DSPFarm in NM-2V is "DOWN"
I have a 2621XM installed with NM-2V and VIC-2FXO, however, the dspfarm is always shown as "DOWN" and it doesn't allow me to use the "voice-card" command, any idea? Thanks.
Andrew
HE-VGW1#sh inventory
NAME: "2621XM chassis", DESCR: "2621XM chassis"
PID: C2621XM-2FE       , VID: 3.1, SN: XXXXXXXXXX
NAME: "C2600 4 port Voice PM", DESCR: "C2600 4 port Voice PM"
PID: NM-2V=            , VID: 1.1, SN: XXXXXXXX
NAME: "Two port FXO voice interface daughtercard", DESCR: "Two port FXO voice in
PID: VIC-2FXO=         , VID: 1.1, SN: XXXXXXXX
HE-VGW1#
HE-VGW1#
HE-VGW1#
HE-VGW1#
HE-VGW1#sh dspfar
HE-VGW1#sh dspfarm
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
HE-VGW1#
HE-VGW1#
HE-VGW1#
HE-VGW1#
HE-VGW1#
HE-VGW1#config t
Enter configuration commands, one per line.  End with CNTL/Z.
HE-VGW1(config)#voice-card 0
% Invalid input detected at '^' marker.
HE-VGW1(config)#
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
Re: DSPFarm in NM-2V is "DOWN"
No, they can't.
Use current hardware for that.
Bronze
I think your using the wrong commands.To access a FXO port you need to use the voice-port command.If you do a sh run you should see them, something like
voice-port 0/0/0 or similiar.
cheers
Mark
I don't see any DSPs listed in the inventory, you need DSPs for voice termination or to configure DSPfarms
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
DSPs are present on the NM-2V, I wonder if they can be used as media resources (hardware conference bridge) for CUCM?
Andrew
HE-VGW1#sh voice dsp
DSP  DSP                DSPWARE CURR  BOOT                         PAK     TX/RX
TYPE NUM CH CODEC       VERSION STATE STATE   RST AI VOICEPORT TS ABORT  PACK COUNT
C542 001 01 None         4.4.29 IDLE  idle      0  0 1/0/0     NA     0    3822/4161
C542 002 01 None         4.4.29 IDLE  idle      0  0 1/0/1     NA     0      594/591
No, they can't.
1031
