DSP utilization differently shown in show commands
We have a 3825 router with three PVDM2-64 and one PVDM2-48. With 16 DSP channels in NM-HD-2V, it has 256 channels in the router.
Recently we found that lots of DSPs are used with small amount of active calls.
The following image shows that the DSP utilization is 74.6% (that is 191 channels used) when only 2 active calls.
We then found that "show voice dsp detailed" and "show voice dsp group all" indicates that there are lots of channels no allocated but "show call resource voice stats dsp" still shows high DSP utilization.
So which information is correct? Is there something wrong?
HQ_GWGK_01#show call resource voice stats dsp
Resource Monitor -  Dial-up Resource Statistics Information:
DSP Statistics:
Utilization: 96.87 percent
Total channels: 256
Inuse channels: 248
Disabled channels: 0
Pending channels: 0
Free channels: 8
HQ_GWGK_01#show voice dsp group all
DSP groups on slot 0:
dsp 1:
  State: UP, firmware: 4.4.20
  Max signal/voice channel: 16/16
  Max credits: 240
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 90, reserved credits: 0
    Signaling channels allocated: 16
    Voice channels allocated: 6
    Credits used: 150
    Voice channels:
      Ch01: voice port: 0/0/0:15.10, codec: g729r8, credits allocated: 30
      Ch02: voice port: 0/0/0:15.4, codec: g729r8, credits allocated: 30
      Ch03: voice port: 0/0/0:15.5, codec: g711ulaw, credits allocated: 15
      Ch04: voice port: 0/0/0:15.7, codec: g729r8, credits allocated: 30
      Ch05: voice port: 0/0/0:15.28, codec: g711ulaw, credits allocated: 15
      Ch06: voice port: 0/0/0:15.3, codec: g729r8, credits allocated: 30
dsp 2:
  Max credits: 240
    Shared credits: 60, reserved credits: 0
    Credits used: 180
    Voice channels:
      Ch01: voice port: 0/0/0:15.22, codec: g729r8, credits allocated: 30
      Ch02: voice port: 0/0/0:15.12, codec: g729br8, credits allocated: 30
      Ch03: voice port: 0/0/0:15.29, codec: g729r8, credits allocated: 30
      Ch04: voice port: 0/0/0:15.21, codec: g729r8, credits allocated: 30
      Ch05: voice port: 0/0/0:15.2, codec: g729r8, credits allocated: 30
      Ch06: voice port: 0/0/0:15.9, codec: g729r8, credits allocated: 30
dsp 3:
  Max credits: 240
    Credits used: 180
    Voice channels:
      Ch01: voice port: 0/0/0:15.17, codec: g729br8, credits allocated: 30
      Ch02: voice port: 0/0/0:15.26, codec: g729r8, credits allocated: 30
      Ch03: voice port: 0/0/0:15.14, codec: g729r8, credits allocated: 30
      Ch04: voice port: 0/0/0:15.6, codec: g729r8, credits allocated: 30
      Ch05: voice port: 0/0/0:15.25, codec: g729r8, credits allocated: 30
      Ch06: voice port: 0/0/0:15.31, codec: g729r8, credits allocated: 30
dsp 5:
  Max credits: 240
    Shared credits: 120, reserved credits: 0
    Signaling channels allocated: 14
    Voice channels allocated: 4
    Credits used: 120
    Voice channels:
      Ch01: voice port: 0/0/0:15.1, codec: g729r8, credits allocated: 30
      Ch02: voice port: 0/0/0:15.24, codec: g729r8, credits allocated: 30
      Ch03: voice port: 0/0/0:15.27, codec: g729r8, credits allocated: 30
      Ch06: voice port: 0/0/0:15.23, codec: g729r8, credits allocated: 30
dsp 6:
  Max credits: 240
    Shared credits: 150, reserved credits: 0
    Signaling channels allocated: 0
    Voice channels allocated: 3
    Credits used: 90
    Voice channels:
      Ch01: voice port: 0/0/0:15.15, codec: g729r8, credits allocated: 30
      Ch03: voice port: 0/0/0:15.13, codec: g729r8, credits allocated: 30
      Ch05: voice port: 0/0/0:15.11, codec: g729r8, credits allocated: 30
dsp 7:
  Max credits: 240
    Shared credits: 240, reserved credits: 0
    Voice channels allocated: 0
    Credits used: 0
dsp 8:
  Max credits: 240
    Credits used: 0
dsp 9:
  Max credits: 240
    Credits used: 0
dsp 10:
  Max credits: 240
    Credits used: 0
dsp 11:
  Max credits: 240
    Credits used: 0
dsp 12:
  Max credits: 240
    Credits used: 0
dsp 13:
  Max credits: 240
    Credits used: 0
dsp 14:
  Max credits: 240
    Credits used: 0
dsp 15:
  Max credits: 240
    Credits used: 0
dsp 16:
  Max credits: 240
    Credits used: 0
DSP groups on slot 1:
dsp 1:
  Max signal/voice channel: 8/16
  Max credits: 240
    Signaling channels allocated: 8
    Credits used: 0
DSP groups on slot 2:
This command is not applicable to slot 2
HQ_GWGK_01#show voice dsp detailed
DSP  DSP             DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC    VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
TYPE  NUM CH CODEC    VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  10    0  20810/21188
C5510 001 02 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  04    0 204230/11451
C5510 001 03 g711ulaw  4.4.20 busy  idle      0  0 0/0/0:15  05    0 234759/23887
C5510 001 04 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  07    0      451/320
C5510 001 05 g711ulaw  4.4.20 busy  idle      0  0 0/0/0:15  28    0    9321/9502
C5510 001 06 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  03    0  247637/8350
