DTMF QSIG to SIP
Hey Guys,
DTMF doesnt seem to be workig correctly. We have the following call flow. CUCM -> H323 -> ISR -> QSIG ->ISR ->SIP -> CUCM ->SIP -> CUMP
Now, I make a call to the MeetingPlace server, the call is connected, however Im unable to press the Meeting Room ID.. hence DTMF doesnt seem to work.
I've the local guys run the following debugs for me.
debug ccsip all
debug voip rtp session named-events
debug vtsp dsp
debug voip ccapi inout
I can see the DTMF negotiating as rtp-nte successfully, however no DTMF events. I have copied the below debugs in for you to view.
The config is basically straight forward.. the sip dial-peer has dtmf-relay sip-kpml rtp-nte digit-drop configured.
If the VOIP Call Leg to the CUCM is changed to H323.. the DTMF digits works fine and can press the Meeting Room ID.. but as soon as the VOIP Call Leg is changed to SIP DTMF stops workign again.
In the below debugs.. I noticed the following:
Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_bridge: really can't find peer_stream for
                                                dtmf-relay interworking
Unsure what this means.
Anyway, here are the debugs.. Your assistance is appreciated.
hkgfcvg04#sh debug
VOIP RTP ALL Named Events debugging is on
CCAPI:
  debug voip ccapi inout is ON (filter is OFF)
CCSIP SPI: SIP Call Statistics tracing is enabled       (filter is OFF)
CCSIP SPI: SIP Call Message tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call State Machine tracing is enabled    (filter is OFF)
CCSIP SPI: SIP Call Events tracing is enabled   (filter is OFF)
CCSIP SPI: SIP error debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP info debug tracing is enabled    (filter is OFF)
CCSIP SPI: SIP media debug tracing is enabled   (filter is OFF)
CCSIP SPI: SIP Call preauth tracing is enabled  (filter is OFF)
CCSIP SPI: SIP Call transport tracing is enabled        (filter is OFF)
CCSIP SPI: SIP DHCP tracing is enabled  (filter is OFF)
DSM:
  debug voip dsm dsp is ON (filter is OFF)
sh log
Syslog logging: enabled (0 messages dropped, 128 messages rate-limited,
                152 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 3789374 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 10445 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 3788536 messages logged, xml disabled,
                     filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
    Trap logging: level notifications, 578 message lines logged
        Logging to 10.121.127.4  (udp port 514,  audit disabled,
              authentication disabled, encryption disabled, link up),
              578 message lines logged,
              0 message lines rate-limited,
              0 message lines dropped-by-MD,
              xml disabled, sequence number disabled
              filtering disabled
        Logging to 10.121.127.5  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 10.121.126.14  (udp port 514,  audit disabled,
              filtering disabled
        Logging to 10.121.18.225  (udp port 514,  audit disabled,
              filtering disabled
Log Buffer (409600 bytes):
898 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7558177 , call lasted 16 seconds
3779421: Aug 13 11:09:17.770 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 751996158149 N/A
3779422: Aug 13 11:09:20.838 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 751996158149 , call lasted 3 seconds
3779423: Aug 13 11:09:22.789 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:9 is now connected to 75628962870 N/A
3779424: Aug 13 11:09:31.349 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:12 is now connected to N/A N/A
3779425: Aug 13 11:09:31.517 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7513164 , call lasted 710 seconds
3779426: Aug 13 11:09:35.817 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:10 is now connected to 7511096 N/A
3779427: Aug 13 11:09:37.901 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:13 is now connected to 7511403 N/A
3779428: Aug 13 11:09:38.673 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:10  disconnected from 7511096 , call lasted 2 seconds
3779429: Aug 13 11:09:41.533 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 751965066961 , call lasted 65 seconds
3779430: Aug 13 11:09:42.373 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 7511142 N/A
3779431: Aug 13 11:09:44.169 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 7511142 , call lasted 1 seconds
3779432: Aug 13 11:10:03.141 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:9  disconnected from 75628962870 , call lasted 40 seconds
3779433: Aug 13 11:10:13.297 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 75628961008 N/A
3779434: Aug 13 11:10:16.049 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 7513637 , call lasted 171 seconds
3779435: Aug 13 11:10:16.305 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7562790 N/A
3779436: Aug 13 11:10:17.553 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:21  disconnected from 7512067 , call lasted 65 seconds
3779437: Aug 13 11:10:21.693 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 7574381 , call lasted 105 seconds
3779438: Aug 13 11:10:38.413 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:9 is now connected to 7562917 N/A
3779439: Aug 13 11:10:48.221 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:21 is now connected to 7553131 N/A
3779440: Aug 13 11:10:49.057 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 7562808 N/A
3779441: Aug 13 11:11:03.661 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 7562808 , call lasted 14 seconds
3779442: Aug 13 11:11:08.189 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7511439 N/A
3779443: Aug 13 11:11:09.416 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7562790 , call lasted 53 seconds
3779444: Aug 13 11:11:11.192 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:9  disconnected from 7562917 , call lasted 32 seconds
3779445: Aug 13 11:11:12.440 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7513616 N/A
3779446: Aug 13 11:11:16.664 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7562805 N/A
3779447: Aug 13 11:11:26.184 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 7450803 N/A
3779448: Aug 13 11:11:27.608 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7511322 , call lasted 558 seconds
3779449: Aug 13 11:11:28.276 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:9 is now connected to 7544848 N/A
3779450: Aug 13 11:11:33.024 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 7513693 N/A
3779451: Aug 13 11:11:33.588 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7552612 N/A
3779452: Aug 13 11:11:39.912 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to 7562540 N/A
3779453: Aug 13 11:12:03.380 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:10 is now connected to 7513585 N/A
3779454: Aug 13 11:12:10.072 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7512514 , call lasted 899 seconds
3779455: Aug 13 11:12:11.188 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:20 is now connected to 7513529 N/A
3779456: Aug 13 11:12:20.048 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:6 is now connected to 7553200 N/A
3779457: Aug 13 11:12:23.120 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 7513696 N/A
3779458: Aug 13 11:12:23.844 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 7513693 , call lasted 50 seconds
3779459: Aug 13 11:12:24.168 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:10  disconnected from 7513585 , call lasted 20 seconds
3779460: Aug 13 11:12:40.592 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 7562540 , call lasted 60 seconds
3779461: Aug 13 11:12:41.388 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7511522 N/A
3779462: Aug 13 11:12:43.920 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7511522 , call lasted 2 seconds
3779463: Aug 13 11:12:44.424 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:6  disconnected from 7553200 , call lasted 24 seconds
3779464: Aug 13 11:12:45.132 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12  disconnected from 7616202 , call lasted 404 seconds
3779465: Aug 13 11:12:52.584 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:18  disconnected from 7513696 , call lasted 29 seconds
3779466: Aug 13 11:12:57.079 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7552612 , call lasted 83 seconds
3779467: Aug 13 11:13:00.615 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected to 7513612 N/A
3779468: Aug 13 11:13:01.263 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7562540 N/A
3779469: Aug 13 11:13:04.311 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7511323 N/A
3779470: Aug 13 11:13:05.311 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  disconnected from 7557026 , call lasted 481 seconds
3779471: Aug 13 11:13:06.571 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 7513330 N/A
3779472: Aug 13 11:13:11.587 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 7450803 , call lasted 105 seconds
3779473: Aug 13 11:13:15.311 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:8  disconnected from 7575661 , call lasted 288 seconds
3779474: Aug 13 11:13:18.403 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 7511098 , call lasted 619 seconds
3779475: Aug 13 11:13:19.235 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:7  disconnected from 64337847 , call lasted 754 seconds
3779476: Aug 13 11:13:24.383 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 7511168 N/A
3779477: Aug 13 11:13:24.427 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7513616 , call lasted 131 seconds
3779478: Aug 13 11:13:31.995 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:12  disconnected from unknown , call lasted 240 seconds
3779479: Aug 13 11:13:33.319 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 7511800 N/A
3779480: Aug 13 11:13:38.799 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12  disconnected from 7513612 , call lasted 38 seconds
3779481: Aug 13 11:13:39.111 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:12 is now connected to 7513906 N/A
3779482: Aug 13 11:13:40.987 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:10 is now connected to 7513913 N/A
3779483: Aug 13 11:13:41.715 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 7514488 , call lasted 751 seconds
3779484: Aug 13 11:13:44.359 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7511323 , call lasted 40 seconds
3779485: Aug 13 11:13:44.755 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected to 7513693 N/A
3779486: Aug 13 11:13:46.983 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7511439 , call lasted 158 seconds
3779487: Aug 13 11:13:48.195 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 7562790 N/A
3779488: Aug 13 11:13:52.623 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:2 is now connected to 7413544 N/A
3779489: Aug 13 11:13:55.587 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7514563 N/A
3779490: Aug 13 11:13:55.703 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:7  disconnected from 3262 , call lasted 4595 seconds
3779491: Aug 13 11:13:57.135 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:10  disconnected from 7513913 , call lasted 16 seconds
3779492: Aug 13 11:13:57.259 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:5  disconnected from 3482 , call lasted 6151 seconds
3779493: Aug 13 11:13:59.583 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:11  disconnected from 6732384447 , call lasted 4650 seconds
3779494: Aug 13 11:14:06.643 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:5 is now connected to 7512517 N/A
3779495: Aug 13 11:14:08.707 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:10 is now connected to 7453335 N/A
3779496: Aug 13 11:14:11.091 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7511522 N/A
3779497: Aug 13 11:14:13.047 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 7562579 N/A
3779498: Aug 13 11:14:13.419 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  disconnected from 7413544 , call lasted 20 seconds
3779499: Aug 13 11:14:13.587 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7511522 , call lasted 2 seconds
3779500: Aug 13 11:14:20.683 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7513921 , call lasted 383 seconds
3779501: Aug 13 11:14:29.243 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12  disconnected from 7513693 , call lasted 44 seconds
3779502: Aug 13 11:14:32.343 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:21  disconnected from 7553131 , call lasted 224 seconds
3779503: Aug 13 11:14:34.395 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:10  disconnected from 7453335 , call lasted 25 seconds
3779504: Aug 13 11:14:50.058 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 62102532 , call lasted 711 seconds
3779505: Aug 13 11:14:50.834 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7562540 , call lasted 109 seconds
3779506: Aug 13 11:14:57.410 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:12  disconnected from 7513906 , call lasted 78 seconds
3779507: Aug 13 11:14:59.634 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:21 is now connected to 7562540 N/A
3779508: Aug 13 11:15:02.358 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7511593 N/A
3779509: Aug 13 11:15:12.010 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7413544 N/A
3779510: Aug 13 11:15:13.502 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7511593 , call lasted 11 seconds
3779511: Aug 13 11:15:13.670 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:9  disconnected from 7544848 , call lasted 225 seconds
3779512: Aug 13 11:15:20.050 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected to 7511442 N/A
3779513: Aug 13 11:15:23.222 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7411593 N/A
3779514: Aug 13 11:15:26.246 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7513807 N/A
3779515: Aug 13 11:15:27.606 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7616794 N/A
3779516: Aug 13 11:15:28.998 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to 7511313 N/A
3779517: Aug 13 11:15:35.030 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7569036 , call lasted 1586 seconds
3779518: Aug 13 11:15:47.094 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 7511168 , call lasted 142 seconds
3779519: Aug 13 11:15:54.510 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 7562579 , call lasted 101 seconds
3779520: Aug 13 11:15:59.970 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 7511313 , call lasted 30 seconds
3779521: Aug 13 11:16:04.366 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7513693 N/A
3779522: Aug 13 11:16:08.542 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7513807 , call lasted 42 seconds
3779523: Aug 13 11:16:12.658 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7511315 N/A
3779524: Aug 13 11:16:14.590 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 7511322 N/A
3779525: Aug 13 11:16:14.666 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7511315 , call lasted 2 seconds
3779526: Aug 13 11:16:27.578 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7562805 , call lasted 310 seconds
3779527: Aug 13 11:16:33.529 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 7513591 N/A
3779528: Aug 13 11:16:34.409 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7511317 N/A
3779529: Aug 13 11:16:35.869 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:2 is now connected to N/A N/A
3779530: Aug 13 11:16:41.301 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:7 is now connected to 7513917 N/A
3779531: Aug 13 11:16:53.545 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7513042 N/A
3779532: Aug 13 11:16:54.393 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7562695 N/A
3779533: Aug 13 11:16:54.957 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7513693 , call lasted 50 seconds
3779534: Aug 13 11:16:57.801 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7562695 , call lasted 3 seconds
3779535: Aug 13 11:17:15.397 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:5  disconnected from 7512742 , call lasted 736 seconds
3779536: Aug 13 11:17:25.765 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7513798 N/A
3779537: Aug 13 11:17:33.329 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7511098 N/A
3779538: Aug 13 11:17:35.697 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7511098 , call lasted 2 seconds
3779539: Aug 13 11:17:38.717 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7413544 , call lasted 146 seconds
3779540: Aug 13 11:17:48.973 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 75628961008 , call lasted 455 seconds
3779541: Aug 13 11:17:49.529 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to N/A N/A
3779542: Aug 13 11:17:57.649 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  disconnected from unknown , call lasted 81 seconds
3779543: Aug 13 11:18:04.981 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:5 is now connected to 7511609 N/A
3779544: Aug 13 11:18:09.085 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:5  disconnected from 7511609 , call lasted 4 seconds
3779545: Aug 13 11:18:12.369 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7514884 N/A
3779546: Aug 13 11:18:18.065 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 7513591 , call lasted 104 seconds
3779547: Aug 13 11:18:25.124 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7511609 N/A
3779548: Aug 13 11:18:32.392 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7514884 , call lasted 20 seconds
3779549: Aug 13 11:18:34.552 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7511609 , call lasted 9 seconds
3779550: Aug 13 11:18:39.896 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected from 7553193 , call lasted 777 seconds
3779551: Aug 13 11:18:55.172 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7511762 N/A
3779552: Aug 13 11:18:57.700 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:12 is now connected to 7413544 N/A
3779553: Aug 13 11:19:02.428 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected to 7512742 N/A
3779554: Aug 13 11:19:02.556 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7513798 , call lasted 96 seconds
3779555: Aug 13 11:19:03.776 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7514563 , call lasted 308 seconds
3779556: Aug 13 11:19:04.920 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7531712 N/A
3779557: Aug 13 11:19:08.492 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 21798313 N/A
3779558: Aug 13 11:19:14.504 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:8  disconnected from 21796301 , call lasted 818 seconds
