DST issues in CM 6.1.2
I upgraded to Call Manager 6.1.2 from 4.3 back in August. I had assumed that with the upgrade I would no longer have to deal w/ DST issues, but w/ the DST change this past weekend all of my phones are 1 hour fast. Does CM 6.1.2 have DST issues? If so is there a patch or do I need to change the time in the server.
  • IP Telephony
Re: DST issues in CM 6.1.2
Yes you do.
CSCsy25150 - CUCM is not sending Daylight Saving Time updates
The versions below (and higher) have the fix:
5.x - 5. 1.3.7000.1 , 5.13.6104.1
6.1.x - 6.1.3.3000.1 , 6.1.3.2190.5, 6.1.3.2104.1, 6.1.2.1139.1,
6.1.3.3190.1, 6.0.x - 6.0.1.3119.1
7.0.x - 7.0.2.11004.2, 7.0.1.21022.2, 7.0.1.11002.1, 7.0.2.20000.2
You can download the different patches from the following link:
http://tools.cisco.com/support/downloads/go/Redirect.x?mdfid=278875240
I have the same issue and I have version 6.1.2.1000-13. I don't see that specific version in the link or a higher 6.12 version. What am I missing on how to find these?
Hall of Fame Super Red
Hi Brian,
You are not losing it here. I don't see any 6.1(2) fixed-in versions either. I would open a case with TAC to see what is available for 6.1(2). Also have a look at this excellent doc from Wes Sisk @ Cisco, it doesn't look good :(
https://supportforums.cisco.com/docs/DOC-6199
Hope this helps!
Rob
"May your heart always be joyful And may your song always be sung May you stay forever young " - Dylan
The link to the bug id CSCsy33379 on the page you linked seems to indicate fixed in 6.1(2.1139.1) so I guess I will just try a TAC case as suggested.
151
