dspfarm
Humm.. I still need help...
Trying to configure the Moh .... I just can hear a bip bip ....
I already configured as configuration guide showed...
What's wrong ?
Thanks.
#sh run | begin scc
sccp local GigabitEthernet0/0
sccp ccm 10.2.41.22 identifier 1
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate profile 1 register mtp002333b11be0
associate profile 3 register jcbcnf
associate profile 2 register jcbxcd
keepalive retries 5
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 5
associate application SCCP
dspfarm profile 3 conference
codec g711ulaw
codec g711alaw
R_JCB_22#show dspfarm all
Dspfarm Profile Configuration
Profile ID = 2, Service = TRANSCODING, Resource ID = 2
Profile Description :
Profile Admin State : UP
Profile Operation State : RESOURCE ALLOCATED
Application : SCCP Status : ASSOCIATION IN PROGRESS
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 5
Number of Resource Available : 5
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
Profile ID = 3, Service = CONFERENCING, Resource ID = 3
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Number of Resource Configured : 4
Number of Resource Available : 4
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Profile ID = 1, Service = MTP, Resource ID = 1
Hardware Configured Resources : 5
Hardware Available Resources : 5
Software Resources : 0
Codec Configuration
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
1 1 1.1.1 UP N/A FREE mtp 1 - - -
1 1 1.1.1 UP N/A FREE xcode 2 - - -
1 2 8.4.7 UP N/A FREE xcode 2 - - -
1 3 1.1.1 UP N/A FREE conf 3 - - -
1 4 1.1.1 UP N/A FREE conf 3 - - -
Total number of DSPFARM DSP channel(s) 14
1 REPLY
Re: dspfarm
and exactly what are you trying to do?????????
if it's multicast MOH i don't see anywhere that config
i only see CFB and XCODER in there
also what you're mentioning is caused because the phone has no access to the MOH server thru the MRGL, not because of a config on the router.
you don't even mention if this is CUCM or CME so i'm going to assume it's CUCM
java
if this helps, please rate
java
www.cisco.com/go/pdi
411