3779559: Aug 13 11:19:16.396 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7531712 , call lasted 11 seconds
3779560: Aug 13 11:19:32.776 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:12  disconnected from 7413544 , call lasted 35 seconds
3779561: Aug 13 11:19:33.668 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7450828 N/A
3779562: Aug 13 11:19:35.352 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7450828 , call lasted 1 seconds
3779563: Aug 13 11:19:35.992 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 7513330 , call lasted 389 seconds
3779564: Aug 13 11:19:48.920 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:20  disconnected from 7513529 , call lasted 457 seconds
3779565: Aug 13 11:19:53.004 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from unknown , call lasted 123 seconds
3779566: Aug 13 11:20:20.695 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12  disconnected from 7511442 , call lasted 300 seconds
3779567: Aug 13 11:20:21.891 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:8 is now connected to 7413182 N/A
3779568: Aug 13 11:20:33.255 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 7616304 N/A
3779569: Aug 13 11:20:40.835 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7513849 N/A
3779570: Aug 13 11:20:42.831 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7513688 N/A
3779571: Aug 13 11:20:46.747 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 7616304 , call lasted 13 seconds
3779572: Aug 13 11:21:07.751 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7411593 , call lasted 344 seconds
3779573: Aug 13 11:21:09.795 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:8 is now connected to 7511862 N/A
3779574: Aug 13 11:21:10.859 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected to 7413544 N/A
3779575: Aug 13 11:21:18.251 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 7511322 , call lasted 303 seconds
3779576: Aug 13 11:21:21.695 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:7  disconnected from 7513917 , call lasted 280 seconds
3779577: Aug 13 11:21:31.891 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:12  disconnected from 7413544 , call lasted 21 seconds
3779578: Aug 13 11:21:40.439 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7513688 , call lasted 57 seconds
3779579: Aug 13 11:21:48.151 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:8  disconnected from 7511862 , call lasted 38 seconds
3779580: Aug 13 11:21:50.347 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:8  disconnected from 7413182 , call lasted 88 seconds
3779581: Aug 13 11:22:01.854 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7513660 N/A
3779582: Aug 13 11:22:02.702 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7513693 N/A
3779583: Aug 13 11:22:08.038 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 7513916 N/A
3779584: Aug 13 11:22:13.738 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7511317 , call lasted 339 seconds
3779585: Aug 13 11:22:19.122 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:20 is now connected to 7562805 N/A
3779586: Aug 13 11:22:23.378 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7511862 N/A
3779587: Aug 13 11:22:25.142 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7411505 N/A
3779588: Aug 13 11:22:26.502 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 21798313 , call lasted 198 seconds
3779589: Aug 13 11:22:28.146 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:20  disconnected from 7562805 , call lasted 9 seconds
3779590: Aug 13 11:22:32.522 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7511862 , call lasted 9 seconds
3779591: Aug 13 11:22:32.750 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:11  disconnected from 75587583158 , call lasted 2056 seconds
3779592: Aug 13 11:22:34.062 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 7550 , call lasted 1692 seconds
3779593: Aug 13 11:22:35.946 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to N/A N/A
3779594: Aug 13 11:22:36.782 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 7512776 N/A
3779595: Aug 13 11:22:39.846 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 7513256 , call lasted 837 seconds
3779596: Aug 13 11:22:40.646 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:8 is now connected to N/A N/A
3779597: Aug 13 11:22:44.214 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:18  disconnected from 7511800 , call lasted 550 seconds
3779598: Aug 13 11:22:45.154 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7411505 , call lasted 20 seconds
3779599: Aug 13 11:23:01.606 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from 97218043 , call lasted 1614 seconds
3779600: Aug 13 11:23:10.450 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 7511876 N/A
3779601: Aug 13 11:23:12.622 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7513849 , call lasted 151 seconds
3779602: Aug 13 11:23:18.906 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7513693 N/A
3779603: Aug 13 11:23:20.602 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 7513849 N/A
3779604: Aug 13 11:23:20.778 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to 7450896 N/A
3779605: Aug 13 11:23:33.750 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7511762 , call lasted 278 seconds
3779606: Aug 13 11:23:34.650 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7513632 , call lasted 1421 seconds
3779607: Aug 13 11:23:35.722 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:13  disconnected from 7513632 , call lasted 945 seconds
3779608: Aug 13 11:23:40.661 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 7450932 N/A
3779609: Aug 13 11:23:42.153 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 7512776 , call lasted 65 seconds
3779610: Aug 13 11:23:46.017 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7513693 , call lasted 103 seconds
3779611: Aug 13 11:23:57.045 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7511600 , call lasted 461 seconds
3779612: Aug 13 11:23:57.461 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7513660 , call lasted 115 seconds
3779613: Aug 13 11:23:59.961 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7413484 N/A
3779614: Aug 13 11:24:05.397 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7513157 N/A
3779615: Aug 13 11:24:10.425 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from unknown , call lasted 94 seconds
3779616: Aug 13 11:24:18.033 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:20 is now connected to 7513807 N/A
3779617: Aug 13 11:24:18.241 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 7450896 , call lasted 57 seconds
3779618: Aug 13 11:24:19.365 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:8  disconnected from unknown , call lasted 98 seconds
3779619: Aug 13 11:24:22.429 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7513227 N/A
3779620: Aug 13 11:24:23.217 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 751963369608 N/A
3779621: Aug 13 11:24:25.249 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 7513916 , call lasted 137 seconds
3779622: Aug 13 11:24:27.945 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:18  disconnected from 751963369608 , call lasted 4 seconds
3779623: Aug 13 11:24:33.357 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected from 7512742 , call lasted 330 seconds
3779624: Aug 13 11:24:34.381 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7513693 , call lasted 75 seconds
3779625: Aug 13 11:24:55.993 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:2 is now connected to N/A N/A
3779626: Aug 13 11:24:57.785 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 751962813215 N/A
3779627: Aug 13 11:25:17.377 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7513495 N/A
3779628: Aug 13 11:25:20.101 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7513227 , call lasted 57 seconds
3779629: Aug 13 11:25:20.885 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7512742 N/A
3779630: Aug 13 11:25:23.649 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7512812 N/A
3779631: Aug 13 11:25:26.220 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7413484 , call lasted 86 seconds
3779632: Aug 13 11:25:36.100 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from 7513849 , call lasted 135 seconds
3779633: Aug 13 11:25:36.780 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:6 is now connected to 7413544 N/A
3779634: Aug 13 11:25:46.356 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7413544 , call lasted 9 seconds
3779635: Aug 13 11:25:47.584 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7513495 , call lasted 30 seconds
3779636: Aug 13 11:25:56.028 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:5  disconnected from 7513888 , call lasted 5017 seconds
3779637: Aug 13 11:25:58.080 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 7513833 N/A
3779638: Aug 13 11:25:58.716 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 751962813215 , call lasted 60 seconds
3779639: Aug 13 11:26:08.768 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from 7513833 , call lasted 10 seconds
3779640: Aug 13 11:26:17.456 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7562521 N/A
3779641: Aug 13 11:26:21.720 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 7553193 N/A
3779642: Aug 13 11:26:29.196 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7562521 , call lasted 11 seconds
3779643: Aug 13 11:26:36.156 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  disconnected from unknown , call lasted 100 seconds
3779644: Aug 13 11:26:39.252 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7513591 N/A
3779645: Aug 13 11:26:48.808 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7513591 , call lasted 9 seconds
3779646: Aug 13 11:26:51.000 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7512505 , call lasted 1288 seconds
3779647: Aug 13 11:26:59.060 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected to 7616627 N/A
3779648: Aug 13 11:27:00.824 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7513042 , call lasted 607 seconds
3779649: Aug 13 11:27:04.036 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 7513591 N/A
3779650: Aug 13 11:27:09.344 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7450862 N/A
3779651: Aug 13 11:27:17.599 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7512812 , call lasted 113 seconds
3779652: Aug 13 11:27:18.547 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7450862 , call lasted 9 seconds
3779653: Aug 13 11:27:19.195 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 7562790 , call lasted 811 seconds
3779654: Aug 13 11:27:20.107 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7511472 N/A
3779655: Aug 13 11:27:32.903 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 75587583158 N/A
3779656: Aug 13 11:27:40.031 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7511472 , call lasted 19 seconds
3779657: Aug 13 11:27:49.551 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 75587583158 , call lasted 16 seconds
3779658: Aug 13 11:27:54.787 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7511366 N/A
3779659: Aug 13 11:27:57.715 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:5  disconnected from 7512517 , call lasted 831 seconds
3779660: Aug 13 11:27:59.235 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7512742 , call lasted 158 seconds
3779661: Aug 13 11:28:01.811 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7513693 N/A
3779662: Aug 13 11:28:15.923 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7562790 N/A
3779663: Aug 13 11:28:18.015 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 7553193 , call lasted 116 seconds
3779664: Aug 13 11:28:26.731 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to 7512841 N/A
3779665: Aug 13 11:28:29.107 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:5  disconnected from 7512841 , call lasted 2 seconds
3779666: Aug 13 11:28:31.887 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7562790 , call lasted 15 seconds
3779667: Aug 13 11:28:34.171 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 75761965159 N/A
3779668: Aug 13 11:28:51.535 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7450896 N/A
3779669: Aug 13 11:28:53.011 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7513693 , call lasted 51 seconds
3779670: Aug 13 11:28:53.331 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7450813 N/A
3779671: Aug 13 11:29:03.566 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:2 is now connected to 7513849 N/A
3779672: Aug 13 11:29:07.206 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7450896 , call lasted 15 seconds
3779673: Aug 13 11:29:15.058 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:2  disconnected from 7513849 , call lasted 11 seconds
3779674: Aug 13 11:29:19.806 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7513693 N/A
3779675: Aug 13 11:29:23.922 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7513646 N/A
3779676: Aug 13 11:29:26.558 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7553158 N/A
3779677: Aug 13 11:29:37.078 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7562695 N/A
3779678: Aug 13 11:29:52.150 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 7511122 N/A
3779679: Aug 13 11:29:59.850 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 7562763 N/A
3779680: Aug 13 11:30:08.374 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:5 is now connected to 7523050 N/A
3779681: Aug 13 11:30:11.550 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:18  disconnected from 7562763 , call lasted 11 seconds
3779682: Aug 13 11:30:16.466 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7562695 , call lasted 39 seconds
3779683: Aug 13 11:30:17.014 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:2 is now connected to 7523050 N/A
3779684: Aug 13 11:30:30.502 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:5 is now connected to 7513631 N/A
3779685: Aug 13 11:30:30.590 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from 7513591 , call lasted 206 seconds
3779686: Aug 13 11:30:33.302 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7513693 , call lasted 73 seconds
3779687: Aug 13 11:30:39.678 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 7511122 , call lasted 47 seconds
3779688: Aug 13 11:30:40.490 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7557033 N/A
3779689: Aug 13 11:30:41.362 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:5  disconnected from 7513631 , call lasted 10 seconds
3779690: Aug 13 11:30:42.686 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7513646 , call lasted 78 seconds
3779691: Aug 13 11:30:43.994 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7513087 N/A
3779692: Aug 13 11:30:44.578 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 7553191 N/A
3779693: Aug 13 11:30:48.010 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:1  disconnected from 7553191 , call lasted 3 seconds
3779694: Aug 13 11:30:54.689 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7553155 N/A
3779695: Aug 13 11:30:59.037 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:1 is now connected to 7571150 N/A
3779696: Aug 13 11:31:00.801 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:5 is now connected to 7511088 N/A
3779697: Aug 13 11:31:04.681 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:5 is now connected to 7513939 N/A
3779698: Aug 13 11:31:07.861 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7553155 , call lasted 13 seconds
3779699: Aug 13 11:31:11.861 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to 75628969036 N/A
3779700: Aug 13 11:31:15.777 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 75628969036 , call lasted 3 seconds
3779701: Aug 13 11:31:20.845 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to 7514884 N/A
3779702: Aug 13 11:31:27.469 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:6 is now connected to 7573260 N/A
3779703: Aug 13 11:31:30.993 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7450862 N/A
3779704: Aug 13 11:31:31.637 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7553158 , call lasted 125 seconds
3779705: Aug 13 11:31:31.929 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:6  disconnected from 7573260 , call lasted 4 seconds
3779706: Aug 13 11:31:32.997 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:7 is now connected to 3691 N/A
3779707: Aug 13 11:31:33.785 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7523050 N/A
3779708: Aug 13 11:31:34.817 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:8 is now connected to 7513259 N/A
3779709: Aug 13 11:31:36.665 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:6 is now connected to 7616076 N/A
3779710: Aug 13 11:31:37.757 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7616076 , call lasted 1 seconds
3779711: Aug 13 11:31:38.353 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7523050 , call lasted 4 seconds
3779712: Aug 13 11:31:44.173 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7523050 N/A
3779713: Aug 13 11:31:45.117 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:7  disconnected from 3691 , call lasted 12 seconds
3779714: Aug 13 11:31:45.513 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7513143 N/A
3779715: Aug 13 11:31:46.957 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:6 is now connected to 7571929 N/A
3779716: Aug 13 11:31:57.177 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7450862 , call lasted 26 seconds
3779717: Aug 13 11:31:59.505 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:19 is now connected to 7511476 N/A
3779718: Aug 13 11:32:05.373 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:5  disconnected from 7511088 , call lasted 64 seconds
3779719: Aug 13 11:32:06.401 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:9  disconnected from 7523050 , call lasted 22 seconds
3779720: Aug 13 11:32:09.049 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 7450932 , call lasted 508 seconds
3779721: Aug 13 11:32:13.969 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7569036 N/A
3779722: Aug 13 11:32:14.621 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:9 is now connected to 7523050 N/A
3779723: Aug 13 11:32:19.825 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:22 is now connected to 7513660 N/A
3779724: Aug 13 11:32:27.025 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:12 is now connected to 7616076 N/A
3779725: Aug 13 11:32:31.593 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 7514884 , call lasted 70 seconds
3779726: Aug 13 11:32:32.745 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:13 is now connected to 9126 N/A
