DTMF H323 to SIP Problem
I have a CUBE (3945 Vers. 15.1) H323 trunking with CUCM 8.5 working fine, I'm trying to redirect the call received from H323 to the Sip Trunk service provider, calls are completed but dtmf isn't working, after look some logs I realized dtmf from H323 are received but are not redirect to the Sip Trunk.
dial-peer voice 101 voip
translation-profile outgoing SIP-Trunk
destination-pattern 4901..........
session protocol sipv2
session target ipv4:x.x.x.x
voice-class codec 2
voice-class sip profiles 1
dtmf-relay rtp-nte
voice class codec 2
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
codec preference 4 g729r8
oice class sip-profiles 1
request INVITE sip-header P-Asserted-Identity modify "<sip:(.*)@(.*)>" "<sip:1234@xxxxx.com.do;user=phone>"
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
Below some debugs:
debug h245 asn1
*Jul 13 18:29:23.071: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 4
*Jul 13 18:29:23.071: H245 MSC INCOMING ENCODE BUFFER::= 6D400139
*Jul 13 18:29:23.071: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= indication : userInput : alphanumeric : "9"
*Jul 13 18:29:23.071: h245_decode_one_pdu: H245ASNDecodePdu rc = 0, bytesLeftToDecode = 0
*Jul 13 18:29:23.071: h245_decode_one_pdu: Read Pkt body: more_pdus:0 rc:0 asn_rc:0
*Jul 13 18:29:26.903: h245_decode_one_pdu: more_pdus = 0, bytesLeftToDecode = 5
*Jul 13 18:29:26.903: H245 MSC INCOMING ENCODE BUFFER::= 0400000000
*Jul 13 18:29:26.903: H245 MSC INCOMING PDU ::=
value MultimediaSystemControlMessage ::= request : closeLogicalChannel :
      forwardLogicalChannelNumber 1
      source user : NULL
debug voip rtp session named-event
debug voip rtp session dtmf-relay
"no output"
Please remember to rate useful posts clicking on the stars below. Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo. ___________________________________________ LinkedIn Profile: do.linkedin.com/in/leosalcie
1 REPLY
resolution
1. configured DTMF Relay Digit-Drop on a Cisco Unified Border Element
//inbound from CUCM h323 dial-peer
!#NEW CONFIG
dial-peer voice 11 voip
dtmf-relay h245-alphanumeric
//outbound to ITSP SIP dial-peer
!#NEW CONFIG
dtmf-relay rtp-nte digit-drop
H.323-to-SIP Connections on a Cisco Unified Border Element
http://www.cisco.com/en/US/docs/ios/voice/cube/configuration/guide/vb-gw-h323sip.html
516
