENM Interrupt Mask:              0047
   ENM/BP FPGA Interrupt 4 Mask:    0040
   ENM1 Test Port:                  00E3
   ENM2 Test Port:                  00E3
   ENM3 Test Port:                  00C3
   ENM LED Control:                 0077
    ENM OIR Control:                 0000
   ENM OIR Status:                  2292
   ENM PCI Speed Status             000C
   Backplane FPGA Diag Int Control: FFFF
   ENM1 OIR State Machine Status:   C4C4
   ENM2 OIR State Machine Status:   C441
   ENM3 OIR State Machine Status:   0000
   ENM4 OIR State Machine Status:   0000
   Backplane Voltage Margin:        0000
Slot 0:
    C3845 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 13 ports
    Port adapter is analyzed
    Port adapter insertion time unknown
    Onboard VPN        : FW ver01100200
    EEPROM contents at hardware discovery:
    PCB Serial Number        : FOC12215Y3T
    Hardware Revision        : 1.4
    Top Assy. Part Number    : 800-23616-06
    Board Revision           : B0
    Fab Version              : 05
    RMA History              : 00
    Processor type           : 69
    Product (FRU) Number     : CISCO3845-MB
    Version Identifier       : V06
    Chassis MAC Address      : 001d.708d.18b0
    MAC Address block size   : 48
    Part Number              : 73-8799-09
    Hardware date code       : 20080526
      0x00: 04 FF C1 8B 46 4F 43 31 32 32 31 35 59 33 54 40
      0x10: 04 2C 41 01 04 C0 46 03 20 00 5C 40 06 42 42 30
      0x20: 88 00 00 00 00 02 05 03 00 81 00 00 00 00 04 00
      0x30: 09 69 C6 8A 49 50 4D 45 31 31 30 42 52 41 CB 8C
      0x40: 43 49 53 43 4F 33 38 34 35 2D 4D 42 89 56 30 36
      0x50: 20 D9 02 40 C1 C3 06 00 1D 70 8D 18 B0 43 00 30
      0x60: 82 49 22 5F 09 83 01 32 67 8E C2 8B 46 48 4B 31
      0x70: 32 32 32 46 32 55 5A FF FF FF FF FF FF FF FF FF
     PVDM Slot 0:
    64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
    Hardware Revision        : 4.0
    Part Number              : 73-8541-05
    Board Revision           : B0
    Fab Version              : 04
    PCB Serial Number        : FOC1220543Q
    RMA History              : 00
    Processor type           : 00
    Product (FRU) Number     : PVDM2-64
      0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 42 30
      0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 32 32 30
      0x20: 35 34 33 51 03 00 81 00 00 00 00 04 00 09 00 CB
      0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
      0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
      0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
    WIC Slot 0:
    Serial 2T (12in1)
    Hardware revision 1.0             Board revision B0
    Serial number     36347141      Part number    800-03181-03
    Version Identifier     V01     FRU Part Number     WIC-2T
    Test history      0x0             RMA number     00-00-00
    Connector type    PCI
    EEPROM format version 1
      0x20: 01 12 01 00 02 2A 9D 05 50 0C 6D 03 00 00 00 00
      0x30: 58 00 00 00 08 03 02 00 FF FF FF FF FF FF FF FF
    WIC Slot 1:
    VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1
    Hardware Revision        : 0.0
    Top Assy. Part Number    : 800-22629-05
    Board Revision           : C0
    Fab Version              : 04
    PCB Serial Number        : FOC14031Y4L
    RMA History              : 00
    Product (FRU) Number     : VWIC2-2MFT-T1/E1
      0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
      0x10: 42 43 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
      0x20: 34 30 33 31 59 34 4C 03 00 81 00 00 00 00 04 00
      0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
      0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
    WIC Slot 2:
    VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1
    Top Assy. Part Number    : 800-22628-05
    Board Revision           : B0
    Fab Version              : 04
    PCB Serial Number        : FOC122009K8
    RMA History              : 00
    Product (FRU) Number     : VWIC2-1MFT-T1/E1
      0x00: 04 FF 40 03 FD 41 00 00 C0 46 03 20 00 58 64 05
