DTMF mismatch issue
I have two clusters of CUCM like this:
IP Phone -------SCCP------CUCM cluster 1 ---------ICT trunk (gk controlled)-------Gatekeeper1------Gatekeeper2 -----ICT trunk (gk controled)------CUCM cluster 2------SIP trunk-----CUBE (to conferencing facility).
SIP trunk is configuured to use RFC 2833.
IP Phone is Cisco 7961 and supports RFC 2833 (confirmed).
SDI traces from CUCM in cluster 2 has the following DTMF mismatchi info:
16:37:59.697 |DET-MediaManager-(51187)::isMTPNeededForMismatchOrConfig, MTPNeededDueToDTMFCapMismatch(2833/OOB) mtpinsertionReason=1 dtmfMTPSide=2|9,100,21,44503.2^13.64.0.17^Port 52275
And due to the DTMF mismatch, an MTP is used.
My questions:
1 Why there is a DTMF mismatch? The IP phone is RFC 2833 supported, and the SIP trunk is RFC 2833 used, Why?
2 Is the ICT trunk anything to do with DTMF?
3 It is found  IP Phones (same model) registered to  CUCM cluster 2 does not have the DTMS mismatch issue. Why?
1 REPLY
VIP Super Bronze
DTMF mismatch issue
It certainly has something to do with the ICT. Your gatekeeper is configured with h323 dial-peers which can only support out of bound dtmf method. Hence you have a sip phone configured for rfc-2833 (inband dtmf) and ICT on outbound..
I had this issue in the past and the way around it is to enable sip kpml on your CUBE.
dial-peer voice 5 voip
dtmf-relay rtp-nte digit-drop sip-kpml
I am not sure whats going on cluster 2. Perhaps rfc2833 is disabled on the phone in that cluster...
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
970
