Community Member
DSP
hi there
I need help with undertanding DSP and its usage....i have tried few docmentations but still not clear when comes to troubleshooting/Design perpective..
is there any documetation that some can share that has very clear instructions...Cheers
Many Thanks
Pramoth
2 ACCEPTED SOLUTIONS
Hall of Fame Super Red
DSP
Re: DSP
NP Pramoth, as a better practice always search the forum before posting. As in this case, you could have found an excellent thread as posted by Rob (+5 ) before hand ( notice the subject was also the same ).
Finally, please do not forget to rate all helpful posts to encourage folks out here, they do exceptional job, trust me.
GP.
DSP
For design perspective & to understand which card will consume how many DSP resources on the router, please use DSP Calculator . This tool is excellent, it also helps you in figuring out which all cards can be mounted in which slot of the router motherboard.
Apart from that UC SRND Guide is also a good document. Did you already refer that ?
Let me know if you have any specific query.
GP.
Pls rate helpful posts !!
Community Member
DSP
Thanks GP for your quick response.
Re: DSP
GP.
DSP
Community Member
DSP
Hi Rob
Thanks very much , its a Great doco i will through it soonest....
by any chance have you got Volume 1 available ?
Pramoth
314
