06-03-2012 03:47 PM - edited 03-16-2019 11:28 AM
ITSP--------CCME----------CUE
dial-peer confg:
dial-peer voice 10 voip
incoming called number.
dtmf relay rtp-nte
codec g711u
dial-peer voice 11 voip
destination-pattern 444
description to CUE AA
session target ipv4: XXXX
dtmf-relay sip-notify
The issue is this..
When ITSP sends invite with SDP, it advertises it dtmf attribute however when CCME sends a 200 OK it doesnt send any dtmf attribute....Hence the ITSP does not send an ACK...and the call fails
What could be causing this?
Please rate useful posts
06-03-2012 05:58 PM
SIP-SIP CUBE doesn't support translation between RFC2833 and SIP NOTIFY DTMF relay methods. It can translate as follow:
SIP NOTIFY - SIP NOTIFY
RFC2833 - RFC2833
Not mixtures are supported.
06-04-2012 01:17 AM
Mohammed,
Excellent! I guess this is where the issue is. So does that suggest you cannt call CUE AA directly over the sip trunk?
What can be done then? Call an extension on CME and do a cfwdall to CUE AA?
06-04-2012 01:45 AM
Hi, no you can use it. Cooridnate with your ITSP to use SIP NOTIFY instead of RFC2833.
06-04-2012 01:49 AM
Wao! The ITSP is not su easy to deal with. So there is no work around for this?
06-04-2012 01:59 AM
although I don't recommend but try to insert the header in 200 OK response (supported if you are using 12.4T(15) or later). Here is the config.
voice class sip-profiles 1
response 200 sdp-header Attribute add "rtpmap:97 telephone-event/8000"
response 200 sdp-header Attribute add "fmtp:97 0-15"
voice-class sip profiles 1
Please test and share your debugs.
06-04-2012 02:53 AM
Ok will update you..Many thanks
06-05-2012 03:30 AM
Mohammed,
I am yet to implement this. The user is actually here on the forum and I havent heard back from him..
I just want to ask another question...is there a way to make CME send 183 session progress with SDP to the ITSP
I am asking eacuse I am looking at an issue where inbound calls from ITSP does not get ringback. Even though CCME is sending 180 ringing. I understand that this implies that the ITSP should generate its own ringback but this doesnt seem to be happening. The ITSP wants a 180 with SDP (which CCM|E cant do) or 183 with SDP and then hear ringback from CCME..
Can this be done..
"I am complete in God, God completes me"
06-05-2012 04:32 AM
In face CME-SIP-Trunk, by default, generate 180 response with SDP. This can be disabled using the commands.
sip-ua
disable-early-media 180
Therefore, check if you disabled early media. Else, SDP should be included. You may share your debugs as well.
CME-SIP-Trunk doesn't generate 183 response.
SIP PSTN Gateway generate 183 response when it receives Progress IE from PSTN to perform voice cut-through.
06-05-2012 05:17 AM
Thank you for your response.
The challenge here is the this CME does snot generate a 180 with SDP even with earl-media enabled. I understand that early media does not affect inbound calls..could that be true..
Attached is the debug..
If you have a few minutes here is the thread with this issue I have been looking at..
https://supportforums.cisco.com/message/3652288#3652288
