DSPFarm 2851 / NM-HD-2V
Hi Everyone,
Quick question. I'm trying to set up cbarge on CME 8.6 running on a 2851. I see that I need dsp to accomplish this. Can I use  nm-hd-2v (has 8 dsp?) for dsps for cbarge (and then fxo/fxs? or without vic card?) or must I use a nm-hdv2 with pvdm2s?
Thank you,
Dan
Everyone's tags (6)
1 ACCEPTED SOLUTION
Re: DSPFarm 2851 / NM-HD-2V
Dan,
This gives a major clue as to whats going on:
Application : SCCP   Status : NOT ASSOCIATED
You'll need to create a loopback, then associate the dspfarm profile via SCCP so it registers. You'll need all of the following, with some modifications based upon your config:
sccp local Loopback0
sccp ccm identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
bind interface Loopback0
associate ccm 1 priority 1
associate profile 1 register CME-CONF
voice-card 1
dspfarm
dsp services dspfarm
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
associate application SCCP
telephony-service
sdspfarm tag 1 CME-CONF
no privacy
conference hardware
Remember to bring the dspfarm up with no shut.
Best,
David
Please remember to rate helpful resonses and identify correct answers.
Hall of Fame Super Gold
You don't need any NM for DSP on an ISR router. Just install PVDM2-xx directly on the motherboard.
Hi Paolo,
Thanks for the reply. I don't have any PVDM2s but I do have a NM-HD-2V without FXO/FXS that I was hoping to be able to use for cbarge conferences, but I can't seem to get it to work. Is it possible?
Dan
CME#sh dspfarm profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : DOWN
Profile Operation State : DOWN
Resource Provider : FLEX_DSPRM   Status : NONE
Number of Resource Configured : 2
Number of Resource Available : 0
Maximum conference participants : 8
Codec Configuration: num_of_codecs:6
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
CME#sh voice dsp group all
DSP groups on slot 0:
DSP groups on slot 1:
dsp 1:
  State: UP, firmware: 28.3.5
  Max signal/voice channel: 16/16
  Max credits: 240
  num_of_sig_chnls_allocated: 0
  Transcoding channels allocated: 0
  Group: FLEX_GROUP_VOICE, complexity: FLEX
    Shared credits: 240, reserved credits: 0
    Signaling channels allocated: 0
    Voice channels allocated: 0
    Credits used (rounded-up): 0
  0 DSP resource allocation failure
Hall of Fame Super Silver
Can you post "sh run"?
Hi Chris,
I reloaded the router after I was unsuccessful just to remove anything I did that may have been erroneous. I followed the post by aokanlawon in the thread below to the letter:
https://supportforums.cisco.com/thread/2011036
The only thing I did additionally was to add the cbarge softkey to the ephone template. I did get the same error in the thread above when dialing the conference # (Can not complete conference), and I tried to remove conference hardware from telephony-service as mentioned in that thread as well.
Thank you,
Dan
Dan,
sccp
sccp ccm group 1
voice-card 1
dspfarm
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 8
telephony-service
no privacy
conference hardware
Best,
David
757
