Community Member
DTMF Digits not be sent through SIP
Hello all,
I have customer running Call Manager Express.  We just brought up the SIP trunk to the telco and all inbound and outbound calls work just fine.
However, once a call is connected the DTMF digits are not being sent.  So if they call a number that has a menu they cannot press any of the options in the menu.
Here is the Dial Peers i am using.
Am i missing something? is there something that needs to change with the carrier?
thanks for any help
Ken
dial-peer voice 100 voip
description PSTN
translation-profile outgoing SIP-OUT
destination-pattern 9.T
progress_ind setup enable 3
session protocol sipv2
session target ipv4:208.53.0.5
incoming called-number 0297
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs5 signaling
no vad
dial-peer voice 1000 voip
description **Incoming Call from SIP Trunk**
service session
destination-pattern 0297
session target ipv4:192.168.130.253
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 200 voip
description PSTN to *****
incoming called-number 0787
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2000 voip
service session
destination-pattern 0787
dtmf-relay rtp-nte
codec g711ulaw
no vad
Everyone's tags (3)
Re: DTMF Digits not be sent through SIP
   Undoubtedly this is due to the lack of using an MTP for anything going over the SIP Trunk.  I don't have any relevent CME config next to me, however using and MTP and registering it to you CME is going to be imperative to get DTMF to work over a SIP Trunk.
I am confident if you get MTP working on you SIP Trunk calls, you will be aok.
HTH,
Chad
Community Member
hi Chad,
thanks for the response.  aren't the MTP only needed when connecting to regular call manager?
I have done a few call manager expresses with SIP before and never had to create a MTP for the dtmf to work.
the dtmf tones work with their voicemail system (a non cisco system)  just not with the SIP
Is this something new in the ios?
thanks for any help
Ken
Community Member
Hey guys,
  I worked with the Telco and they are not seeing any digits when i press them.
Here is the message i get in the debug when i press a digit.  Have you guys seen this before?  it looks like its trying to start a conference call?
*Feb  3 16:46:38.409: //2023/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x7E9
*Feb  3 16:46:38.409: //2023/xxxxxxxxxxxx/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
*Feb  3 16:46:38.409: //2023/xxxxxxxxxxxx/CCAPI/cc_api_call_digit_end:
attached is the full debug
thanks for any insight!
   Once again, you may not have needed an MTP before, however in my expereinces this can really only be one of 2 things.  dtmf-relay configuration, which i see is set to rtp-nte, are you sure its not sip-notify with this carrier?  worth checking.  If its not this, I highly suggest trying some MTP's you can even just use software session directly on the router without needing a PVDM.
Chad
Community Member
hi Chad,
can you give me a config to use?
also, i did check with the telco.  they are using that form of relay and they watched the trunk and do not see the digits being sent at all,
on the cisco debug it looks like the system is trying a conference call.
thanks!
Ken
something like this should do
voice-card 1
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sccp local GigabitEthernet0/0
sccp ccm 9.13.29.30 identifier 1 version 4.0 -- Use your own IP address
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register MTP123456
keepalive retries 1
keepalive timeout 10
switchover method immediate
switchback method immediate
dspfarm profile 1 mtp
description MTP123456
codec g711ulaw
codec g729r8
maximum sessions software 400
associate application SCCP
telephony-service
max-ephones 1
max-dn 1
ip source-address 9.13.29.30 port 2000 --> Use your own IP address
sdspfarm units 1
sdspfarm mtp sessions 10
sdspfarm tag 1 MTP1234356
Community Member
Hi Chad,
I addeed the MTP but still no luck :/
there seems to be some progress, before i added the MTP's i added a command to the dial-peer to force the dtmf
and now if i call the TAC guy at cisco, the DTMF digits seem to work however if i call other numbers and try their menus it still does not work.
any other options to try?
thanks!
Community Member
Any resolution to this yet?  I'm running into this problem using ATAs (SCCP) and already have MTP configured as well.
Thanks.
Community Member
It ended up being an issue with the SIP Telco carrier.   they made some changes and all began to work.
which ata version are you using? is it the old 186/188 or the new slim looking 187 that just came out.
Community Member
Thanks for the quick reply!
ATA 186 running v3.1.0. Do you know the change the Telco made?
I've tried upgrading it to the latest firmware, but for whatever reason I can't get it upgraded via TFTP.
Community Member
they made a change to the way the call was being routed outside their system.  for some reason when they passed the SIP call from us to a normal PRI at their location the DTMF would not pass through.  So they change the calls to stay SIP out of their location.  once they did that, it all worked fine
here is a link from cisco that shows how to manually upgrade those things as well
http://www.cisco.com/en/US/docs/voice_ip_comm/cata/186_188/2_15_ms/english/administration/guide/sccp/sccpaapc.html
6825
