DST 1.02 update for 4.0(2a) to 4.2(1) ?
Anyone seen this update ? I am not finding this on cisco download page or in the CCM DST field notices and am seeing it on a system that called in problems.
03/09/2007 19:16:53 Cisco Unified CallManager 4.0(2a), 4.1(2), 4.1(3), 4.2(1) 2007-DST-Update.1-0-2 Installed with 0 errors
Green
Re: DST 1.02 update for 4.0(2a) to 4.2(1) ?
Im not able to find that either.
From history.log u get that line?
OS 2000.2-7sr6 and CCM 4.0(2a)sr2a
Single server cluster
Yes, that line is from the history.log on the server.
I searched the customers HD for it and can't find the .exe , but did find the uninstaller exe file which has a similar filename and did find a install log that looks like other cisco install logs and is same folder as other cisco install logs.
But I am also not seeing the OS DST patches in the history.log either, and so far have not been able to get hold of the customer since they reported the ticket to find out what they exactly did or such either. I'm thinking they did some thing manually because the server has the right time and DST checkbox is still checked.
Green
Which is the current CCM version installed?
Cisco Systems IP Telephony Application Server History Log
OS Image Code: "MCS7825H02"
Base OS version: "2000.2.7"
History
________
03/30/2005 23:22:25 Original Installation of OS "2000.2.7"
03/31/2005 11:07:47 2000.2.7sr2
03/31/2005 13:37:14 SQL2K MS03-031
03/31/2005 15:15:43 Cisco CallManager 4.0(2a)DevPack02 Installed
03/31/2005 15:15:50 Cisco CallManager 4.0 DevPack26 Installed
03/31/2005 15:18:49 Cisco CallManager 4.0(2a)sr1 Installed
03/31/2005 16:20:12 Cisco BARS 4.0.6000
03/31/2005 17:26:21 OS Hotfix for CallManager4.x co-resident with Cisco CRA 3.5(x)
03/31/2005 17:40:10 CiscoCM-CSA-4.0.3.728-1.1.9
08/03/2005 17:24:04 2000.2.7sr6
03/09/2007 19:19:10 Cisco Unified CallManager 4.0(2a), 4.1(2), 4.1(3), 4.2(1) 2007-DST-Update.1-0-2 Installed with 0 errors
The only thing I can find , is a file in the C:\esbackout folder called
uninstCisco Unified CallManager 4.0(2a), 4.1(2), 4.1(3), 4.2(1)2007-DST-Update.1-0-2.exe
Community Member
Eber
If they are running 4.0(2) there was no update, only a manual workaround from all I have read/seen through the cisco page and outside forums.
Unless you are talking about
ciscocm.4-0-2a-2007-DST-Update.1-0-1.exe
Which is the CallManager Database Table update:
FYI,
The "Ciscocm-4-02a-2007-DST-Update.1-0-1.exe" they applied turns out to be Cisco Unified CallManager 4.0(2a) , 4.1(2), 4.1(3), 4.2(1) 2007-DST-Update.1-0-2." after installed.
Community Member
So is the database patch Ciscocm-4-02a-2007-DST-Update.1-0-1.exe not working correctly?
It is, but they initially had issues and I coudln't find this patch they applied where name covered multiple versions and was version 1-0-2.
150
