DTMF between SIP and GW problem
Hello, I have CUCM 8.6 connecting via a SIP trunk to a 2801 gateway router and then out to the PSTN via an ITSP SIP proxy.
The calls are find but DTMF is not working. I am using SCCP 7940 phones.
I have tried adding "dtmf-relay h245-alphanumeric" to my gateway dial peers.
I have tried adding "voice-class sip dtmf-relay force rtp-nte" to my gateway dial peers.
I have tried choosing both of the options under "Required Field" within CUCM trunk configuration.
I have tried selecting the "Media Termination Point Required" option within the CUCM Trunk configuration.
I tried selecting "Early Offer support for voice and video calls (insert MTP if needed)" within the SIP profile for the trunk.
No luck.
Can someone please tell me what I should try next ?
Thanks kindly.
  • IP Telephony
1 REPLY
Have you tried configuring rtp-nte on the outbound dial peer ot CUCM and checking the MTP required option on the CUCM SIP Trunk at the same time?
1.    enable
2.    configure terminal
3.    dial-peer voice number voip
4.    session protocol sipv2
5.    dtmf-relay rtp-nte
6.    rtp payload-type nte number comfort-noise [13 | 19]
7.    exit
Regards.
158
