DTMF Issue with SIP TRUNK (CUCM and CUE)
Dear All,
I am having DTMF issues while configuring sip trunk on CUCM and CUE. The issue is that when I call from outside to the sip number some times it keeps ringing and sometimes it goes to the auto attendant (when i dial the extension, operator repeates" you are still there").  I am doing Transalation to change all my sip numbers to local extensions. I have configured CTI Port/CIT Route Point.
To add: we are using analog lines and we just got the new sip trunk, gradually we will move from analog to sip. Right now we are doing some test run in order to get the sip trunk configured.
Below is the configuration, along witht he debugs.
My Configuration is as follows:
SIP PROVIDER ---------- VOICE GATEWAY----------- CUCM ------(sip trunk)----------CUE
Configuration on Voice Gateway:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
h323
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice translation-rule 813
rule 1 /^8132/ /2/
rule 2 /^038132/ /2/
rule 3 /^0096638132/ /2/
rule 4 /^96638132/ /2/
rule 5 /^38132/ /2/
voice translation-profile 03813
translate called 813voice translation-rule 813
rule 1 /^8132/ /2/
rule 5 /^38132/ /2/
dial-peer voice 1000 voip
translation-profile incoming 03813
destination-pattern 27..
session protocol sipv2
session target ipv4:10.15.0.201
incoming called-number .T
dtmf-relay sip-notify
codec g711ulaw
no vad
On the CUCM i have configured a SIP Trunk with:
Required Field: g711ulaw
Required Field: No preference
Non Secure SIP Trunk Profile: I am using TCP+UDP for INCOMING ;
On the CUCM i have configured CTI Port and CTI Route Point. Both showing registered with CUE
Please help me resolve this issue. I have faced it many times but it got resolved but this one I dont know what to do.
Thanks & Regards,
TYZ
459
