DSPFarm SCCP Controlled Gateway
Ken Douglas
Hello:
OK... this is kind of a newbie question.  I've not done this before... but we had a 3845 with IOS 12.4(24)T2 that was on the network but not being used for any voice traffic (Communications Manager doesn't know about it).  It was under utilized and we added some DSPs.  We've configured the DSPFarm and have defined a profile for transcoding services.
voice-card 0
dspfarm
dsp services dspfarm
sccp local Loopback10
sccp ccm 192.168.30.2 identifier 1 priority 1 version 6.0
sccp ccm 192.168.78.2 identifier 2 priority 2 version 6.0
sccp ccm 192.168.30.1 identifier 3 priority 3 version 6.0
sccp ip precedence 3
sccp
sccp ccm group 1
bind interface Loopback10
associate ccm 1 priority 1
associate ccm 2 priority 2
associate ccm 3 priority 3
associate profile 20 register WTC-XCODE-CRT12
dspfarm profile 20 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
We configured Communications Manager 6.1(2) with the same profile name (WTC-XCODE-CRT12) and have been through the configuration documents several times.  When we perform a show dspfarm all  we get:
Dspfarm Profile Configuration
Profile ID = 20, Service = TRANSCODING, Resource ID = 1
Profile Description :
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP   Status : NOT ASSOCIATED
Resource Provider : FLEX_DSPRM   Status : UP
Number of Resource Configured : 10
Number of Resource Available : 10
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
SLOT DSP VERSION  STATUS CHNL USE   TYPE    RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0    1   24.3.2   UP     N/A  FREE  xcode  1      -         -         -
0    2   24.3.2   UP     N/A  FREE  xcode  1      -         -         -
Total number of DSPFARM DSP channel(s) 10
And Communications Manager shows the status as "Unknown" and the IP address as "Unknown."
The one thing we've not done is defined this 3845 as any kind of gateway to Communications Manager.  Is that required?  If so, can we define it as an SCCP controlled gateway and if we do that is there any way to use the loopback interface.  This 3845 is dual connected for redundancy and it seems like a limitation to have to choose ONE of the two Ethernet interfaces for binding interface.
Thanks!
2 Accepted Solutions
Have you reset the SCCP?
Gateway# no sccp
Gateway# sccp
MK
Hi Ken,
No.
Configuration seems to be fine. Check if SCCP is UP, you can check with show sccp commands. Also, you can follow mightyking's suggestion.
Check if the CUCM can be reached from Loopback's interface.
Best regards,
-- Adrián.
5 Replies 5
Rob Huffman
Hi Ken,
Is this the doc you are using??
CallManager and IOS Gateway DSP Farm Configuration Example
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080334294.shtml
It does show the required steps for CUCM as well.
Hope this helps!
Rob
Gateway# no sccp
Gateway# sccp
MK
Hi Ken,
No.
Best regards,
-- Adrián.
Ken Douglas
And the right answer was.... Reset SCCP.    Thanks mightyking!  I would not have guess that a simple "no sccp, sccp" would have forced the association. Obviously I need to understand the association mechanism better.  I assumed the SCCP would use the same polling parameters regardless of what type of application (phone, gateway, etc.) was in use.  I thought that this 3845 would poll every x minutes (what ever the polling interval is) and discover the Communications Manager.
Thanks for the help.
Ken,
Glad to see your xcoding is working!.
-- Adrián.