3779727: Aug 13 11:32:35.428 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 7511470 N/A
3779728: Aug 13 11:32:52.468 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:4 is now connected to 7511438 N/A
3779729: Aug 13 11:32:56.184 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 7513620 N/A
3779730: Aug 13 11:32:58.016 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:4  disconnected from 27196389 , call lasted 1910 seconds
3779731: Aug 13 11:32:58.408 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7513087 , call lasted 134 seconds
3779732: Aug 13 11:32:59.540 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:18  disconnected from 7513620 , call lasted 3 seconds
3779733: Aug 13 11:33:01.232 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7511442 N/A
3779734: Aug 13 11:33:13.380 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 7513910 N/A
3779735: Aug 13 11:33:15.508 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:18 is now connected to 7514884 N/A
3779736: Aug 13 11:33:21.100 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7511442 , call lasted 19 seconds
3779737: Aug 13 11:33:28.356 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7450811 N/A
3779738: Aug 13 11:33:43.104 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7512057 N/A
3779739: Aug 13 11:33:43.796 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:4 is now connected to 7412791 N/A
3779740: Aug 13 11:33:45.404 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:22  disconnected from 7513660 , call lasted 85 seconds
3779741: Aug 13 11:33:45.748 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:4  disconnected from 7412791 , call lasted 1 seconds
3779742: Aug 13 11:33:48.108 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7450811 , call lasted 19 seconds
3779743: Aug 13 11:33:57.152 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:4 is now connected to 7513989 N/A
3779744: Aug 13 11:34:08.228 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7513143 , call lasted 142 seconds
3779745: Aug 13 11:34:09.392 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7569036 , call lasted 115 seconds
3779746: Aug 13 11:34:12.072 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7557033 , call lasted 211 seconds
3779747: Aug 13 11:34:15.052 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7513688 N/A
3779748: Aug 13 11:34:20.980 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30  disconnected from 7562867 , call lasted 1584 seconds
3779749: Aug 13 11:34:22.235 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:23  disconnected from 7513910 , call lasted 68 seconds
3779750: Aug 13 11:34:45.575 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:20  disconnected from 7513807 , call lasted 627 seconds
3779751: Aug 13 11:34:48.011 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7513688 , call lasted 32 seconds
3779752: Aug 13 11:34:49.291 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected to 7562867 N/A
3779753: Aug 13 11:34:51.587 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7544848 N/A
3779754: Aug 13 11:34:55.067 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7544848 , call lasted 3 seconds
3779755: Aug 13 11:34:56.131 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:7 is now connected to 7513807 N/A
3779756: Aug 13 11:35:01.563 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:9 is now connected to 7511047 N/A
3779757: Aug 13 11:35:07.051 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:4  disconnected from 7513989 , call lasted 69 seconds
3779758: Aug 13 11:35:07.183 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 751992349273 N/A
3779759: Aug 13 11:35:13.399 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7513287 N/A
3779760: Aug 13 11:35:14.023 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7513663 N/A
3779761: Aug 13 11:35:14.375 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7544848 N/A
3779762: Aug 13 11:35:16.099 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:5 is now connected to 7562903 N/A
3779763: Aug 13 11:35:16.983 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7513663 , call lasted 2 seconds
3779764: Aug 13 11:35:18.195 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7544848 , call lasted 3 seconds
3779765: Aug 13 11:35:19.259 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:6 is now connected to 7562665 N/A
3779766: Aug 13 11:35:20.571 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:11  disconnected from 4320041 , call lasted 1811 seconds
3779767: Aug 13 11:35:21.283 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:10  disconnected from 2999 , call lasted 1863 seconds
3779768: Aug 13 11:35:21.823 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:3  disconnected from 2999 , call lasted 2145 seconds
3779769: Aug 13 11:35:21.959 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 751998779327 N/A
3779770: Aug 13 11:35:31.283 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:3 is now connected to 7558177 N/A
3779771: Aug 13 11:35:37.291 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7450813 , call lasted 403 seconds
3779772: Aug 13 11:35:41.599 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7513287 , call lasted 28 seconds
3779773: Aug 13 11:35:44.787 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7511466 N/A
3779774: Aug 13 11:35:48.159 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7511466 , call lasted 3 seconds
3779775: Aug 13 11:35:56.067 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 751998779327 , call lasted 34 seconds
3779776: Aug 13 11:35:57.543 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:4 is now connected to 7412730 N/A
3779777: Aug 13 11:36:00.087 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30  disconnected from 7562867 , call lasted 70 seconds
3779778: Aug 13 11:36:00.223 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7511526 N/A
3779779: Aug 13 11:36:06.411 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 751992349273 , call lasted 59 seconds
3779780: Aug 13 11:36:11.374 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7512057 , call lasted 148 seconds
3779781: Aug 13 11:36:21.070 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7513157 , call lasted 735 seconds
3779782: Aug 13 11:36:22.550 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected to 751967372630 N/A
3779783: Aug 13 11:36:25.654 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:10 is now connected to 7511088 N/A
3779784: Aug 13 11:36:40.594 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7544848 N/A
3779785: Aug 13 11:36:45.170 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7544848 , call lasted 4 seconds
3779786: Aug 13 11:36:49.562 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to N/A N/A
3779787: Aug 13 11:36:59.514 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7513256 N/A
3779788: Aug 13 11:37:06.006 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:26  disconnected from 7511526 , call lasted 65 seconds
3779789: Aug 13 11:37:15.170 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:19  disconnected from 7511476 , call lasted 315 seconds
3779790: Aug 13 11:37:15.530 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7511366 , call lasted 560 seconds
3779791: Aug 13 11:37:34.458 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:1  disconnected from 7511876 , call lasted 864 seconds
3779792: Aug 13 11:37:37.026 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7562665 , call lasted 137 seconds
3779793: Aug 13 11:37:44.766 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:26 is now connected to 7513967 N/A
3779794: Aug 13 11:37:50.086 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7513074 N/A
3779795: Aug 13 11:37:50.958 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:1 is now connected to 7512067 N/A
3779796: Aug 13 11:37:52.062 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7513074 , call lasted 1 seconds
3779797: Aug 13 11:37:57.233 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:6 is now connected to 7513670 N/A
3779798: Aug 13 11:37:59.321 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7513670 , call lasted 2 seconds
3779799: Aug 13 11:38:02.413 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:7 is now connected to 7544848 N/A
3779800: Aug 13 11:38:05.037 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:7  disconnected from 7544848 , call lasted 2 seconds
3779801: Aug 13 11:38:29.209 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:3  disconnected from 7511932 , call lasted 1807 seconds
3779802: Aug 13 11:38:43.073 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:11 is now connected to 7513637 N/A
3779803: Aug 13 11:38:49.593 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:8  disconnected from 7513259 , call lasted 434 seconds
3779804: Aug 13 11:38:54.789 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:7  disconnected from 7513807 , call lasted 238 seconds
3779805: Aug 13 11:38:55.233 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:3 is now connected to 7544848 N/A
3779806: Aug 13 11:38:56.889 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7578349 N/A
3779807: Aug 13 11:38:57.413 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:3  disconnected from 7544848 , call lasted 2 seconds
3779808: Aug 13 11:39:06.113 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7578349 , call lasted 9 seconds
3779809: Aug 13 11:39:08.133 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:5  disconnected from 7513939 , call lasted 483 seconds
3779810: Aug 13 11:39:09.713 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7553262 N/A
3779811: Aug 13 11:39:20.885 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:11  disconnected from 7513637 , call lasted 37 seconds
3779812: Aug 13 11:39:41.873 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7511676 N/A
3779813: Aug 13 11:39:42.484 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:8 is now connected to 7511692 N/A
3779814: Aug 13 11:39:51.156 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:8  disconnected from 7511692 , call lasted 8 seconds
3779815: Aug 13 11:40:04.196 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:3 is now connected to 7513017 N/A
3779816: Aug 13 11:40:05.880 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:5 is now connected to 7413544 N/A
3779817: Aug 13 11:40:06.048 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:3  disconnected from 7513017 , call lasted 1 seconds
3779818: Aug 13 11:40:11.720 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7511676 , call lasted 29 seconds
3779819: Aug 13 11:40:14.968 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7553262 , call lasted 65 seconds
3779820: Aug 13 11:40:15.836 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:3 is now connected to 7514847 N/A
3779821: Aug 13 11:40:24.736 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:30  disconnected from 751967372630 , call lasted 242 seconds
3779822: Aug 13 11:40:36.508 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:5  disconnected from 7413544 , call lasted 30 seconds
3779823: Aug 13 11:41:04.272 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:8 is now connected to 7450831 N/A
3779824: Aug 13 11:41:17.616 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:30 is now connected to 7513017 N/A
3779825: Aug 13 11:41:17.724 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:6 is now connected to 7511389 N/A
3779826: Aug 13 11:41:31.499 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7513256 , call lasted 271 seconds
3779827: Aug 13 11:41:34.603 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:3  disconnected from 7514847 , call lasted 78 seconds
3779828: Aug 13 11:41:37.619 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:11 is now connected to 7562690 N/A
3779829: Aug 13 11:41:48.415 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from unknown , call lasted 298 seconds
3779830: Aug 13 11:42:02.579 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:5 is now connected to 7562810 N/A
3779831: Aug 13 11:42:03.595 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7531769 N/A
3779832: Aug 13 11:42:04.435 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7511051 N/A
3779833: Aug 13 11:42:05.091 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7412791 N/A
3779834: Aug 13 11:42:06.107 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7531769 , call lasted 2 seconds
3779835: Aug 13 11:42:07.199 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:3  disconnected from 7511051 , call lasted 2 seconds
3779836: Aug 13 11:42:16.191 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 75761965159 , call lasted 822 seconds
3779837: Aug 13 11:42:18.027 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:18  disconnected from 7514884 , call lasted 542 seconds
3779838: Aug 13 11:42:24.255 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7511332 N/A
3779839: Aug 13 11:42:41.939 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:2 is now connected to 7513157 N/A
3779840: Aug 13 11:42:47.683 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:0  disconnected from 7616627 , call lasted 948 seconds
3779841: Aug 13 11:42:51.707 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:3 is now connected to 7511514 N/A
3779842: Aug 13 11:42:54.859 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:3  disconnected from 7511514 , call lasted 3 seconds
3779843: Aug 13 11:42:57.967 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:7 is now connected to 7513118 N/A
3779844: Aug 13 11:43:03.835 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7511521 N/A
3779845: Aug 13 11:43:05.343 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7511862 N/A
3779846: Aug 13 11:43:07.511 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:3 is now connected to 1906 N/A
3779847: Aug 13 11:43:17.974 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:8  disconnected from 7450831 , call lasted 133 seconds
3779848: Aug 13 11:43:23.250 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:8 is now connected to 7450876 N/A
3779849: Aug 13 11:43:26.574 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:9 is now connected to 7574381 N/A
3779850: Aug 13 11:43:27.998 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7511332 , call lasted 63 seconds
3779851: Aug 13 11:43:36.834 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:8 is now connected to 7450811 N/A
3779852: Aug 13 11:43:40.738 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:3  disconnected from 1906 , call lasted 33 seconds
3779853: Aug 13 11:43:45.030 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:0 is now connected to 7513253 N/A
3779854: Aug 13 11:43:47.358 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:9  disconnected from 7574381 , call lasted 20 seconds
3779855: Aug 13 11:44:04.206 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7511098 N/A
3779856: Aug 13 11:44:06.234 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7562567 N/A
3779857: Aug 13 11:44:13.358 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7511989 N/A
3779858: Aug 13 11:44:15.146 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:24  disconnected from 7511989 , call lasted 1 seconds
3779859: Aug 13 11:44:16.894 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:0  disconnected from 7511098 , call lasted 12 seconds
3779860: Aug 13 11:44:18.054 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7511389 , call lasted 180 seconds
3779861: Aug 13 11:44:31.342 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:3 is now connected to 7412475 N/A
3779862: Aug 13 11:44:34.122 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:0 is now connected to 7511476 N/A
3779863: Aug 13 11:44:34.862 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:17 is now connected to 7413495 N/A
3779864: Aug 13 11:44:53.454 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:17  disconnected from 7413495 , call lasted 18 seconds
3779865: Aug 13 11:44:55.614 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:7 is now connected to 5532 N/A
3779866: Aug 13 11:45:00.650 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:10 is now connected to 75628962870 N/A
3779867: Aug 13 11:45:02.185 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:24 is now connected to 7512910 N/A
3779868: Aug 13 11:45:11.833 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:29  disconnected from 7511521 , call lasted 128 seconds
3779869: Aug 13 11:45:15.257 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:10  disconnected from 75628962870 , call lasted 14 seconds
3779870: Aug 13 11:45:16.717 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:8  disconnected from 7450876 , call lasted 113 seconds
3779871: Aug 13 11:45:30.777 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7511862 , call lasted 145 seconds
3779872: Aug 13 11:45:32.929 HKG: %ISDN-6-CONNECT: Interface Serial0/0/1:10 is now connected to 7513047 N/A
3779873: Aug 13 11:45:35.673 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:10  disconnected from 7513047 , call lasted 2 seconds
3779874: Aug 13 11:45:37.561 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:25  disconnected from 7562567 , call lasted 91 seconds
3779875: Aug 13 11:45:37.761 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3779876: Aug 13 11:45:37.849 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3779877: Aug 13 11:45:38.273 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3779878: Aug 13 11:45:39.261 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3779879: Aug 13 11:45:40.233 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3779880: Aug 13 11:45:40.361 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3779881: Aug 13 11:45:40.429 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3779882: Aug 13 11:45:40.929 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3779883: Aug 13 11:45:41.333 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3779884: Aug 13 11:45:41.721 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3779885: Aug 13 11:45:42.277 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3779886: Aug 13 11:45:42.641 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3779887: Aug 13 11:45:42.937 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3779888: Aug 13 11:45:43.141 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3779889: Aug 13 11:45:43.913 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3779890: Aug 13 11:45:44.025 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3779891: Aug 13 11:45:44.745 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3779892: Aug 13 11:45:44.777 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3779893: Aug 13 11:45:44.933 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3779894: Aug 13 11:45:44.993 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/1:4  disconnected from 7511438 , call lasted 772 seconds