      0x20: 32 32 30 30 39 4B 38 03 00 81 00 00 00 00 04 00
      0x30: CB 90 56 57 49 43 32 2D 31 4D 46 54 2D 54 31 2F
    WIC Slot 3:
    4 Port FE Switch
    Base MAC Address         : 0027.0dd5.29f4
    PCB Serial Number        : FOC14045GKR
    Hardware Revision        : 6.0
    Part Number              : 73-8474-06
     Board Revision           : A0
    Top Assy. Part Number    : 800-24193-02
    Fab Version              : 05
    CLEI Code                : IPUIA00RAA
    RMA History              : 00
    Product (FRU) Number     : HWIC-4ESW
    Connector Type           : 01
      0x00: 04 FF CF 06 00 27 0D D5 29 F4 43 00 04 C1 8B 46
      0x10: 4F 43 31 34 30 34 35 47 4B 52 40 00 56 41 06 00
      0x20: 82 49 21 1A 06 42 41 30 C0 46 03 20 00 5E 81 02
      0x30: 88 00 00 00 00 02 05 C6 8A 49 50 55 49 41 30 30
      0x40: 52 41 41 03 00 81 00 00 00 00 04 00 CB 89 48 57
      0x50: 49 43 2D 34 45 53 57 89 56 30 31 20 D9 02 C1 40
      0x60: 05 01 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 1:
     Voice NM-HD-2VE (3 on-board DSPs) Port adapter
    Hardware Revision        : 5.3
    Top Assy. Part Number    : 800-20164-02
    Board Revision           : B0
    Deviation Number         : 0-0
    Fab Version              : 03
    PCB Serial Number        : FOC1212389L
    RMA History              : 00
    Product (FRU) Number     : NM-HD-2VE
      0x00: 04 FF 40 03 9C 41 05 03 C0 46 03 20 00 4E C4 02
      0x10: 42 42 30 80 00 00 00 00 02 03 C1 8B 46 4F 43 31
      0x20: 32 31 32 33 38 39 4C 03 00 81 00 00 00 00 04 00
      0x30: CB 89 4E 4D 2D 48 44 2D 32 56 45 89 56 30 31 20
      0x40: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Slot 2:
    Board Revision           : B0
    Fab Version              : 03
    PCB Serial Number        : FOC1212389X
    RMA History              : 00
       0x20: 32 31 32 33 38 39 58 03 00 81 00 00 00 00 04 00
Slot 3:
    Integrated Service Engine-2 Port adapter, 1 port
    Part Number              : 73-11062-04
    Top Assy. Part Number    : 800-28761-05
    Board Revision           : A0
    Fab Version              : 01
    PCB Serial Number        : FOC13500G7E
    RMA History              : 00
    Product (FRU) Number     : NME-WAE-522-K9
     Version Identifier       : V05
    CLEI Code                : IPUIBETRAA
      0x00: 04 FF 40 05 82 41 01 00 82 49 2B 36 04 C0 46 03
      0x10: 20 00 70 59 05 42 41 30 88 00 00 00 00 02 01 C1
      0x20: 8B 46 4F 43 31 33 35 30 30 47 37 45 03 00 81 00
      0x30: 00 00 00 04 00 CB 8E 4E 4D 45 2D 57 41 45 2D 35
      0x40: 32 32 2D 4B 39 89 56 30 35 20 D9 03 40 C1 CB C6
      0x50: 8A 49 50 55 49 42 45 54 52 41 41 FF FF FF FF FF
     - Integrated Service Engine Daughter Card.
    Part Number              : 73-10372-01
    Top Assy. Part Number    : 800-28709-02
    Board Revision           : B0
    Fab Version              : 01
    PCB Serial Number        : FOC13492KZN
     RMA History              : 00
      0x00: 04 FF 40 04 F9 41 01 00 82 49 28 84 01 C0 46 03
      0x10: 20 00 70 25 02 42 42 30 88 00 00 00 00 02 01 C1
      0x20: 8B 46 4F 43 31 33 34 39 32 4B 5A 4E 03 00 81 00
      0x30: 00 00 00 04 00 D9 02 40 C1 FF FF FF FF FF FF FF
Waiting for ur reply
Don't see voice-card enabled in the configurations.  Make sure you have enable voice-card and configured it for DSP farm as example below:
voice-card 0
no dspfarm
dsp services dspfarm
Bronze
Hi friend, I note that you are trying to configure PVDM-II for trancoding resurces, so you need to considerer this:
1. You need to configure the DSPFarm in this way:
voice-card 0
dspfarm
sccp local GigabitEthernet0/0
sccp ccm CCM-IP identifier 1 version X
sccp
sccp ccm group 10
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register xcodec
keepalive retries 5
dspfarm profile 1 transcode
codec g729r8
codec g729br8
codec g729abr8
codec g729ar8
codec g711ulaw
maximum sessions X
associate application SCCP
no shut
2. In the CallManager, you have to add this resource as Enhanced IOS Transcoder using the same name as the profile "xcodec".
hth
David
362