C5510 001 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 01 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  22    0  93656/50138
C5510 002 02 g729br8   4.4.20 busy  idle      0  0 0/0/0:15  12    0  30952/35167
C5510 002 03 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  29    0    3813/3892
C5510 002 04 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  21    0  98094/99791
C5510 002 05 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  02    0    1146/1216
C5510 002 06 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  09    0  24072/16936
C5510 002 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 002 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 01 g729br8   4.4.20 busy  idle      0  0 0/0/0:15  17    0  17763/14653
C5510 003 02 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  26    0  83512/84969
C5510 003 03 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  14    0  31082/16770
C5510 003 04 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  06    0  11081/11271
C5510 003 05 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  25    0  18097/18402
C5510 003 06 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  31    0  10675/10780
C5510 003 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 003 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 01 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  01    0    3389/3459
C5510 005 02 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  24    0    3169/1428
C5510 005 03 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  27    0  10569/10771
C5510 005 04 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  30    0      342/361
C5510 005 05 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  20    0      120/135
C5510 005 06 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  23    0    1608/1650
C5510 005 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 005 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 01 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  15    0    1204/1241
C5510 006 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 03 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  13    0  15207/15477
C5510 006 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 05 g729r8    4.4.20 busy  idle      0  0 0/0/0:15  11    0  10378/10508
C5510 006 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 006 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 007 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 008 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 009 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 010 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 011 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 012 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 013 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 014 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 015 16 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 07 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 08 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 09 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 10 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 11 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 12 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 13 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 14 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 15 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 016 16 None      4.4.20 idle  idle      0  0                 0          0/0
                           *DSP SIGNALING CHANNELS*
C5510 001 01 {flex}    4.4.20 alloc idle      0  0 0/1/0     02    0          3/0
C5510 001 02 {flex}    4.4.20 alloc idle      0  0 0/1/1     02    0          3/0
------------------------END OF FLEX VOICE CARD 0 ----------------------------
----------------------------FLEX VOICE CARD 1 ------------------------------
C5510 001 01 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 02 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 03 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 04 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 05 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 06 None      4.4.20 idle  idle      0  0                 0          0/0
C5510 001 01 {flex}    4.4.20 alloc idle      0  0 1/0/0     02    0         20/0
C5510 001 02 {flex}    4.4.20 alloc idle      0  0 1/0/1     06    0         20/0
C5510 001 03 {flex}    4.4.20 alloc idle      0  0 1/0/2     10    0         20/0
C5510 001 04 {flex}    4.4.20 alloc idle      0  0 1/0/3     14    0         20/0
C5510 001 05 {flex}    4.4.20 alloc idle      0  0 1/1/0     02    0         20/0
C5510 001 06 {flex}    4.4.20 alloc idle      0  0 1/1/1     06    0         20/0
C5510 001 07 {flex}    4.4.20 alloc idle      0  0 1/1/2     10    0         20/0
C5510 001 08 {flex}    4.4.20 alloc idle      0  0 1/1/3     14    0         20/0
------------------------END OF FLEX VOICE CARD 1 ----------------------------
  • IP Telephony
2963