3779895: Aug 13 11:45:44.993 HKG: //5338966/5552CC028856/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x29D868EC, Call Id=5338966
3779896: Aug 13 11:45:44.993 HKG: //5338966/5552CC028856/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
3779897: Aug 13 11:45:44.993 HKG: //5338966/5552CC028856/CCAPI/ccConferenceDestroy:
   Conference Id=0x200665, Tag=0x0
3779898: Aug 13 11:45:44.993 HKG: //5338966/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x200665, Source Interface=0x29D868EC, Source Call Id=5338966,
   Destination Call Id=5338967, Disposition=0x0, Tag=0x0
3779899: Aug 13 11:45:44.993 HKG: //5338967/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x200665, Source Interface=0x2968961C, Source Call Id=5338967,
   Destination Call Id=5338966, Disposition=0x0, Tag=0x0
3779900: Aug 13 11:45:44.993 HKG: //5338966/5552CC028856/CCAPI/cc_generic_bridge_done:
3779901: Aug 13 11:45:44.993 HKG: //5338966/5552CC028856/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
3779902: Aug 13 11:45:44.993 HKG: //5338966/5552CC028856/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
3779903: Aug 13 11:45:44.997 HKG: //5338966/5552CC028856/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
3779904: Aug 13 11:45:44.997 HKG: //5338967/5552CC028856/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
3779905: Aug 13 11:45:44.997 HKG: //5338967/5552CC028856/CCAPI/ccCallDisconnect:
3779906: Aug 13 11:45:44.997 HKG: //5338967/5552CC028856/CCAPI/cc_api_get_transfer_info:
3779907: Aug 13 11:45:45.005 HKG: //5338967/5552CC028856/CCAPI/cc_api_get_transfer_info:
3779908: Aug 13 11:45:45.005 HKG: //5338967/5552CC028856/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5338967,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
3779909: Aug 13 11:45:45.005 HKG: //5338967/5552CC028856/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
3779910: Aug 13 11:45:45.005 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3779911: Aug 13 11:45:45.005 HKG: :cc_free_feature_vsa freeing 31C6B058
3779912: Aug 13 11:45:45.005 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3779913: Aug 13 11:45:45.005 HKG:  vsacount in free is 75
3779914: Aug 13 11:45:45.017 HKG: //5338966/5552CC028856/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29D868EC, Tag=0x0, Call Id=5338966,
3779915: Aug 13 11:45:45.017 HKG: //5338966/5552CC028856/CCAPI/cc_api_call_disconnect_done:
3779916: Aug 13 11:45:45.017 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3779917: Aug 13 11:45:45.017 HKG: :cc_free_feature_vsa freeing 31C6B138
3779918: Aug 13 11:45:45.017 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3779919: Aug 13 11:45:45.017 HKG:  vsacount in free is 74
3779920: Aug 13 11:45:45.149 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3779921: Aug 13 11:45:46.141 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3779922: Aug 13 11:45:46.821 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3779923: Aug 13 11:45:47.149 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3779924: Aug 13 11:45:47.173 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3779925: Aug 13 11:45:47.253 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3779926: Aug 13 11:45:47.929 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3779927: Aug 13 11:45:48.749 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3779928: Aug 13 11:45:49.233 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3779929: Aug 13 11:45:49.709 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3779930: Aug 13 11:45:50.425 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3779931: Aug 13 11:45:51.457 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3779932: Aug 13 11:45:51.685 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3779933: Aug 13 11:45:51.921 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3779934: Aug 13 11:45:52.081 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3779935: Aug 13 11:45:52.753 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3779936: Aug 13 11:45:53.197 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3779937: Aug 13 11:45:53.705 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3779938: Aug 13 11:45:54.457 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3779939: Aug 13 11:45:54.589 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3779940: Aug 13 11:45:55.317 HKG: //-1/0061EE52BD4A/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Catherine TEO
   ----- ccCallInfo IE subfields -----
   cisco-ani=7521161
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7513150
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
3779941: Aug 13 11:45:55.317 HKG: //-1/0061EE52BD4A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2968961C, Call Info(
   Calling Number=7521161,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513150(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=752001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=5339187
3779942: Aug 13 11:45:55.317 HKG: //-1/0061EE52BD4A/CCAPI/ccCheckClipClir:
   In: Calling Number=7521161(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3779943: Aug 13 11:45:55.317 HKG: //-1/0061EE52BD4A/CCAPI/ccCheckClipClir:
   Out: Calling Number=7521161(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3779944: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3779945: Aug 13 11:45:55.317 HKG: :cc_get_feature_vsa malloc success
3779946: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3779947: Aug 13 11:45:55.317 HKG:  cc_get_feature_vsa count is 75
3779948: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3779949: Aug 13 11:45:55.317 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835105088,feature_id:5342262
3779950: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7521161(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513150(TON=Unknown, NPI=Unknown))
3779951: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/cc_process_call_setup_ind:
   Event=0x310E6BB8
3779952: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7513150
3779953: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallSetContext:
   Context=0x31AFB990
3779954: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339187 with tag 752001 to app "_ManagedAppProcess_Default"
3779955: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallProceeding:
3779956: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=700001, Params=0x31ABCA7C, Progress Indication=NULL(0)
3779957: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCheckClipClir:
3779958: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCheckClipClir:
3779959: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallSetupRequest:
   Destination Pattern=7T, Called Number=7513150, Digit Strip=TRUE
3779960: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Catherine TEO
   Account Number=Catherine TEO, Final Destination Flag=TRUE,
   Guid=0061EE52-73DF-A13E-BD4A-970316795A0F, Outgoing Dial-peer=700001
3779961: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=7521161
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7513150
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3779962: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x29CCE8B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=7521161,(Calling Name=Catherine TEO)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513150(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=700001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
3779963: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3779964: Aug 13 11:45:55.317 HKG: :cc_get_feature_vsa malloc success
3779965: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3779966: Aug 13 11:45:55.317 HKG:  cc_get_feature_vsa count is 76
3779967: Aug 13 11:45:55.317 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3779968: Aug 13 11:45:55.317 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835104864,feature_id:5342263
3779969: Aug 13 11:45:55.317 HKG: //5339188/0061EE52BD4A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
3779970: Aug 13 11:45:55.317 HKG: //5339188/0061EE52BD4A/CCAPI/ccCallSetContext:
   Context=0x31ABCA2C
3779971: Aug 13 11:45:55.317 HKG: //5339187/0061EE52BD4A/CCAPI/ccSaveDialpeerTag:
3779972: Aug 13 11:45:55.405 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_call_proceeding:
   Interface=0x29CCE8B8, Progress Indication=NULL(0)
3779973: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_call_alert:
   Interface=0x29CCE8B8, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
3779974: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
3779975: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallAlert:
3779976: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
3779977: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
3779978: Aug 13 11:45:55.657 HKG: //5339187/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A51582C, callID1=0x517833, callID2=0x517834, tag=0x0)
3779979: Aug 13 11:45:55.657 HKG: //5339187/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A51582C, callID1=0x517833, gcid=0-0-0-0, tag=0x0)
3779980: Aug 13 11:45:55.657 HKG: //5339188/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A51582C, callID2=0x517834, gcid=0-0-0-0, tag=0x0)
3779981: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/ccConferenceCreate:
   Conference Id=0x2A51582C, Call Id1=5339187, Call Id2=5339188, Tag=0x0
3779982: Aug 13 11:45:55.657 HKG: //5339187/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3779983: Aug 13 11:45:55.657 HKG: cc_api_get_xcode_stream : 4534
3779984: Aug 13 11:45:55.657 HKG: //5339187/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B3, Source Interface=0x2968961C, Source Call Id=5339187,
   Destination Call Id=5339188, Disposition=0x0, Tag=0x0
3779985: Aug 13 11:45:55.657 HKG: //5339188/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B3, Source Interface=0x29CCE8B8, Source Call Id=5339188,
   Destination Call Id=5339187, Disposition=0x0, Tag=0xFFFFFFFF
3779986: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/cc_generic_bridge_done:
3779987: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B3, Destination Call Id=5339188)
3779988: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B3, Destination Call Id=5339187)
3779989: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339187, Source Call Id=5339188,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
3779990: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
3779991: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339187
3779992: Aug 13 11:45:55.657 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_get_called_ccm_detected:
3779993: Aug 13 11:45:55.657 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
3779994: Aug 13 11:45:55.661 HKG: //5339187/0061EE52BD4A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B3, Call Id1=5339187, Call Id2=5339188
3779995: Aug 13 11:45:55.733 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3779996: Aug 13 11:45:56.105 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3779997: Aug 13 11:45:56.177 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3779998: Aug 13 11:45:56.469 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3779999: Aug 13 11:45:57.041 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780000: Aug 13 11:45:57.057 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780001: Aug 13 11:45:57.153 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780002: Aug 13 11:45:57.861 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780003: Aug 13 11:45:58.337 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780004: Aug 13 11:45:58.617 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780005: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780006: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780007: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780008: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7571150@22.121.5.4:5060;transport=tcp SIP/2.0
Date: Wed, 13 Aug 2014 03:45:59 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <sip:7523050@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68742143
Allow-Events: presence, kpml
P-Asserted-Identity: "Meeting Place " <sip:3050@22.121.6.1>
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 0330139450-0567349732-2285719613-3846689392
Remote-Party-ID: "Meeting Place " <sip:3050@22.121.6.1>;party=calling;screen=yes;privacy=off
Content-Length: 208
User-Agent: Cisco-CUCM7.1
To: "Zainab Ansari" <sip:7571150@22.121.5.4>;tag=9BC640AC-22D
Contact: <sip:7523050@22.121.6.1:5060;transport=tcp>;isfocus
Expires: 180
Content-Type: application/sdp
Call-ID: 13AEC18F-21D111E4-BAC9D61B-FD97BF00@22.121.5.4
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4938db41c1
CSeq: 101 INVITE
Session-Expires:  1800;refresher=uac
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 22.121.6.1
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
m=audio 20382 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
3780009: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780010: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313B16C0
3780011: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780012: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780013: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780014: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780015: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
3780016: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Name to Meeting Place
3780017: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 3050
3780018: Aug 13 11:45:59.041 HKG: //5338912/13AD873A883D/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=5338912
3780019: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3780020: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
3780021: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPINegotiateSessionExpires: Min-SE Header: 1800
3780022: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPINegotiateSessionExpires:
Session-Expires value: 1800 refresher: 1
3780023: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPI_ipip_Add_SessionExpiresParamsToContainer: Session-refresh parameters added to container minse = 1800 session expire = 1800 refresher = 1
3780024: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
3780025: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
3780026: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: Attribute mid, level 1 instance 1 not found.
3780027: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3780028: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780029: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3780030: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3780031: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3780032: Aug 13 11:45:59.041 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3780033: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3780034: Aug 13 11:45:59.041 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3780035: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
3780036: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
3780037: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3780038: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3780039: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3780040: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
    stream_type=voice+dtmf (1), dest_ip_address=22.121.7.3, dest_port=20382
3780041: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3780042: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=20382 new=20382
3780043: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPIGetNewLocalMediaDirection:
    New Remote Media Direction = SENDRECV
    Present Local Media Direction = SENDRECV
    New Local Media Direction = SENDRECV
    retVal = 0
3780044: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
3780045: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
3780046: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: Entry
3780047: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
3780048: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
3780049: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3780050: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3780051: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Preferred Codec        : g711ulaw, bytes :160
    Preferred  DTMF relay  : rtp-nte
    Preferred NTE payload  : 101
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : Yes
    New Media              : No
    DSP DNLD Reqd          : No
3780052: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3780053: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780054: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Stream type            : voice+dtmf
      Media line             : 1
      State                  : STREAM_ACTIVE (5)
      Stream address type    : 1
      Callid                 : 5338913
      Negotiated Codec       : g711ulaw, bytes :160
      Nego. Codec payload    : 0 (tx), 0 (rx)
      Negotiated DTMF relay  : rtp-nte
      Negotiated NTE payload : 101 (tx), 101 (rx)
      Negotiated CN payload  : 0
      Media Srce Addr/Port   : [22.121.5.4]:28360
      Media Dest Addr/Port   : [22.121.7.3]:20382
3780055: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/is_call_held: Remote media IP addr: 22.121.7.3
3780056: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/is_call_held: Media IP Addr 22.121.7.3, RTCP Type 3
3780057: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
3780058: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
3780059: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=28360
3780060: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
3780061: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 28360
3780062: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
 SIP update src sdp, negoitated codec 5, payload type 0
3780063: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
3780064: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_api_request_offer: Deffering QoS
                                reservation for MID-CALL Invite
3780065: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_api_request_offer: Response 200 OK for TDM
3780066: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
3780067: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateSDPQoSAttributes: 4 a-line(s) found for stream 1
3780068: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 346, curr send SDP size =
              238
3780069: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
              is not same.. so no comparision is done..
