DTMF digits in SDL log
Hello everyone
I have a question regarding the SDL trace log, I am having difficulty reading the DTMF digits dialed by outside callers, especailly in a call center environment, the call is connected, the diigts caller entered to navagate the menu is impport for one of my production problems, the trace level is details, however, I still couldn't find the digits caller dialed, can someone help on this one?
thanks
VIP Super Bronze
Re: DTMF digits in SDL log
Start by reading the SDI traces instead of SDL. After that it will depend what protocol the gateway is using.
Please remember to rate helpful responses and identify helpful or
I did the same thing for SDI and couldn't find anything, that's why I moved to SD
L and found it contains more info related to DTMF, however still can't find what I am
looking for.
Can you please be more specific, if you need a SDI/SDL trace, I could attach a copy, I am wondering if I missed out something
thanks
Super Bronze
I would say that reading the SDI or SDL may be a little tricky; if you use triplecombo to parse the SDI logs it would be simple for an SCCP device but whether or not you see the DTMF from a gateway is another matter.
I would start by looking at the tools and debugging available in your Call Center software if it's a matter of seeing what DTMF was sent. It's fairly key to the functionality of that software, so it should have a reasonable log of it.
I would look at the CCM logs if it was a matter of troubleshooting DTMF if it's not being received.
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
thanks for the reply
The problem is we have DTMF tone missing issue from time to time
we have  went through our call center which is ICM/IPIVR logs already, we found call center system didn't receive any info on the missing DTMF digits, that's why we have to move to CM for further troubleshooting.
Where I can find the tool you mentioned to read SDL logs?
thanks
found the tool already,thanks
523
