11-12-2014 06:01 PM - edited 03-17-2019 12:54 AM
Hi All,
I have an issue here. The DTMF is not recognized by the Unity when user wants to do remote login to voicemail box by pressing *
Call Flow : T1 --> AS5400 --> SIP Trunk --> CUCM 9.1.2 --> SCCP --> CUC 9.1.2
Time : Nov 12 20:06:56.417 UTC
Calling Party Number i = 0x1183, '914466553077'
Called Party Number i = 0xA1, '2067677' - 99992067677
I can see in CCAPI, * being pressed and NOTIFY message is sent to CUCM, and I get 403 Forbidden as response.
The dial-peer configuration point to CUCM is below
dial-peer voice 4320 voip
tone ringback alert-no-PI
description --- PSTN to XXX 9999.XXXXXXX ---
preference 1
destination-pattern 9999.......$
no modem passthrough
session protocol sipv2
session target ipv4:XXXXX
voice-class codec 1
voice-class sip early-offer forced
voice-class sip options-keepalive
dtmf-relay sip-notify rtp-nte
fax rate 7200
ip qos dscp cs3 signaling
no vad
Logs are attached. Please help me to find out the issue.
12-10-2014 01:08 PM
So that fixes the internal dialing out DTMF issue:
The Main AutoAttendant to the 2523170388 is still functioning
But changing that incoming called-number 9T , broke the original issue that we just fixed.
Calling 9102857722 no longer accepts DTMF inputs now haha
Just to double check...I have:
dial-peer voice 15 voip
description Incoming Calls To CUCM Subscriber
preference 1
destination-pattern [2-9].........
voice-class codec 9999
session target ipv4:10.1.1.11
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 110 voip
description LD SIP Calls
translation-profile outgoing Outgoing_LD_SIP
destination-pattern 91[2-9]..[2-9]......
session target sip-server
dtmf-relay rtp-nte digit-drop
codec g711ulaw
no vad
dial-peer voice 100 voip
description Local SIP Calls
translation-profile outgoing Outgoing_SIP
destination-pattern 9[2-9].........
incoming called-number [29].........
no vad
12-10-2014 01:20 PM
You have what is called overlapping dial plans. You use 9 to dial out and you also have remote location with extensions/DDI beginning with 9..Can you tell me specifically what the DDI range is for the remote location? is it 910....... or are there more?
12-10-2014 01:24 PM
Ah that makes sense. We do use 9 to dial out.
We have locations all over the country and are currently expanding even further West.
For example, the 9102857722 rings to our Wallace, NC location
281-XXX-XXXX for a few Texas stores
205-XXX-XXXX for a few Alabama stores
And so forth
12-10-2014 01:50 PM
ok..We need to use a different approach to resolve this..We need to prefix calls coming from cucm so as to break up the overlapping issue..
do this..
go to cucm, search for the Route list you use for outbound calls, click on the route group associated with it.
Under called party xformation
under discard digits: use to none
prefix digit outgoing calls: add 141 as shown below
Then do this...
voice translation-rule 141
rule 1 /^141/ //
voice translation-profile 141
translate called 141
incoming called-number 141T
translation-profile incoming 141
Then..do this
incoming called number [29].........
So what this does is that all calls coming from cucm are prefixed with 141 and will match dial-peer 15. We then strip this 141 from the dial-peer and send the call as it should be out to the PSTN..This way we break the overlapping issue with calls coming from PSTN with 9..
12-11-2014 05:34 AM
I will make this change shortly, however does this break my existing setup? For example, will users still be dialing 9 then the # to make calls?
I definitely understand where this is going, just making sure it doesn't cause any downtime, or change the current procedure.
Thanks again for all this help. Above and beyond.
12-11-2014 06:41 AM
Joe,
It doesn't break anything. This change is transparent to the end users. They continue to dial as normal. The only thing to watch out for is if the display on the ip phone shows the prefixed 141..If this happens then please apply this command and you should be good
voice service voip
no supplementary-service h225-notify cid-update
12-11-2014 06:42 AM
I will make these changes around 12:15pm, most should be at lunch. And I will report back.
Again, thanks for all the help.
12-11-2014 09:32 AM
That worked like a champ. I didn't see the '141' appended to any phones internally or get masked when calling externally, so that looks good as well.
The original issue I posted looks to be fixed, however, I am wondering if you could help with 2 other "issues".
1. I have cleaned up that config as best as I know how, however I am trying to further that clean up, especially now that we have a more correct config in place.
-Do we need any other dial-peers besides Voice 15 and Voice 100? Are the original Voice Translation Rules/Profiles valid anymore?
2. We've never been able to dial internationally from our phone system, but I do see the existing dial peer below:
dial-peer voice 120 voip
description International SIP Calls
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
no vad
Is this an easy fix to get working?
12-11-2014 10:45 AM
Glad to help Joe..
Yes you do need those dial-peers. They all do different things..
dial-peer 15 is for inbound from cucm and for outbound to cucm sub1 and 16 is for outbound to cucm sub2 incase sub1 fails..
The other outbound dial-peers are used for routing different numbers..
I am sure this should be easy to fix. what happens when you dial international call with this dial-peer in place? The previous config you sent to me doesn't seem to have this..
12-11-2014 11:16 AM
Well, if I am dialing it out correctly:
9-004-072-420-5837
But it simply immediately goes "Your call can't be completed as dialed. Try again....etc"
That is a cell phone in Romania (coworker)
The current dial peer I am seeing is:
dtmf-relay rtp-nte
codec g711ulaw
no vad
12-11-2014 11:26 AM
You are not dialing correctly. The IDD for the is is 011, so you should be dialling
9-0114-072-420-5837
12-11-2014 11:31 AM
Well now I feel silly for not looking at that dial peer closer. However, now we receive
"The numbers are not in service, please try again"
I do know they are active numbers (coworkers mom cell and land line in Romania)
12-11-2014 11:58 AM
Have you tried dialling another? Any other international number
12-11-2014 12:02 PM
I have:
4165034259
4162588513
(289) 997-2241
(416) 998-8298
All Canadian numbers. If I use 9011 - then the number it gives the above message.
If I simply try and dial normally -> 9-1-416-503-4259 , I get:
"This type of call requires the collection of a valid passcode to proceed. Please enter your passcode, followed by the pound key"
Possibly something in CUCM?
12-11-2014 12:19 PM
That looks like FAC in cucm. Even if you put in the FAC code, this wouldn't match any dial peer on the gateway