3780070: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 0,
                         new version id = 1
3780071: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
3780072: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIUpdateCallInfoforDelayReconnect:
sipSPIUpdateCallInfoforDelayReconnect: callID 5338913
3780073: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/State/sipSPIChangeState: 0x313B16C0 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
3780074: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
3780075: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPISendInviteResponse: Associated container=0x31511728 to Invite Response 100
3780076: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Transport/sipSPITransportSendMessage: msg=0x2A7501E8, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x0
3780077: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780078: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780079: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A7501E8, addr=22.121.6.1, port=39173, connId=2 for TCP
3780080: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIProcessContactInfo: Previous Hop 22.121.6.1:5060
3780081: Aug 13 11:45:59.045 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
3780082: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/act_handle_app_media_event: method = 102 state = 16
3780083: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
3780084: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 22.121.7.3, RTCP Type 3
3780085: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3780086: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5338913
3780087: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5338913
3780088: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
3780089: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
3780090: Aug 13 11:45:59.045 HKG: //5338913/13AD873A883D/SIP/Info/sipSPISendInviteResponse: Associated container=0x3150FBA8 to Invite Response 200
3780091: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
3780092: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Transport/sipSPITransportSendMessage: msg=0x2A516194, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x249C2C40
3780093: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780094: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780095: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A516194, addr=22.121.6.1, port=39173, connId=2 for TCP
3780096: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
3780097: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
3780098: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: "Zainab Ansari" <sip:7571150@22.121.5.4>;party=called;screen=yes;privacy=off
Contact: <sip:3050@22.121.5.4:5060;transport=tcp>
Supported: replaces
Supported: sdp-anat
Require: timer
Content-Length: 238
v=0
o=CiscoSystemsSIP-GW-UserAgent 3603 1 IN IP4 22.121.5.4
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
m=audio 28360 RTP/AVP 0 101
c=IN IP4 22.121.5.4
a=fmtp:101 0-16
a=ptime:20
3780099: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780100: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780101: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780102: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3050@22.121.5.4:5060;transport=tcp SIP/2.0
Content-Length: 0
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4951f6a84ad
CSeq: 101 ACK
Max-Forwards: 70
3780103: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780104: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313B16C0
3780105: Aug 13 11:45:59.049 HKG: //5338913/13AD873A883D/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780106: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780107: Aug 13 11:45:59.049 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780108: Aug 13 11:45:59.053 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780109: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
3780110: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/State/sipSPIChangeState: 0x313B16C0 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
3780111: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/sipSPICreateAndStartRtpTimer:
3780112: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
3780113: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start resume start notifivation
3780114: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIResumeStartNotificationRequest: sipSPIResumeStartNotificationRequest: Resume Type=Unknown
3780115: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/CCAPI/cc_api_call_facility:
   Interface=0x30D62BB0, Call Id=5338913
3780116: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
3780117: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIProcessRsvp: Entry
3780118: Aug 13 11:45:59.053 HKG: //5338913/13AD873A883D/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
3780119: Aug 13 11:45:59.673 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780120: Aug 13 11:45:59.681 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780121: Aug 13 11:45:59.685 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780122: Aug 13 11:46:01.105 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780123: Aug 13 11:46:01.121 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780124: Aug 13 11:46:01.737 HKG: //-1/2DC00B2E88CB/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=7544819
   cisco-anitype=3
   cisco-aniplan=9
   cisco-anipi=0
   cisco-anisi=0
   dest=7528518
   cisco-desttype=3
   cisco-destplan=9
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780125: Aug 13 11:46:01.737 HKG: //-1/2DC00B2E88CB/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x29E03770, Call Info(
   Calling Number=7544819,(Calling Name=)(TON=Network, NPI=Private, Screening=Not Screened, Presentation=Allowed),
   Called Number=7528518(TON=Network, NPI=Private),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=700001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
3780126: Aug 13 11:46:01.737 HKG: //-1/2DC00B2E88CB/CCAPI/ccCheckClipClir:
   In: Calling Number=7544819(TON=Network, NPI=Private, Screening=Not Screened, Presentation=Allowed)
3780127: Aug 13 11:46:01.737 HKG: //-1/2DC00B2E88CB/CCAPI/ccCheckClipClir:
   Out: Calling Number=7544819(TON=Network, NPI=Private, Screening=Not Screened, Presentation=Allowed)
3780128: Aug 13 11:46:01.737 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780129: Aug 13 11:46:01.737 HKG: :cc_get_feature_vsa malloc success
3780130: Aug 13 11:46:01.737 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780131: Aug 13 11:46:01.737 HKG:  cc_get_feature_vsa count is 77
3780132: Aug 13 11:46:01.737 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780133: Aug 13 11:46:01.737 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835108000,feature_id:5342264
3780134: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7544819(TON=Network, NPI=Private, Screening=Not Screened, Presentation=Allowed),
   Called Number=7528518(TON=Network, NPI=Private))
3780135: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_process_call_setup_ind:
   Event=0x310E75C0
3780136: Aug 13 11:46:01.737 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7528518
3780137: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallSetContext:
   Context=0x2A938938
3780138: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339190 with tag 700001 to app "_ManagedAppProcess_Default"
3780139: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallProceeding:
3780140: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=752001, Params=0x2A8A40BC, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
3780141: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCheckClipClir:
3780142: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCheckClipClir:
3780143: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallSetupRequest:
   Destination Pattern=752T, Called Number=7528518, Digit Strip=FALSE
3780144: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallSetupRequest:
   Account Number=, Final Destination Flag=TRUE,
   Guid=2DC00B2E-21D3-11E4-88CB-503DE547D270, Outgoing Dial-peer=752001
3780145: Aug 13 11:46:01.737 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=7544819
   cisco-anitype=3
   cisco-aniplan=9
   cisco-anipi=0
   cisco-anisi=0
   dest=7528518
   cisco-desttype=3
   cisco-destplan=9
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780146: Aug 13 11:46:01.741 HKG: //5339190/2DC00B2E88CB/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2968961C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=7544819,(Calling Name=)(TON=Network, NPI=Private, Screening=Not Screened, Presentation=Allowed),
   Called Number=7528518(TON=Network, NPI=Private), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=752001, Call Count On=FALSE,
3780147: Aug 13 11:46:01.741 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780148: Aug 13 11:46:01.741 HKG: :cc_get_feature_vsa malloc success
3780149: Aug 13 11:46:01.741 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780150: Aug 13 11:46:01.741 HKG:  cc_get_feature_vsa count is 78
3780151: Aug 13 11:46:01.741 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780152: Aug 13 11:46:01.741 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835105312,feature_id:5342265
3780153: Aug 13 11:46:01.741 HKG: //5339191/2DC00B2E88CB/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
3780154: Aug 13 11:46:01.741 HKG: //5339191/2DC00B2E88CB/CCAPI/ccCallSetContext:
   Context=0x2A8A406C
3780155: Aug 13 11:46:01.741 HKG: //5339190/2DC00B2E88CB/CCAPI/ccSaveDialpeerTag:
3780156: Aug 13 11:46:02.185 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780157: Aug 13 11:46:02.193 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
3780158: Aug 13 11:46:02.193 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_proceeding:
   Interface=0x2968961C, Progress Indication=NULL(0)
3780159: Aug 13 11:46:02.193 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780160: Aug 13 11:46:02.905 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_set_called_ccm_detected:
3780161: Aug 13 11:46:02.905 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_set_delay_xport:
   CallInfo(delay xport=TRUE)
3780162: Aug 13 11:46:02.905 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_alert:
   Interface=0x2968961C, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
3780163: Aug 13 11:46:02.909 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_alert:
3780164: Aug 13 11:46:02.909 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallAlert:
3780165: Aug 13 11:46:02.909 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallAlert:
3780166: Aug 13 11:46:02.913 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_set_called_ccm_detected:
3780167: Aug 13 11:46:02.913 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x2968961C, Call Id=5339191
3780168: Aug 13 11:46:02.913 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
3780169: Aug 13 11:46:02.913 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
3780170: Aug 13 11:46:02.913 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339190
3780171: Aug 13 11:46:03.701 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780172: Aug 13 11:46:03.705 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780173: Aug 13 11:46:03.705 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780174: Aug 13 11:46:03.709 HKG: //-1/2EECF1E588CC/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=7513612
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7528081
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780175: Aug 13 11:46:03.709 HKG: //-1/2EECF1E588CC/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=7513612,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7528081(TON=Unknown, NPI=Unknown),
   Incoming Dial-peer=700001, Progress Indication=NULL(0), Calling IE Present=TRUE,
3780176: Aug 13 11:46:03.709 HKG: //-1/2EECF1E588CC/CCAPI/ccCheckClipClir:
   In: Calling Number=7513612(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780177: Aug 13 11:46:03.709 HKG: //-1/2EECF1E588CC/CCAPI/ccCheckClipClir:
   Out: Calling Number=7513612(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780178: Aug 13 11:46:03.709 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780179: Aug 13 11:46:03.709 HKG: :cc_get_feature_vsa malloc success
3780180: Aug 13 11:46:03.709 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780181: Aug 13 11:46:03.709 HKG:  cc_get_feature_vsa count is 79
3780182: Aug 13 11:46:03.709 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780183: Aug 13 11:46:03.709 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835107104,feature_id:5342266
3780184: Aug 13 11:46:03.709 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7513612(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7528081(TON=Unknown, NPI=Unknown))
3780185: Aug 13 11:46:03.709 HKG: //5339192/2EECF1E588CC/CCAPI/cc_process_call_setup_ind:
   Event=0x310E75C0
3780186: Aug 13 11:46:03.709 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7528081
3780187: Aug 13 11:46:03.709 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallSetContext:
   Context=0x2A939C40
3780188: Aug 13 11:46:03.709 HKG: //5339192/2EECF1E588CC/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339192 with tag 700001 to app "_ManagedAppProcess_Default"
3780189: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallProceeding:
3780190: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=752001, Params=0x31B977B0, Progress Indication=NULL(0)
3780191: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccCheckClipClir:
3780192: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccCheckClipClir:
3780193: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallSetupRequest:
   Destination Pattern=752T, Called Number=7528081, Digit Strip=FALSE
3780194: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Ho Khui SIM
   Guid=2EECF1E5-21D3-11E4-88CC-503DE547D270, Outgoing Dial-peer=752001
3780195: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=7513612
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7528081
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780196: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=7513612,(Calling Name=Ho Khui SIM)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7528081(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
3780197: Aug 13 11:46:03.713 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780198: Aug 13 11:46:03.713 HKG: :cc_get_feature_vsa malloc success
3780199: Aug 13 11:46:03.713 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780200: Aug 13 11:46:03.713 HKG:  cc_get_feature_vsa count is 80
3780201: Aug 13 11:46:03.713 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780202: Aug 13 11:46:03.713 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835107328,feature_id:5342267
3780203: Aug 13 11:46:03.713 HKG: //5339193/2EECF1E588CC/CCAPI/ccIFCallSetupRequestPrivate:
3780204: Aug 13 11:46:03.713 HKG: //5339193/2EECF1E588CC/CCAPI/ccCallSetContext:
   Context=0x31B97760
3780205: Aug 13 11:46:03.713 HKG: //5339192/2EECF1E588CC/CCAPI/ccSaveDialpeerTag:
3780206: Aug 13 11:46:03.717 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780207: Aug 13 11:46:04.421 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780208: Aug 13 11:46:04.433 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_set_called_ccm_detected:
3780209: Aug 13 11:46:04.433 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_proceeding:
3780210: Aug 13 11:46:05.237 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_set_called_ccm_detected:
3780211: Aug 13 11:46:05.237 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_set_delay_xport:
3780212: Aug 13 11:46:05.237 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_alert:
3780213: Aug 13 11:46:05.237 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_alert:
3780214: Aug 13 11:46:05.237 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallAlert:
3780215: Aug 13 11:46:05.237 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallAlert:
3780216: Aug 13 11:46:05.237 HKG: //5339192/2EECF1E588CC/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Ring Back,
   Tone Direction=Network, Params=0x0, Call Id=5339192
3780217: Aug 13 11:46:05.245 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_set_called_ccm_detected:
3780218: Aug 13 11:46:05.245 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_notify:
   Data Bitmask=0x7, Interface=0x2968961C, Call Id=5339193
3780219: Aug 13 11:46:05.245 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780220: Aug 13 11:46:05.245 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
3780221: Aug 13 11:46:05.245 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_get_ccm_detected:
3780222: Aug 13 11:46:05.245 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339192
3780223: Aug 13 11:46:05.249 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780224: Aug 13 11:46:06.329 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780225: Aug 13 11:46:06.953 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780226: Aug 13 11:46:06.961 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780227: Aug 13 11:46:07.145 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780228: Aug 13 11:46:07.161 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780229: Aug 13 11:46:07.257 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780230: Aug 13 11:46:08.089 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780231: Aug 13 11:46:08.105 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780232: Aug 13 11:46:09.277 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780233: Aug 13 11:46:09.557 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780234: Aug 13 11:46:09.945 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7412791 , call lasted 244 seconds
3780235: Aug 13 11:46:09.945 HKG: //5339135/00A343C6B64A/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x29CCE8B8, Call Id=5339135
3780236: Aug 13 11:46:09.945 HKG: //5339135/00A343C6B64A/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
3780237: Aug 13 11:46:09.945 HKG: //5339134/00A343C6B64A/CCAPI/ccConferenceDestroy:
   Conference Id=0x200699, Tag=0x0
3780238: Aug 13 11:46:09.945 HKG: //5339134/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x200699, Source Interface=0x2968961C, Source Call Id=5339134,
   Destination Call Id=5339135, Disposition=0x0, Tag=0x0
3780239: Aug 13 11:46:09.945 HKG: //5339135/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x200699, Source Interface=0x29CCE8B8, Source Call Id=5339135,
   Destination Call Id=5339134, Disposition=0x0, Tag=0x0
3780240: Aug 13 11:46:09.945 HKG: //5339134/00A343C6B64A/CCAPI/cc_generic_bridge_done:
3780241: Aug 13 11:46:09.945 HKG: //5339134/00A343C6B64A/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
3780242: Aug 13 11:46:09.945 HKG: //5339134/00A343C6B64A/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
3780243: Aug 13 11:46:09.945 HKG: //5339134/00A343C6B64A/CCAPI/cc_api_get_transfer_info:
3780244: Aug 13 11:46:09.945 HKG: //5339135/00A343C6B64A/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
3780245: Aug 13 11:46:09.945 HKG: //5339135/00A343C6B64A/CCAPI/ccCallDisconnect:
3780246: Aug 13 11:46:10.069 HKG: //5339134/00A343C6B64A/CCAPI/cc_api_get_transfer_info:
3780247: Aug 13 11:46:10.073 HKG: //5339134/00A343C6B64A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5339134,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
3780248: Aug 13 11:46:10.073 HKG: //5339134/00A343C6B64A/CCAPI/cc_api_call_disconnect_done:
3780249: Aug 13 11:46:10.073 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780250: Aug 13 11:46:10.073 HKG: :cc_free_feature_vsa freeing 31C6B678
3780251: Aug 13 11:46:10.073 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780252: Aug 13 11:46:10.073 HKG:  vsacount in free is 79
3780253: Aug 13 11:46:10.073 HKG: //5339135/00A343C6B64A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29CCE8B8, Tag=0x0, Call Id=5339135,
3780254: Aug 13 11:46:10.077 HKG: //5339135/00A343C6B64A/CCAPI/cc_api_call_disconnect_done:
3780255: Aug 13 11:46:10.077 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780256: Aug 13 11:46:10.077 HKG: :cc_free_feature_vsa freeing 31C6DB38
3780257: Aug 13 11:46:10.077 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780258: Aug 13 11:46:10.077 HKG:  vsacount in free is 78
3780259: Aug 13 11:46:11.013 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780260: Aug 13 11:46:11.013 HKG: //5339191/2DC00B2E88CB/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
3780261: Aug 13 11:46:11.017 HKG: //5339193/2EECF1E588CC/CCAPI/ccIsInfoRingback:
3780262: Aug 13 11:46:11.781 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780263: Aug 13 11:46:11.785 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780264: Aug 13 11:46:11.789 HKG: //-1/00C9775CBE4A/CCAPI/cc_api_display_ie_subfields:
   cisco-username=Frances LAU
   cisco-ani=7528292
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7616188
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780265: Aug 13 11:46:11.789 HKG: //-1/00C9775CBE4A/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=7528292,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7616188(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=5339194
3780266: Aug 13 11:46:11.789 HKG: //-1/00C9775CBE4A/CCAPI/ccCheckClipClir:
   In: Calling Number=7528292(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780267: Aug 13 11:46:11.789 HKG: //-1/00C9775CBE4A/CCAPI/ccCheckClipClir:
   Out: Calling Number=7528292(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780268: Aug 13 11:46:11.789 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780269: Aug 13 11:46:11.789 HKG: :cc_get_feature_vsa malloc success
3780270: Aug 13 11:46:11.789 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780271: Aug 13 11:46:11.789 HKG:  cc_get_feature_vsa count is 79
3780272: Aug 13 11:46:11.789 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780273: Aug 13 11:46:11.789 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835115840,feature_id:5342268
3780274: Aug 13 11:46:11.789 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7528292(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7616188(TON=Unknown, NPI=Unknown))
3780275: Aug 13 11:46:11.789 HKG: //5339194/00C9775CBE4A/CCAPI/cc_process_call_setup_ind:
   Event=0x310E75C0
3780276: Aug 13 11:46:11.789 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7616188
3780277: Aug 13 11:46:11.789 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallSetContext:
   Context=0x3196F3B0
3780278: Aug 13 11:46:11.789 HKG: //5339194/00C9775CBE4A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339194 with tag 752001 to app "_ManagedAppProcess_Default"
3780279: Aug 13 11:46:11.789 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallProceeding:
3780280: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=700001, Params=0x2A150D84, Progress Indication=NULL(0)
3780281: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccCheckClipClir:
3780282: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccCheckClipClir:
