DST issue with 7940/7960 on CUCM 8.6.2
Hi Guys,
In the last 19 October, in any city of Brazil started of date summer time (DST), and the IP Phone models 7940/7960 not changed the time automatically. After restart physical or logical the IP Phone stay the correct time.
7940
Firmware de aplicação  P00308010200
Firmware de inicialização  PC0303010200
Versão  8.1(2.0)
I read any posts in this forum, but, not is clear for me if this problem is related any bug or no. Any have idea about this?
Thank You,
Wilson
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Hi Wilson,
It could be related to the 7940/60 firmware but sadly the 8.1.2
is the latest and last firmware available for these models as they
are EoL
I would do one or all of these;
- open a TAC case
- upgrade to latest CUCM 8.6 SR
- install the 2013 DST/TZ
Cheers!
Rob
"Why do the best things always disappear "
- The Band
Hi Wilson,
There are a number of DST bugs that affect CUCM 8.6. I would have a look
at the attached bugs . Did you install any of the DST/TZ Timezone updates for CUCM?
Cisco Unified Communications Manager / Cisco Unity Connection
Timezone Update 2013d
Release Notes Version 1
September 19, 2013
Introduction:
These release notes contain important information about installation procedures for the 8.6(2x) Timezone
Update for Cisco Unified Communications Manager or Cisco Unity Connection.
Note
Before you install this Timezone Update, Cisco recommends that you review the
Important Notes section for information about issues that may affect your system.
Updates in This Release
DST updates are cumulative, so installing this patch will provide all of the fixes in the New Updates section plus all of the
fixes in the Previous Updates section
New Updates
CSCui46884
DST/TZ data update with 2013d
Previous Updates
CSCue96910
DST/TZ data update with 2013b
CSCue06553
DST/TZ data update with 2012j
CSCtz20987
DST: Update CM to Olson TZ version 2012c
CSCtn29406
DST: Update CM to Olson TZ version 2011h
CSCtk55066
DST: Update CM for Olson TZ ver 2010o
CSCtj75860
Inconsistent changeover
for DST spring and fall in US, Canada
CSCtg50448
DST: Update CM for Olson TZ ver 2010i
Known Caveats
CSCuj30440
Renaming DST
cop file in logs
CSCuj26553
69xx phones will not display correct time for Chile/Santiago Timezone
CSCue81856
dst
updater.2012j DST cop file does not match Gaza in timeanddate.com
From
http://www.cisco.com/web/software/282074298/106084/dst-862-2013d-cop-readme.pdf
Cheers!
Rob
- The Band
Hi Rob,
Thanks for your contact. The timezone current is 2012j and it putted in march (previously 2012c), because, the IP Phone 7911 statyed 1 hour ahead after finish the DST in GMT-3 America/São Paulo. When we had the problem, putted the version 2012j and solved the problem, but, in this version not is informed that should to affect the model specific. The IP Phone 7940/7960 are many old and my suspect is about firmware version. Am I sure in my affirmation?
I read the 03 last updates about DST and nothing each speak about Brasil GMT-3 America/Sao Paulo
admin:show timezone config
Current timezone: Brasilia Summer Time (America/Sao_Paulo)
Timezone version: 2012j
Thanks a lot,
Wilson
Hi Wilson,
are EoL
- open a TAC case
Cheers!
Rob
- The Band
Hi Rob,
I will verify with my Customer if want simulate this environment in the lab. I will follow your recommendation, first, install the 2013 DST/TZ, if dont solve, upgrade the latest CUCM 8.6 SR. In this moment open a TAC case not is recommendated, because, We don´t have problem, why the IP Phone stay the correct time after restart.
Thanks a Lot,
Wilson
395
