DTMF not recognized on connected call
I am not getting any DTMF accptance when I call into an IVR and asked to make a selection 1-9 ect...
ITSP ---->(SIP)  CUBE  --->(H323)  CUCM
pbxguy_router#sho run
Building configuration...
Current configuration : 8466 bytes
! Last configuration change at 23:31:47 UTC Wed Dec 11 2013 by scott
version 15.1
hostname pbxguy_router
boot-start-marker
boot system flash c3825-adventerprisek9-mz.151-4.M7.bin
boot-end-marker
no logging buffered
enable secret 5 $1$jLw/$mT4zlcPRsWnipVZ0aHnBA0
aaa new-model
aaa authentication login default local
aaa authentication login sslvpn local
aaa authorization exec default local
aaa session-id common
dot11 syslog
ip source-route
ip cef
ip domain name pbxguy.com
ip name-server 8.8.8.8
no ipv6 cef
stcapp ccm-group 1
stcapp
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
no ip address trusted authenticate
media flow-around
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  early-offer forced
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
codec preference 3 g729br8
voice translation-rule 1
rule 1 /4029881010/ /1010/
voice translation-rule 2
rule 2 /335201/ /1010/
voice translation-profile INCOMING
translate called 1
voice translation-profile TempIncoming
translate called 2
crypto pki trustpoint TP-self-signed-1860214740
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1860214740
revocation-check none
rsakeypair TP-self-signed-1860214740
crypto pki certificate chain TP-self-signed-1860214740
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31383630 32313437 3430301E 170D3133 31303235 31353434
  33375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 38363032
  31343734 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009C49 FF6C8071 A0CF9255 70366C11 EDEDE473 013AC5E8 E26B8F1B 5B4FB0CE
  B801F441 67439BC7 2A251DD5 708A7A35 128E2DFC 861D23F4 18A23EF0 6AC87CB3
  C3F03C47 4285FC3E A043A66B 1232F885 3597F6D6 E98B5E3D 86902237 A3483ED5
  17E5B804 A478EAB3 D00D3DEA 68D13EAE 6D9552F3 780E6CB8 B329EEDD 255A22E4
  A7610203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 140840B0 1EF7F1E2 1A8CA935 431D067E 57B6C46F 37301D06
  03551D0E 04160414 0840B01E F7F1E21A 8CA93543 1D067E57 B6C46F37 300D0609
  2A864886 F70D0101 05050003 8181005D 03A541D5 9B3C206E 8BC2E4A3 B00017FE
  EC0A4806 5B5E2F3E 67CCDAC9 D11AD33D BD44989F 295E784D E4CF39AC 2E21A2B5
  FFAC5171 1372DD0B 764DD3C0 E4088CB7 01D5D4E2 4CA0C955 25F4FF2E 75C3D740
  399F67B5 9160F8F4 59206DDC 8392D4B7 47B8E683 220E06BD 2964EBA4 5B57BC98
  D623EFC5 399AA46D 6E591D52 45233C
            quit
license udi pid CISCO3825 sn FTX1239A28R
license accept end user agreement
archive
log config
  hidekeys
username scott privilege 15 secret 5 $1$Y4nT$1neWA5OmFc/IAvSfA4dB11
redundancy
ip ssh version 2
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1.40
encapsulation dot1Q 40
ip address 10.10.10.1 255.255.255.252
ip nat inside
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.10.10.1
router eigrp 10
network 10.10.10.1 0.0.0.0
ip local pool webvpn-pool 10.20.30.10 10.20.30.15
ip forward-protocol nd
ip http server
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static udp 192.168.192.3 3074 interface GigabitEthernet0/0 3074
ip nat inside source static udp 192.168.192.3 88 interface GigabitEthernet0/0 88
ip nat inside source static tcp 192.168.192.3 53 interface GigabitEthernet0/0 53
ip nat inside source static udp 192.168.192.3 53 interface GigabitEthernet0/0 53
ip nat inside source static tcp 192.168.192.3 80 interface GigabitEthernet0/0 80
ip nat inside source static tcp 192.168.192.3 3074 interface GigabitEthernet0/0 3074
ip nat inside source static tcp 192.168.254.10 5060 interface GigabitEthernet0/0 5060
ip nat inside source static udp 192.168.254.10 5060 interface GigabitEthernet0/0 5060
ip access-list extended inbound
permit udp any any eq 3074
permit udp any eq 88 any
permit tcp any any eq 3074
permit tcp any any eq domain
permit udp any any eq domain
permit tcp any any eq www
permit tcp any any eq 5060
permit udp any any eq 5060
access-list 1 permit 208.110.65.18
access-list 1 permit 192.168.192.0 0.0.0.255
access-list 1 permit 192.168.128.0 0.0.0.31
access-list 1 permit 10.20.30.0 0.0.0.255
access-list 1 permit 192.168.254.0 0.0.0.255
control-plane
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm 192.168.254.10 identifier 1 version 7.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confLab
associate profile 2 register xcodeLab
associate profile 3 register mtpLab
dspfarm profile 2 transcode
codec g729r8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 9
associate application SCCP
dspfarm profile 1 conference
codec g711ulaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
dspfarm profile 3 mtp
codec g711ulaw
maximum sessions hardware 12
maximum sessions software 200
dial-peer voice 1 voip
incoming called-number .
voice-class codec 1
dtmf-relay rtp-nte h245-signal h245-alphanumeric
no vad
dial-peer voice 2 voip
destination-pattern 4029881010
session target ipv4:192.168.254.10
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 4 voip
destination-pattern 1[2-9]..[2-9]......
session protocol sipv2
session target sip-server
session transport udp
no voice-class sip early-offer forced
dtmf-relay rtp-nte
no dtmf-interworking
codec g711ulaw
no vad
dial-peer voice 5 voip
destination-pattern [2-9]..[2-9]......