3780283: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallSetupRequest:
   Destination Pattern=7T, Called Number=7616188, Digit Strip=TRUE
3780284: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Frances LAU
   Account Number=Frances LAU, Final Destination Flag=TRUE,
   Guid=00C9775C-83DF-A13E-BE4A-98031679644F, Outgoing Dial-peer=700001
3780285: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=7528292
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7616188
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780286: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=7528292,(Calling Name=Frances LAU)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7616188(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
3780287: Aug 13 11:46:11.793 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780288: Aug 13 11:46:11.793 HKG: :cc_get_feature_vsa malloc success
3780289: Aug 13 11:46:11.793 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780290: Aug 13 11:46:11.793 HKG:  cc_get_feature_vsa count is 80
3780291: Aug 13 11:46:11.793 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780292: Aug 13 11:46:11.793 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835106432,feature_id:5342269
3780293: Aug 13 11:46:11.793 HKG: //5339195/00C9775CBE4A/CCAPI/ccIFCallSetupRequestPrivate:
3780294: Aug 13 11:46:11.793 HKG: //5339195/00C9775CBE4A/CCAPI/ccCallSetContext:
   Context=0x2A150D34
3780295: Aug 13 11:46:11.793 HKG: //5339194/00C9775CBE4A/CCAPI/ccSaveDialpeerTag:
3780296: Aug 13 11:46:11.801 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780297: Aug 13 11:46:11.801 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780298: Aug 13 11:46:12.597 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_connected:
   Interface=0x2968961C, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
3780299: Aug 13 11:46:12.597 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
3780300: Aug 13 11:46:12.597 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_set_called_ccm_detected:
3780301: Aug 13 11:46:12.597 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_call_notify:
3780302: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=5339190
3780303: Aug 13 11:46:12.601 HKG: //5339190/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x31989ECC, callID1=0x517836, callID2=0x517837, tag=0x0)
3780304: Aug 13 11:46:12.601 HKG: //5339190/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x31989ECC, callID1=0x517836, gcid=2DC00B2E-21D311E4-88CB503D-E547D270, tag=0x0)
3780305: Aug 13 11:46:12.601 HKG: //5339191/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x31989ECC, callID2=0x517837, gcid=2DC00B2E-21D311E4-88CB503D-E547D270, tag=0x0)
3780306: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/ccConferenceCreate:
   Conference Id=0x31989ECC, Call Id1=5339190, Call Id2=5339191, Tag=0x0
3780307: Aug 13 11:46:12.601 HKG: //5339190/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B4, Source Interface=0x29E03770, Source Call Id=5339190,
   Destination Call Id=5339191, Disposition=0x0, Tag=0xFFFFFFFF
3780308: Aug 13 11:46:12.601 HKG: //5339191/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3780309: Aug 13 11:46:12.601 HKG: cc_api_get_xcode_stream : 4534
3780310: Aug 13 11:46:12.601 HKG: //5339191/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B4, Source Interface=0x2968961C, Source Call Id=5339191,
   Destination Call Id=5339190, Disposition=0x0, Tag=0x0
3780311: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_generic_bridge_done:
3780312: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B4, Destination Call Id=5339191)
3780313: Aug 13 11:46:12.601 HKG: //5339191/2DC00B2E88CB/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B4, Destination Call Id=5339190)
3780314: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339191, Source Call Id=5339190,
3780315: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_caps_ind:
3780316: Aug 13 11:46:12.601 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
3780317: Aug 13 11:46:12.601 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_get_ccm_detected:
3780318: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallNotify:
3780319: Aug 13 11:46:12.601 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B4, Call Id1=5339190, Call Id2=5339191
3780320: Aug 13 11:46:12.601 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29E03770, Destination Call Id=5339190, Source Call Id=5339191,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
3780321: Aug 13 11:46:12.601 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_caps_ind:
3780322: Aug 13 11:46:12.605 HKG: //5339191/2DC00B2E88CB/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=6370)
3780323: Aug 13 11:46:12.605 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_caps_ack:
3780324: Aug 13 11:46:12.605 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_connected:
   Connection Handle=0
3780325: Aug 13 11:46:12.605 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_connected:
3780326: Aug 13 11:46:12.605 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_set_called_ccm_detected:
3780327: Aug 13 11:46:12.605 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_notify:
3780328: Aug 13 11:46:12.605 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
3780329: Aug 13 11:46:12.605 HKG: //5339190/2DC00B2E88CB/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
3780330: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/ccGenerateToneInfo:
3780331: Aug 13 11:46:12.609 HKG: //5339192/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x3198A19C, callID1=0x517838, callID2=0x517839, tag=0x0)
3780332: Aug 13 11:46:12.609 HKG: //5339192/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x3198A19C, callID1=0x517838, gcid=2EECF1E5-21D311E4-88CC503D-E547D270, tag=0x0)
3780333: Aug 13 11:46:12.609 HKG: //5339193/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x3198A19C, callID2=0x517839, gcid=2EECF1E5-21D311E4-88CC503D-E547D270, tag=0x0)
3780334: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/ccConferenceCreate:
   Conference Id=0x3198A19C, Call Id1=5339192, Call Id2=5339193, Tag=0x0
3780335: Aug 13 11:46:12.609 HKG: //5339192/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B5, Source Interface=0x29E03770, Source Call Id=5339192,
   Destination Call Id=5339193, Disposition=0x0, Tag=0xFFFFFFFF
3780336: Aug 13 11:46:12.609 HKG: //5339193/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3780337: Aug 13 11:46:12.609 HKG: cc_api_get_xcode_stream : 4534
3780338: Aug 13 11:46:12.609 HKG: //5339193/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B5, Source Interface=0x2968961C, Source Call Id=5339193,
   Destination Call Id=5339192, Disposition=0x0, Tag=0x0
3780339: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/cc_generic_bridge_done:
3780340: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B5, Destination Call Id=5339193)
3780341: Aug 13 11:46:12.609 HKG: //5339193/2EECF1E588CC/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B5, Destination Call Id=5339192)
3780342: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339193, Source Call Id=5339192,
3780343: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_caps_ind:
3780344: Aug 13 11:46:12.609 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
3780345: Aug 13 11:46:12.609 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_get_ccm_detected:
3780346: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallNotify:
3780347: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallConnect:
3780348: Aug 13 11:46:12.609 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallConnect:
3780349: Aug 13 11:46:12.609 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_proceeding:
3780350: Aug 13 11:46:12.613 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_voice_mode_event:
   Call Id=5339190
3780351: Aug 13 11:46:12.613 HKG: //5339190/2DC00B2E88CB/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x2A938938)
3780352: Aug 13 11:46:12.613 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_alert:
   Interface=0x29CCE8B8, Progress Indication=NULL(0), Signal Indication=NOT PRESENT(255)
3780353: Aug 13 11:46:12.613 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_alert:
3780354: Aug 13 11:46:12.613 HKG: //5339192/2EECF1E588CC/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B5, Call Id1=5339192, Call Id2=5339193
3780355: Aug 13 11:46:12.613 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:3 is now connected to 7544819 N/A
3780356: Aug 13 11:46:12.613 HKG: %ISDN-6-CONNECT: Interface Serial0/1/0:6 is now connected to 7513612 N/A
3780357: Aug 13 11:46:12.617 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29E03770, Destination Call Id=5339192, Source Call Id=5339193,
3780358: Aug 13 11:46:12.617 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_caps_ind:
3780359: Aug 13 11:46:12.617 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1291)
3780360: Aug 13 11:46:12.617 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_caps_ack:
3780361: Aug 13 11:46:12.617 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_voice_mode_event:
   Call Id=5339192
3780362: Aug 13 11:46:12.617 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x2A939C40)
3780363: Aug 13 11:46:12.621 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallAlert:
3780364: Aug 13 11:46:12.621 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallAlert:
3780365: Aug 13 11:46:12.621 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_get_called_ccm_detected:
3780366: Aug 13 11:46:12.621 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339194
3780367: Aug 13 11:46:12.621 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_get_called_ccm_detected:
3780368: Aug 13 11:46:12.621 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780369: Aug 13 11:46:12.621 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780370: Aug 13 11:46:12.621 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780371: Aug 13 11:46:12.621 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_get_delay_xport:
3780372: Aug 13 11:46:12.621 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780373: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780374: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780375: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780376: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:3050@22.121.5.4:5060;transport=tcp SIP/2.0
Date: Wed, 13 Aug 2014 03:46:13 GMT
From: <sip:7523050@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68738904
Min-SE:  1800
Cisco-Guid: 3947702899-0567022052-2269401149-3846689392
Content-Length: 208
To: <sip:75628962695@22.121.5.4>;tag=9BAB0118-1C6
Expires: 180
Call-ID: EB4DC69B-21CC11E4-B778D61B-FD97BF00@22.121.5.4
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4984b385b44
CSeq: 103 INVITE
Max-Forwards: 70
v=0
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
m=audio 18298 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
3780377: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780378: Aug 13 11:46:13.453 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313DAF40
3780379: Aug 13 11:46:13.453 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780380: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780381: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780382: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780383: Aug 13 11:46:13.453 HKG: //5338401/EB4D2A738744/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
3780384: Aug 13 11:46:13.453 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Name to Meeting Place
3780385: Aug 13 11:46:13.453 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 3050
3780386: Aug 13 11:46:13.453 HKG: //5338400/EB4D2A738744/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=5338400
3780387: Aug 13 11:46:13.453 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3780388: Aug 13 11:46:13.453 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
3780389: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPINegotiateSessionExpires: Min-SE Header: 1800
3780390: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPINegotiateSessionExpires:
3780391: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPI_ipip_Add_SessionExpiresParamsToContainer: Session-refresh parameters added to container minse = 1800 session expire = 1800 refresher = 1
3780392: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
3780393: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
3780394: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
3780395: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3780396: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780397: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3780398: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3780399: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3780400: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3780401: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3780402: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3780403: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
3780404: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
3780405: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3780406: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3780407: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3780408: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    stream_type=voice+dtmf (1), dest_ip_address=22.121.7.3, dest_port=18298
3780409: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3780410: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=18298 new=18298
3780411: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPIGetNewLocalMediaDirection:
    retVal = 0
3780412: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
3780413: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
3780414: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: Entry
3780415: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
3780416: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
3780417: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3780418: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3780419: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : Yes
    New Media              : No
    DSP DNLD Reqd          : No
3780420: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3780421: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780422: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Media line             : 1
      Callid                 : 5338401
      Media Srce Addr/Port   : [22.121.5.4]:18608
      Media Dest Addr/Port   : [22.121.7.3]:18298
3780423: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/is_call_held: Remote media IP addr: 22.121.7.3
3780424: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/is_call_held: Media IP Addr 22.121.7.3, RTCP Type 3
3780425: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
3780426: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
3780427: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=18608
3780428: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
3780429: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 18608
3780430: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
3780431: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
3780432: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_api_request_offer: Deffering QoS
3780433: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_api_request_offer: Response 200 OK for TDM
3780434: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
3780435: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateSDPQoSAttributes: 4 a-line(s) found for stream 1
3780436: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 241, curr send SDP size =
              241
3780437: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP and curr send SDP are
                  same
3780438: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID not incremented ..
3780439: Aug 13 11:46:13.457 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
3780440: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIUpdateCallInfoforDelayReconnect:
sipSPIUpdateCallInfoforDelayReconnect: callID 5338401
3780441: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/State/sipSPIChangeState: 0x313DAF40 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
3780442: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
3780443: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
3780444: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPISendInviteResponse: Associated container=0x315055F8 to Invite Response 100
3780445: Aug 13 11:46:13.457 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPITransportSendMessage: msg=0x3029EDA0, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x0
3780446: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780447: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780448: Aug 13 11:46:13.461 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3029EDA0, addr=22.121.6.1, port=39173, connId=2 for TCP
3780449: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIProcessContactInfo: Previous Hop 22.121.6.1:5060
3780450: Aug 13 11:46:13.461 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
3780451: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/act_handle_app_media_event: method = 102 state = 16
3780452: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
3780453: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 22.121.7.3, RTCP Type 3
3780454: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3780455: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5338401
3780456: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5338401
3780457: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
3780458: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Event/sipSPICreateRpid: Received Octet3A=0x83 -> Setting ;screen=yes ;privacy=off
3780459: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
3780460: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPISendInviteResponse: Associated container=0x3150CAD8 to Invite Response 200
3780461: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
3780462: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPITransportSendMessage: msg=0x3024EB04, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x249C2C40
3780463: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780464: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780465: Aug 13 11:46:13.461 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3024EB04, addr=22.121.6.1, port=39173, connId=2 for TCP
3780466: Aug 13 11:46:13.461 HKG: //5338401/EB4D2A738744/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
3780467: Aug 13 11:46:13.961 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
3780468: Aug 13 11:46:13.961 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Remote-Party-ID: <sip:75628962695@22.121.5.4>;party=called;screen=yes;privacy=off
Supported: replaces
Supported: sdp-anat
Session-Expires:  1800;refresher=uac
Require: timer
Content-Type: application/sdp
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 1816 6086 IN IP4 22.121.5.4
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
m=audio 18608 RTP/AVP 0 101
c=IN IP4 22.121.5.4
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
3780469: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 208, Bytes Remaining 633
3780470: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5338401
3780471: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5338401
3780472: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Event/sipSPICreateRpid: Received Octet3A=0x83 -> Setting ;screen=yes ;privacy=off
3780473: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
3780474: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPISendInviteResponse: Associated container=0x3150CAD8 to Invite Response 200
3780475: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
3780476: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPITransportSendMessage: msg=0x3024EB04, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x0
3780477: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780478: Aug 13 11:46:13.965 HKG: //5338401/EB4D2A738744/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780479: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3024EB04, addr=22.121.6.1, port=39173, connId=2 for TCP
3780480: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780481: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780482: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780483: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <sip:7523050@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68738906
Allow-Events: presence, kpml
P-Asserted-Identity: "Meeting Place " <sip:3050@22.121.6.1>
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 3951662656-0567022052-2269466685-3846689392
Remote-Party-ID: "Meeting Place " <sip:3050@22.121.6.1>;party=calling;screen=yes;privacy=off
Content-Length: 208
User-Agent: Cisco-CUCM7.1
To: <sip:0212521574@22.121.5.4>;tag=9BAB02A4-1C17
Contact: <sip:7523050@22.121.6.1:5060;transport=tcp>;isfocus
Expires: 180
Call-ID: EB8A3300-21CC11E4-B77ED61B-FD97BF00@22.121.5.4
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e49a52ba595a
CSeq: 103 INVITE
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 22.121.6.1
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
m=audio 17870 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
3780484: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780485: Aug 13 11:46:13.965 HKG: //5338403/EB8996408745/SIP/Info/sipSPICheckFromToRequest: Found matching CB 3137D820
3780486: Aug 13 11:46:13.965 HKG: //5338403/EB8996408745/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780487: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780488: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780489: Aug 13 11:46:13.965 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780490: Aug 13 11:46:13.965 HKG: //5338403/EB8996408745/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
3780491: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Name to Meeting Place
3780492: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 3050
3780493: Aug 13 11:46:13.969 HKG: //5338402/EB8996408745/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=5338402
3780494: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3780495: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
3780496: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPINegotiateSessionExpires: Min-SE Header: 1800
3780497: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPINegotiateSessionExpires:
Session-Expires value: 1800 refresher: 1
3780498: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPI_ipip_Add_SessionExpiresParamsToContainer: Session-refresh parameters added to container minse = 1800 session expire = 1800 refresher = 1
3780499: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
3780500: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
3780501: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: Attribute mid, level 1 instance 1 not found.
