Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
DTMF issue ---call from PSTN
I have an issue about DTMF.  I have call manager 7 and unity connection 7, one of my H323 voice gateway using FXO port to connect a GSM module.
When call coming from FXO port, the call will divert to an IVR which configure on UC. People can hear greeting however when they Press option unity can't recieved DTMF tone.
On gateway I can see below debug:
*Sep 15 03:06:01.089: htsp_digit_ready(4): digit = 5
*Sep 15 03:06:04.009: htsp_digit_ready(4): digit = 2
*Sep 15 03:06:04.729: htsp_digit_ready(4): digit = 2
*Sep 15 03:06:05.509: htsp_digit_ready(4): digit = 3
*Sep 15 03:06:06.181: htsp_digit_ready(4): digit = 1
on Connection Remote port status Monitor:
02:38:51, New Call, CalledId=7771,  RedirectingId=7771,  Origin=16,  Reason=8,  CallGuid=89FA38373CDD47BD9C28C6DECA6BD3F5,  CallerName=,  LastRedirectingId=7771,  LastRedirectingReason=8,  PortDisplayName=PhoneSystem-1-013,[Origin=Invalid],[Reason=Invalid]
02:38:51, AttemptForward
02:38:51, State - AttemptForward.cde!Dummy
02:38:51, Event is [NULL]
02:38:51, PHTransfer
02:38:51, State - PHTransfer.cde!LoadInfo
02:38:51, Event is [TrueEvent]
02:38:51, PHGreeting
02:38:51, State - PHGreeting.cde!PlayGreeting
02:38:54, Call answered if needed
02:38:55, Playing greeting for Call Handler:  BOSS-IVR-09-2010
02:39:10, No DTMF received
02:39:10, Event is [NULL]
02:39:11, PHTransfer
02:39:11, State - PHTransfer.cde!LoadInfo
02:39:11, Answer Phone if needed
02:39:11, Event is [FalseEvent]
02:39:11, State - PHTransfer.cde!CheckPlayTransferIntro
02:39:11, State - PHTransfer.cde!XferCall
02:39:40, Event is [TransferFailed]
02:39:40, State - PHTransfer.cde!LeaveMsg
02:39:40, Event is [NULL]
02:39:40, Idle
my gateway configuration is
voice-port 4
supervisory disconnect dualtone mid-call
no battery-reversal
input gain 14
timeouts wait-release 1
connection plar opx 7771
description 09175709870
dial-peer voice 2201 voip
destination-pattern 77..
session target ipv4:192.168.50.5
dtmf-relay h245-alphanumeric
no vad
1 ACCEPTED SOLUTION
Re: DTMF issue ---call from PSTN
Hi there,
I noticed that you have bumped up gain to a very high value on the incoming port:
voice-port 4
no battery-reversal
input gain 14  <-----!!!!
Any particular reason for setting it so high ? Even for  low incoming volume, its set too high
where it can not only distort dtmf but also introduce audio issues such as echo.
I suspect this is distorting the DTMF and its coming in too "hot' now...
Can u set it to default and test?
voice-port X
shut
default input gain
no shut
DK
Bronze
Hello Victor,
On your outbound dial-peer  can you add 'dtmf-relay h245-signal h245-alphanumeric'  instead of 'dtmf-relay h245-alphanumeric'. And see if that helps.
Thank you jaschulz,
It looks like no change here, I wonder if relate to some timer setting on VG or CM.
GV:
no vad
Connection remote port status monitor:
09:28:11, New Call, CalledId=7771,  RedirectingId=7771,  Origin=16,  Reason=8,  CallGuid=27166B997D584E1FA4A77C227401BE39,  CallerName=,  LastRedirectingId=7771,  LastRedirectingReason=8,  PortDisplayName=PhoneSystem-1-021,[Origin=Invalid],[Reason=Invalid]
09:28:11, AttemptForward
09:28:11, State - AttemptForward.cde!Dummy
09:28:11, Event is [NULL]
09:28:11, PHTransfer
09:28:11, State - PHTransfer.cde!LoadInfo
09:28:11, Event is [TrueEvent]
09:28:11, PHGreeting
09:28:11, State - PHGreeting.cde!PlayGreeting
09:28:14, Call answered if needed
09:28:15, Playing greeting for Call Handler:  BOSS-IVR-09-2010
09:28:30, No DTMF received
09:28:30, Event is [NULL]
09:28:30, PHTransfer
09:28:30, State - PHTransfer.cde!LoadInfo
09:28:30, Answer Phone if needed
09:28:30, Event is [FalseEvent]
09:28:30, State - PHTransfer.cde!CheckPlayTransferIntro
09:28:30, State - PHTransfer.cde!XferCall
09:29:00, Event is [TransferFailed]
09:29:00, State - PHTransfer.cde!LeaveMsg
09:29:00, Event is [NULL]
09:29:00, Idle
Hi there,
voice-port 4
no battery-reversal
voice-port X
shut
default input gain
no shut
DK
Hi Dilip,
your are correct, I change input gain to adjust volume before,the Gateway is in Philippin and our call manger & unity connection is in Australia office.
After set it to default,now I can recieved DTMFas below...however call can't divert to internal extension for some reason. If people in Philippin dial 7771 from deskphone which reigstered to call manager in Australia, call can divert without any problem, however if call make from outside go through FXO port...it can't divert to.
any ideal about that?
thanks
02:29:32, New Call, CalledId=7771,  RedirectingId=7771,  Origin=16,  Reason=8,  CallGuid=CFEDE115E9DD42D4BED8D2896FEBA2C3,  CallerName=,  LastRedirectingId=7771,  LastRedirectingReason=8,  PortDisplayName=PhoneSystem-1-010,[Origin=Invalid],[Reason=Invalid]
02:29:32, AttemptForward
02:29:32, State - AttemptForward.cde!Dummy
02:29:32, Event is [NULL]
02:29:32, PHTransfer
02:29:32, State - PHTransfer.cde!LoadInfo
02:29:32, Event is [TrueEvent]
02:29:32, PHGreeting
02:29:32, State - PHGreeting.cde!PlayGreeting
02:29:35, Call answered if needed
02:29:35, Playing greeting for Call Handler:  BOSS-IVR-09-2010
02:29:40, DTMF received [1]
02:29:40, Event is [AlternateContactNumber]
02:29:40, State - PHGreeting.cde!PlayTransferPrompt
02:29:42, Event is [NULL]
02:29:42, State - PHGreeting.cde!TransferToACN
02:30:12, Event is [FalseEvent]
02:30:12, State - PHGreeting.cde!PlayUnableToDial
02:30:12, Event is [HangupEvent]
02:30:12, Idle
866