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
credentials username 335201 password 7 03570B58505E771C165D40 realm sip-ua.com
authentication username 335201 password 7 075C711F18584F554F4652 realm sip-ua.com
registrar dns:proxy.sip-ua.com expires 60
sip-server dns:proxy.sip-ua.com
line con 0
line aux 0
line vty 0 4
exec-timeout 40 0
privilege level 15
password cisco
transport input ssh
scheduler allocate 20000 1000
webvpn gateway Cisco-WebVPN-Gateway
ip address 174.71.48.163 port 443
ssl encryption rc4-md5
ssl trustpoint TP-self-signed-1860214740
logging enable
inservice
webvpn gateway webvpn
no inservice
webvpn install svc flash:/webvpn/anyconnect-win-3.0.11042-k9.pkg sequence 1
webvpn install svc flash:/webvpn/anyconnect-macosx-i386-3.1.04072-k9.pkg sequence 2
webvpn context Cisc0-WebVPN
ssl authenticate verify all
policy group webvpnpolicy
   functions svc-enabled
no inservice
webvpn context Cisco-WebVPN
title "Scott Glenn Private Network, Authorized Users Only"
url-list "rewrite"
acl "ssl-acl"
   permit ip 10.20.30.0 255.255.255.0 192.168.192.0 255.255.255.0
   permit ip 10.20.30.0 255.255.255.0 192.168.254.0 255.255.255.0
   permit ip 10.20.30.0 255.255.255.0 10.10.10.0 255.255.255.0
login-message "Cisco Secure WebVPN"
   svc address-pool "webvpn-pool" netmask 255.255.255.0
   svc rekey method new-tunnel
   svc split include 10.20.30.0 255.255.255.0
   svc split include 192.168.192.0 255.255.255.0
   svc split include 192.168.254.0 255.255.255.0
   svc split include 10.10.10.0 255.255.255.0
default-group-policy webvpnpolicy
aaa authentication list sslvpn
max-users 2
inservice
end
Please attach the following debugs from the CUBE
Debug voice ccapi inout
Debug cssip messages
Also for start if the Codec on the leg with the CUCM is G711ulaw, we can invoke Call manager(Software ) MTP on the sip trunk. If using G729 we need Hardware MTP
VIP Super Bronze
Looking at your config,
1. your inboun dial-peer has been wrongly configured.. This dial-peer is used for routing calls from both your ITSP and CUCM. The problem with this is that one leg is SIP and the other is h323...This dial-peer is h323 dial-peer and it has rtp-nte as the primary dtmf method..This is not a good practice
voice-class codec 1
no vad
2. You will need to create two different inbound dial-peers and apply the correct dtmf method to them..
eg
incoming called number XXXXXXX (where XXXXX= called number from ITSP)
no vad
voice-class codec 1
dtmf-relay rtp-nte digit-drop
incoming called number YYYYY, where YYYY=called number from cucm
no vad
voice-class codec 1
NB: You should use the digit drop key word so that DTMF are passed out of band on the sip leg hence preventing a need for MTP
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Please rate all useful posts "The essence of christianity is not the enthronement but the obliteration of self --William Barclay"
It appears that I am getting back the following messge when I call into a TFN and try to press option "1":
*Dec 16 14:58:48.604: //20386/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x716C46E8, Params=0x716C46C0, Call Id=20386
*Dec 16 14:58:48.604: //20387/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
   Nominator=0x716C46E8, Params=0x716C46C0, Call Id=20387
*Dec 16 14:58:48.664: //20386/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x18E00, Params=0x716C4A50, Call Id=20386
*Dec 16 14:58:48.668: //20386/xxxxxxxxxxxx/CCAPI/cc_api_call_modify_done:
   Result=0, Interface=0x6A030830, Call Id=20386
*Dec 16 14:58:48.668: //20386/xxxxxxxxxxxx/CCAPI/ccCallModifyExtended:
*Dec 16 14:59:01.148: //20384/8008FC7E1300/CCAPI/cc_api_call_digit_begin:
   Consume mask is not set. Relaying Digit 1 to dstCallId 0x4FA1
*Dec 16 14:59:01.148: //20384/8008FC7E1300/CCAPI/cc_relay_digit_begin_for_3way_conference:
   Check DTMF relay digit begin for 3way conf
*Dec 16 14:59:01.148: //20384/8008FC7E1300/CCAPI/cc_api_call_digit_end:
*Dec 16 14:59:01.148: //20384/8008FC7E1300/CCAPI/cc_relay_digit_end_for_3way_conference:
   Check DTMF relay digit end for 3way conf
*Dec 16 14:59:11.280: //20386/xxxxxxxxxxxx/CCAPI/ccCallModify:
   Nominator=0x800, Params=0x716C4A98, Call Id=20386
VIP Super Bronze
Have you made the changes I suggested..??
I made the changes and there was no change in the outcome.  Still no digits are recognized when calling into menus.
VIP Super Bronze
Re: DTMF not recognized on connected call
Scoot,
Please send us the ff:
1. sh run
2. debug voip ccapi inout
3.debug ccsip messages
4. debug voip rtp session named-event
5. debug h245 asn1
Please collect the logs in one file and attach here
I have attached the following in one file.
show run
debug ccsip message
debug h245 asn1
1040