3780502: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3780503: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780504: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3780505: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3780506: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3780507: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3780508: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3780509: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3780510: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
3780511: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
3780512: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3780513: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3780514: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3780515: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
    stream_type=voice+dtmf (1), dest_ip_address=22.121.7.3, dest_port=17870
3780516: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3780517: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=17870 new=17870
3780518: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPIGetNewLocalMediaDirection:
    New Remote Media Direction = SENDRECV
    Present Local Media Direction = SENDRECV
    New Local Media Direction = SENDRECV
    retVal = 0
3780519: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
3780520: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
3780521: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: Entry
3780522: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
3780523: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
3780524: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3780525: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3780526: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Preferred Codec        : g711ulaw, bytes :160
    Preferred  DTMF relay  : rtp-nte
    Preferred NTE payload  : 101
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : Yes
    New Media              : No
    DSP DNLD Reqd          : No
3780527: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3780528: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780529: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Stream type            : voice+dtmf
      Media line             : 1
      State                  : STREAM_ACTIVE (5)
      Stream address type    : 1
      Callid                 : 5338403
      Negotiated Codec       : g711ulaw, bytes :160
      Nego. Codec payload    : 0 (tx), 0 (rx)
      Negotiated DTMF relay  : rtp-nte
      Negotiated NTE payload : 101 (tx), 101 (rx)
      Negotiated CN payload  : 0
      Media Srce Addr/Port   : [22.121.5.4]:20394
      Media Dest Addr/Port   : [22.121.7.3]:17870
3780530: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/is_call_held: Remote media IP addr: 22.121.7.3
3780531: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/is_call_held: Media IP Addr 22.121.7.3, RTCP Type 3
3780532: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
3780533: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
3780534: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=20394
3780535: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
3780536: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 20394
3780537: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
 SIP update src sdp, negoitated codec 5, payload type 0
3780538: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
3780539: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/ccsip_api_request_offer: Deffering QoS
                                reservation for MID-CALL Invite
3780540: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/ccsip_api_request_offer: Response 200 OK for TDM
3780541: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
3780542: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateSDPQoSAttributes: 4 a-line(s) found for stream 1
3780543: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 241, curr send SDP size =
              241
3780544: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP and curr send SDP are
                  same
3780545: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID not incremented ..
3780546: Aug 13 11:46:13.969 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
3780547: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIUpdateCallInfoforDelayReconnect:
sipSPIUpdateCallInfoforDelayReconnect: callID 5338403
3780548: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/State/sipSPIChangeState: 0x3137D820 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
3780549: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
3780550: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
3780551: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Info/sipSPISendInviteResponse: Associated container=0x31511780 to Invite Response 100
3780552: Aug 13 11:46:13.969 HKG: //5338403/EB8996408745/SIP/Transport/sipSPITransportSendMessage: msg=0x2A8FCB60, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x0
3780553: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780554: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780555: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A8FCB60, addr=22.121.6.1, port=39173, connId=2 for TCP
3780556: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIProcessContactInfo: Previous Hop 22.121.6.1:5060
3780557: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780558: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780559: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780560: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3050@22.121.5.4:5060;transport=tcp SIP/2.0
Content-Length: 0
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e49c16db5e87
CSeq: 103 ACK
Max-Forwards: 70
3780561: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780562: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313DAF40
3780563: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780564: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780565: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780566: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780567: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
3780568: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/State/sipSPIChangeState: 0x313DAF40 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
3780569: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPICreateAndStartRtpTimer:
3780570: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
3780571: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start resume start notifivation
3780572: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIResumeStartNotificationRequest: sipSPIResumeStartNotificationRequest: Resume Type=Unknown
3780573: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/CCAPI/cc_api_call_facility:
   Interface=0x30D62BB0, Call Id=5338401
3780574: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
3780575: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIProcessRsvp: Entry
3780576: Aug 13 11:46:13.973 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
3780577: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
3780578: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/act_handle_app_media_event: method = 102 state = 16
3780579: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
3780580: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 22.121.7.3, RTCP Type 3
3780581: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3780582: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5338403
3780583: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5338403
3780584: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
3780585: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Event/sipSPICreateRpid: Received Octet3A=0x83 -> Setting ;screen=yes ;privacy=off
3780586: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
3780587: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sipSPISendInviteResponse: Associated container=0x3150B428 to Invite Response 200
3780588: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
3780589: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Transport/sipSPITransportSendMessage: msg=0x31C0DB48, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x249C2C40
3780590: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3780591: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3780592: Aug 13 11:46:13.973 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31C0DB48, addr=22.121.6.1, port=39173, connId=2 for TCP
3780593: Aug 13 11:46:13.973 HKG: //5338403/EB8996408745/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
3780594: Aug 13 11:46:13.973 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780595: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Allow-Events: telephone-event
Contact: <sip:3050@22.121.5.4:5060;transport=tcp>
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Require: timer
Content-Length: 241
v=0
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
c=IN IP4 22.121.5.4
a=fmtp:101 0-16
a=ptime:20
3780596: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 103 INVITE
Content-Length: 0
3780597: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 103 INVITE
Remote-Party-ID: <sip:0212521574@22.121.5.4>;party=called;screen=yes;privacy=off
Supported: replaces
Supported: sdp-anat
Require: timer
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 3585 3968 IN IP4 22.121.5.4
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
m=audio 20394 RTP/AVP 0 101
c=IN IP4 22.121.5.4
a=fmtp:101 0-16
a=ptime:20
3780598: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780599: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780600: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780601: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
CSeq: 103 ACK
Max-Forwards: 70
3780602: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780603: Aug 13 11:46:13.977 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313DAF40
3780604: Aug 13 11:46:13.977 HKG: //5338401/EB4D2A738744/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780605: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780606: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780607: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780608: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3780609: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3780610: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3780611: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e49d6685dce7
CSeq: 103 ACK
Max-Forwards: 70
3780612: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3780613: Aug 13 11:46:13.977 HKG: //5338403/EB8996408745/SIP/Info/sipSPICheckFromToRequest: Found matching CB 3137D820
3780614: Aug 13 11:46:13.977 HKG: //5338403/EB8996408745/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3780615: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780616: Aug 13 11:46:13.977 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3780617: Aug 13 11:46:13.981 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3780618: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
3780619: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/State/sipSPIChangeState: 0x3137D820 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
3780620: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/sipSPICreateAndStartRtpTimer:
3780621: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
3780622: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start resume start notifivation
3780623: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/sipSPIResumeStartNotificationRequest: sipSPIResumeStartNotificationRequest: Resume Type=Unknown
3780624: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/CCAPI/cc_api_call_facility:
   Interface=0x30D62BB0, Call Id=5338403
3780625: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
3780626: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/sipSPIProcessRsvp: Entry
3780627: Aug 13 11:46:13.981 HKG: //5338403/EB8996408745/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
3780628: Aug 13 11:46:14.697 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780629: Aug 13 11:46:15.077 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780630: Aug 13 11:46:15.161 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780631: Aug 13 11:46:16.009 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_cut_progress:
   Interface=0x29CCE8B8, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Signal Indication=INTERCEPT(2),
   Cause Value=0
3780632: Aug 13 11:46:16.009 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
3780633: Aug 13 11:46:16.009 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallCutProgress:
   Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Signal Indication=INTERCEPT(2), Cause Value=0
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=TRUE)
3780634: Aug 13 11:46:16.009 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallCutProgress:
3780635: Aug 13 11:46:16.009 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
3780636: Aug 13 11:46:16.237 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780637: Aug 13 11:46:16.465 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780638: Aug 13 11:46:17.333 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:27 is now connected to 7616188 N/A
3780639: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_connected:
   Interface=0x29CCE8B8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
3780640: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_connected:
3780641: Aug 13 11:46:17.337 HKG: //5339194/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A4B6A04, callID1=0x51783A, callID2=0x51783B, tag=0x0)
3780642: Aug 13 11:46:17.337 HKG: //5339194/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A4B6A04, callID1=0x51783A, gcid=0-0-0-0, tag=0x0)
3780643: Aug 13 11:46:17.337 HKG: //5339195/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A4B6A04, callID2=0x51783B, gcid=0-0-0-0, tag=0x0)
3780644: Aug 13 11:46:17.337 HKG: //5339194/00C9775CBE4A/CCAPI/ccConferenceCreate:
   Conference Id=0x2A4B6A04, Call Id1=5339194, Call Id2=5339195, Tag=0x0
3780645: Aug 13 11:46:17.337 HKG: //5339194/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3780646: Aug 13 11:46:17.337 HKG: cc_api_get_xcode_stream : 4534
3780647: Aug 13 11:46:17.337 HKG: //5339194/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B6, Source Interface=0x2968961C, Source Call Id=5339194,
   Destination Call Id=5339195, Disposition=0x0, Tag=0x0
3780648: Aug 13 11:46:17.337 HKG: //5339195/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B6, Source Interface=0x29CCE8B8, Source Call Id=5339195,
   Destination Call Id=5339194, Disposition=0x0, Tag=0xFFFFFFFF
3780649: Aug 13 11:46:17.337 HKG: //5339194/00C9775CBE4A/CCAPI/cc_generic_bridge_done:
3780650: Aug 13 11:46:17.337 HKG: //5339194/00C9775CBE4A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B6, Destination Call Id=5339195)
3780651: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B6, Destination Call Id=5339194)
3780652: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339194, Source Call Id=5339195,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
3780653: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
3780654: Aug 13 11:46:17.337 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallConnect:
3780655: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_get_called_ccm_detected:
3780656: Aug 13 11:46:17.337 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallConnect:
3780657: Aug 13 11:46:17.337 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallNotify:
3780658: Aug 13 11:46:17.337 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_get_called_ccm_detected:
3780659: Aug 13 11:46:17.341 HKG: //5339194/00C9775CBE4A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B6, Call Id1=5339194, Call Id2=5339195
3780660: Aug 13 11:46:17.341 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780661: Aug 13 11:46:18.101 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780662: Aug 13 11:46:18.105 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780663: Aug 13 11:46:18.113 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780664: Aug 13 11:46:18.117 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29CCE8B8, Destination Call Id=5339195, Source Call Id=5339194,
3780665: Aug 13 11:46:18.117 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_caps_ind:
3780666: Aug 13 11:46:18.117 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7397)
3780667: Aug 13 11:46:18.117 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_caps_ack:
3780668: Aug 13 11:46:18.117 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780669: Aug 13 11:46:18.117 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_voice_mode_event:
   Call Id=5339195
3780670: Aug 13 11:46:18.117 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x2A150D34)
3780671: Aug 13 11:46:18.897 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780672: Aug 13 11:46:18.913 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780673: Aug 13 11:46:19.961 HKG: //-1/007D3C61BF4A/CCAPI/cc_api_display_ie_subfields:
   cisco-username=Charis WONG
   ----- ccCallInfo IE subfields -----
   cisco-ani=7528941
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7513902
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
3780674: Aug 13 11:46:19.961 HKG: //-1/007D3C61BF4A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2968961C, Call Info(
   Calling Number=7528941,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513902(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=752001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=5339198
3780675: Aug 13 11:46:19.961 HKG: //-1/007D3C61BF4A/CCAPI/ccCheckClipClir:
   In: Calling Number=7528941(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780676: Aug 13 11:46:19.961 HKG: //-1/007D3C61BF4A/CCAPI/ccCheckClipClir:
   Out: Calling Number=7528941(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780677: Aug 13 11:46:19.961 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780678: Aug 13 11:46:19.961 HKG: :cc_get_feature_vsa malloc success
3780679: Aug 13 11:46:19.961 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780680: Aug 13 11:46:19.961 HKG:  cc_get_feature_vsa count is 81
3780681: Aug 13 11:46:19.961 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780682: Aug 13 11:46:19.961 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835114944,feature_id:5342270
3780683: Aug 13 11:46:19.961 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7528941(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513902(TON=Unknown, NPI=Unknown))
3780684: Aug 13 11:46:19.961 HKG: //5339198/007D3C61BF4A/CCAPI/cc_process_call_setup_ind:
   Event=0x310E4DA0
3780685: Aug 13 11:46:19.961 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7513902
3780686: Aug 13 11:46:19.961 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallSetContext:
   Context=0x31ABB724
3780687: Aug 13 11:46:19.961 HKG: //5339198/007D3C61BF4A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339198 with tag 752001 to app "_ManagedAppProcess_Default"
3780688: Aug 13 11:46:19.961 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallProceeding:
3780689: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=700001, Params=0x2A7165C0, Progress Indication=NULL(0)
3780690: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccCheckClipClir:
3780691: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccCheckClipClir:
3780692: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallSetupRequest:
   Destination Pattern=7T, Called Number=7513902, Digit Strip=TRUE
3780693: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Charis WONG
   Account Number=Charis WONG, Final Destination Flag=TRUE,
