Community Member
DSPs (PVDMs) vs. Memory
      I work on a large voip conversion project and a lot of terms get mixed up (DSPs vs Memory) and people get confused.  I was wondering if there was a good way to explain what the difference is between DSPs and Memory on a router connected to the PSTN which terminate PRIs.  The routers also have a Conference Profile built, and are the SRST routers.
I have a couple of questions.  We had a 3945e router, and it was maxed out with PVDMs on all the slots (NM-HDV modules).  We were having dropped calls during peak hours after we converted the site to Cisco VoIP.  Now the router was configured to use each slot as a dspfarm
voice-card 0
dsp services dspfarm
voice-card 1
voice-card 2
voice-card 3
Then the only dspfarm profile that was built was:
dspfarm profile 10 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
max sessions 20
associate application SCCP
The SRST was built like this below.  When SRST is active, is it using DSPs or memory when all the phones register?
call-manager-fallback
max-conferences 8 gain -6
transfer-system full-consult
limit-dn 7962 1
timeouts interdigit 5
ip source-address 10.70.131.7 port 2000
ip qos dscp af31 signal
max-ephones 1500
system message primary SRST-Limited Functionality
transfer-pattern .......
voicemail 18553186245
no huntstop
translation-profile incoming intrasite
SampleAudioSource.ulaw.wav
multicast moh 239.192.166.65 port 16384 route 10.70.131.7
When calls dropped they removed the "dsp services dspfarm" from voice-card 1, voice-card 2, and voice-card 3, while also making some other adjustments and rebooting the router.
We also we getting errors when we tried to add dial-peers because the memory was full.
My question is, would the dropped calls be more of a result from all the voice-cards being configured as dspfarms, or the lack of physical memory?  Can you use the DSPs on the voice-cards for other reasons besides local conferencing and transcoding when configured that way?  Meaning, does the router reserve them only for conferencing and transcoding or can they be used to bring up a new 4 port PRI module that is inserted, things like that?
And if any could explain the main differences between DSPs and physicl memory in regards to the perfomance of Voice Routers (routers that termiante PSTN circuits).
Thank you.
Have you checked out
http://www.cisco.com/en/US/docs/routers/access/1900/software/configuration/guide/pvdm3_config.html
Goes over the PVDM3 modules which you should be using in the ISR G2 Router.
Unless your using PVDM2 with the adapter.
Can you do a show inventory?
296