   Guid=007D3C61-8BDF-A13E-BF4A-990316792AAE, Outgoing Dial-peer=700001
3780694: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=7528941
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7513902
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780695: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x29CCE8B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=7528941,(Calling Name=Charis WONG)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513902(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=700001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
3780696: Aug 13 11:46:19.965 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780697: Aug 13 11:46:19.965 HKG: :cc_get_feature_vsa malloc success
3780698: Aug 13 11:46:19.965 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780699: Aug 13 11:46:19.965 HKG:  cc_get_feature_vsa count is 82
3780700: Aug 13 11:46:19.965 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780701: Aug 13 11:46:19.965 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835114720,feature_id:5342271
3780702: Aug 13 11:46:19.965 HKG: //5339199/007D3C61BF4A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
3780703: Aug 13 11:46:19.965 HKG: //5339199/007D3C61BF4A/CCAPI/ccCallSetContext:
   Context=0x2A716570
3780704: Aug 13 11:46:19.965 HKG: //5339198/007D3C61BF4A/CCAPI/ccSaveDialpeerTag:
3780705: Aug 13 11:46:20.753 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_call_proceeding:
3780706: Aug 13 11:46:20.757 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:13  disconnected from 7511403 , call lasted 2202 seconds
3780707: Aug 13 11:46:20.757 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_call_alert:
   Interface=0x29CCE8B8, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
3780708: Aug 13 11:46:20.757 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
3780709: Aug 13 11:46:20.757 HKG: //5338592/160AB8DC879E/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x29E03770, Call Id=5338592
3780710: Aug 13 11:46:20.757 HKG: //5338592/160AB8DC879E/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
3780711: Aug 13 11:46:20.761 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780712: Aug 13 11:46:20.761 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallAlert:
3780713: Aug 13 11:46:20.761 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
3780714: Aug 13 11:46:20.761 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_get_called_ccm_detected:
3780715: Aug 13 11:46:20.761 HKG: //5339198/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x316BA49C, callID1=0x51783E, callID2=0x51783F, tag=0x0)
3780716: Aug 13 11:46:20.761 HKG: //5339198/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x316BA49C, callID1=0x51783E, gcid=0-0-0-0, tag=0x0)
3780717: Aug 13 11:46:20.761 HKG: //5339199/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x316BA49C, callID2=0x51783F, gcid=0-0-0-0, tag=0x0)
3780718: Aug 13 11:46:20.761 HKG: //5339198/007D3C61BF4A/CCAPI/ccConferenceCreate:
   Conference Id=0x316BA49C, Call Id1=5339198, Call Id2=5339199, Tag=0x0
3780719: Aug 13 11:46:20.761 HKG: //5339198/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3780720: Aug 13 11:46:20.761 HKG: cc_api_get_xcode_stream : 4534
3780721: Aug 13 11:46:20.761 HKG: //5339198/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B7, Source Interface=0x2968961C, Source Call Id=5339198,
   Destination Call Id=5339199, Disposition=0x0, Tag=0x0
3780722: Aug 13 11:46:20.761 HKG: //5339199/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B7, Source Interface=0x29CCE8B8, Source Call Id=5339199,
   Destination Call Id=5339198, Disposition=0x0, Tag=0xFFFFFFFF
3780723: Aug 13 11:46:20.761 HKG: //5339198/007D3C61BF4A/CCAPI/cc_generic_bridge_done:
3780724: Aug 13 11:46:20.761 HKG: //5339198/007D3C61BF4A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B7, Destination Call Id=5339199)
3780725: Aug 13 11:46:20.761 HKG: //5339199/007D3C61BF4A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B7, Destination Call Id=5339198)
3780726: Aug 13 11:46:20.761 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339198, Source Call Id=5339199,
3780727: Aug 13 11:46:20.761 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_caps_ind:
3780728: Aug 13 11:46:20.761 HKG: //5338592/160AB8DC879E/CCAPI/ccConferenceDestroy:
   Conference Id=0x2005BE, Tag=0x0
3780729: Aug 13 11:46:20.761 HKG: //5338592/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2005BE, Source Interface=0x29E03770, Source Call Id=5338592,
   Destination Call Id=5338593, Disposition=0x0, Tag=0x0
3780730: Aug 13 11:46:20.761 HKG: //5338593/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2005BE, Source Interface=0x2968961C, Source Call Id=5338593,
   Destination Call Id=5338592, Disposition=0x0, Tag=0x0
3780731: Aug 13 11:46:20.761 HKG: //5338592/160AB8DC879E/CCAPI/cc_generic_bridge_done:
3780732: Aug 13 11:46:20.761 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
3780733: Aug 13 11:46:20.765 HKG: //5339198/007D3C61BF4A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B7, Call Id1=5339198, Call Id2=5339199
3780734: Aug 13 11:46:20.765 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780735: Aug 13 11:46:20.765 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780736: Aug 13 11:46:20.765 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339198
3780737: Aug 13 11:46:20.765 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_get_called_ccm_detected:
3780738: Aug 13 11:46:20.765 HKG: //5338592/160AB8DC879E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
3780739: Aug 13 11:46:20.765 HKG: //5338592/160AB8DC879E/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
3780740: Aug 13 11:46:20.765 HKG: //5338592/160AB8DC879E/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
3780741: Aug 13 11:46:20.765 HKG: //5338593/160AB8DC879E/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
3780742: Aug 13 11:46:20.765 HKG: //5338593/160AB8DC879E/CCAPI/ccCallDisconnect:
3780743: Aug 13 11:46:20.765 HKG: //5338593/160AB8DC879E/CCAPI/cc_api_get_transfer_info:
3780744: Aug 13 11:46:20.769 HKG: //5338593/160AB8DC879E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5338593,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
3780745: Aug 13 11:46:20.769 HKG: //5338593/160AB8DC879E/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
3780746: Aug 13 11:46:20.769 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780747: Aug 13 11:46:20.769 HKG: :cc_free_feature_vsa freeing 31E48D40
3780748: Aug 13 11:46:20.769 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780749: Aug 13 11:46:20.769 HKG:  vsacount in free is 81
3780750: Aug 13 11:46:20.769 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780751: Aug 13 11:46:21.509 HKG: //5338592/160AB8DC879E/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29E03770, Tag=0x0, Call Id=5338592,
3780752: Aug 13 11:46:21.509 HKG: //5338592/160AB8DC879E/CCAPI/cc_api_call_disconnect_done:
3780753: Aug 13 11:46:21.509 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780754: Aug 13 11:46:21.509 HKG: :cc_free_feature_vsa freeing 31E48E20
3780755: Aug 13 11:46:21.509 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3780756: Aug 13 11:46:21.509 HKG:  vsacount in free is 80
3780757: Aug 13 11:46:21.733 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780758: Aug 13 11:46:21.981 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:25 is now connected to 7513902 N/A
3780759: Aug 13 11:46:21.981 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_call_connected:
   Connection Handle=0
3780760: Aug 13 11:46:21.981 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
3780761: Aug 13 11:46:21.981 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
3780762: Aug 13 11:46:21.981 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_get_called_ccm_detected:
3780763: Aug 13 11:46:21.981 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
3780764: Aug 13 11:46:21.981 HKG: //5339198/007D3C61BF4A/CCAPI/ccCallNotify:
3780765: Aug 13 11:46:21.981 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_get_called_ccm_detected:
3780766: Aug 13 11:46:22.801 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29CCE8B8, Destination Call Id=5339199, Source Call Id=5339198,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
3780767: Aug 13 11:46:22.801 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_caps_ind:
3780768: Aug 13 11:46:22.801 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
3780769: Aug 13 11:46:22.805 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_caps_ack:
3780770: Aug 13 11:46:22.809 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_voice_mode_event:
   Call Id=5339199
3780771: Aug 13 11:46:22.809 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x2A716570)
3780772: Aug 13 11:46:23.573 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780773: Aug 13 11:46:23.577 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780774: Aug 13 11:46:23.577 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780775: Aug 13 11:46:23.577 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780776: Aug 13 11:46:23.577 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780777: Aug 13 11:46:23.581 HKG: //-1/3AC524C588CF/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=1
   cisco-anisi=1
   dest=752928369795
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780778: Aug 13 11:46:23.581 HKG: //-1/3AC524C588CF/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x29D868EC, Call Info(
   Calling Number=,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Restricted),
   Called Number=752928369795(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=700002, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
3780779: Aug 13 11:46:23.581 HKG: //-1/3AC524C588CF/CCAPI/ccCheckClipClir:
   In: Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Restricted)
3780780: Aug 13 11:46:23.581 HKG: //-1/3AC524C588CF/CCAPI/ccCheckClipClir:
   Out: Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Restricted)
3780781: Aug 13 11:46:23.581 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780782: Aug 13 11:46:23.581 HKG: :cc_get_feature_vsa malloc success
3780783: Aug 13 11:46:23.581 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780784: Aug 13 11:46:23.581 HKG:  cc_get_feature_vsa count is 81
3780785: Aug 13 11:46:23.581 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780786: Aug 13 11:46:23.581 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835101056,feature_id:5342272
3780787: Aug 13 11:46:23.581 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Restricted),
   Called Number=752928369795(TON=Unknown, NPI=Unknown))
3780788: Aug 13 11:46:23.581 HKG: //5339200/3AC524C588CF/CCAPI/cc_process_call_setup_ind:
   Event=0x310E6BB8
3780789: Aug 13 11:46:23.581 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 752928369795
3780790: Aug 13 11:46:23.581 HKG: //5339200/3AC524C588CF/CCAPI/ccCallSetContext:
   Context=0x2A936328
3780791: Aug 13 11:46:23.581 HKG: //5339200/3AC524C588CF/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339200 with tag 700002 to app "_ManagedAppProcess_Default"
3780792: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccCallProceeding:
3780793: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=752001, Params=0x2A14884C, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
3780794: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccCheckClipClir:
3780795: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccCheckClipClir:
3780796: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccCallSetupRequest:
   Destination Pattern=752T, Called Number=752928369795, Digit Strip=FALSE
3780797: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=SYSTEM
   Account Number=, Final Destination Flag=TRUE,
   Guid=3AC524C5-21D3-11E4-88CF-503DE547D270, Outgoing Dial-peer=752001
3780798: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=1
   cisco-anisi=1
   dest=752928369795
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780799: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x2968961C, Interface Type=1, Destination=, Mode=0x0,
   Call Params(Calling Number=,(Calling Name=SYSTEM)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Restricted),
   Called Number=752928369795(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=752001, Call Count On=FALSE,
3780800: Aug 13 11:46:23.585 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780801: Aug 13 11:46:23.585 HKG: :cc_get_feature_vsa malloc success
3780802: Aug 13 11:46:23.585 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780803: Aug 13 11:46:23.585 HKG:  cc_get_feature_vsa count is 82
3780804: Aug 13 11:46:23.585 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780805: Aug 13 11:46:23.585 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835100832,feature_id:5342273
3780806: Aug 13 11:46:23.585 HKG: //5339201/3AC524C588CF/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=1, FlowMode=1
3780807: Aug 13 11:46:23.585 HKG: //5339201/3AC524C588CF/CCAPI/ccCallSetContext:
   Context=0x2A1487FC
3780808: Aug 13 11:46:23.585 HKG: //5339200/3AC524C588CF/CCAPI/ccSaveDialpeerTag:
3780809: Aug 13 11:46:23.589 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780810: Aug 13 11:46:24.225 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780811: Aug 13 11:46:24.233 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_set_called_ccm_detected:
   CallInfo(called ccm detected=TRUE ccmVersion 3)
3780812: Aug 13 11:46:24.233 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_call_proceeding:
   Interface=0x2968961C, Progress Indication=NULL(0)
3780813: Aug 13 11:46:26.049 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3780814: Aug 13 11:46:26.137 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3780815: Aug 13 11:46:26.141 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3780816: Aug 13 11:46:26.149 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780817: Aug 13 11:46:26.333 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780818: Aug 13 11:46:26.669 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_media_reset_ind:
   Interface=0x0, Call Id=5339198
3780819: Aug 13 11:46:26.677 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_userinfo:
   Interface=0x2968961C, Signal Indication=TONES OFF(63)
3780820: Aug 13 11:46:26.677 HKG: //5339199/007D3C61BF4A/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=5339199
3780821: Aug 13 11:46:26.677 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_userinfo:
   Interface=0x2968961C, Signal Indication=NOT PRESENT(255)
3780822: Aug 13 11:46:26.677 HKG: //5339199/007D3C61BF4A/CCAPI/ccCallUserInfo:
   Call Id=5339199
3780823: Aug 13 11:46:27.049 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_caps_ind:
3780824: Aug 13 11:46:27.049 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_caps_ind:
3780825: Aug 13 11:46:27.049 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=193)
3780826: Aug 13 11:46:27.049 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_caps_ack:
3780827: Aug 13 11:46:27.049 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_voice_mode_event:
   Call Id=5339199
3780828: Aug 13 11:46:27.049 HKG: //5339199/007D3C61BF4A/CCAPI/cc_api_voice_mode_event:
3780829: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_userinfo:
3780830: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_set_called_ccm_detected:
3780831: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_notify:
   Data Bitmask=0x3, Interface=0x2968961C, Call Id=5339198
3780832: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_set_called_ccm_detected:
3780833: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_call_notify:
3780834: Aug 13 11:46:27.053 HKG: //5339199/007D3C61BF4A/CCAPI/ccGenerateToneInfo:
3780835: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
   CallInfo(ssCTreRoutingNotSupported=FALSE)
3780836: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_get_ccm_detected:
   CallInfo(ccm detected=TRUE)
3780837: Aug 13 11:46:27.053 HKG: //5339199/007D3C61BF4A/CCAPI/ccCallNotify:
   Data Bitmask=0x3, Call Id=5339199
3780838: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
3780839: Aug 13 11:46:27.053 HKG: //5339198/007D3C61BF4A/CCAPI/cc_api_get_ccm_detected:
3780840: Aug 13 11:46:27.053 HKG: //5339199/007D3C61BF4A/CCAPI/ccCallNotify:
3780841: Aug 13 11:46:27.053 HKG: //-1/00310166C04A/CCAPI/cc_api_display_ie_subfields:
   cisco-username=Philippe GENNAUX
   cisco-ani=7523364
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7573260
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780842: Aug 13 11:46:27.057 HKG: //-1/00310166C04A/CCAPI/cc_api_call_setup_ind_common:
   Calling Number=7523364,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7573260(TON=Unknown, NPI=Unknown),
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=5339202
3780843: Aug 13 11:46:27.057 HKG: //-1/00310166C04A/CCAPI/ccCheckClipClir:
   In: Calling Number=7523364(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780844: Aug 13 11:46:27.057 HKG: //-1/00310166C04A/CCAPI/ccCheckClipClir:
   Out: Calling Number=7523364(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780845: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780846: Aug 13 11:46:27.057 HKG: :cc_get_feature_vsa malloc success
3780847: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780848: Aug 13 11:46:27.057 HKG:  cc_get_feature_vsa count is 83
3780849: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780850: Aug 13 11:46:27.057 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835103520,feature_id:5342274
3780851: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7523364(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7573260(TON=Unknown, NPI=Unknown))
3780852: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/cc_process_call_setup_ind:
   Event=0x310E1170
3780853: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7573260
3780854: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCallSetContext:
   Context=0x2A93D558
3780855: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339202 with tag 752001 to app "_ManagedAppProcess_Default"
3780856: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCallProceeding:
3780857: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=700001, Params=0x31966EC8, Progress Indication=NULL(0)
3780858: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCheckClipClir:
3780859: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCheckClipClir:
3780860: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCallSetupRequest:
   Destination Pattern=7T, Called Number=7573260, Digit Strip=TRUE
3780861: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Philippe GENNAUX
   Account Number=Philippe GENNAUX, Final Destination Flag=TRUE,
   Guid=00310166-93DF-A13E-C04A-9A0316796D27, Outgoing Dial-peer=700001
3780862: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=7523364
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7573260
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780863: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccIFCallSetupRequestPrivate:
   Call Params(Calling Number=7523364,(Calling Name=Philippe GENNAUX)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7573260(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
3780864: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780865: Aug 13 11:46:27.057 HKG: :cc_get_feature_vsa malloc success
3780866: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780867: Aug 13 11:46:27.057 HKG:  cc_get_feature_vsa count is 84
3780868: Aug 13 11:46:27.057 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780869: Aug 13 11:46:27.057 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835103744,feature_id:5342275
3780870: Aug 13 11:46:27.057 HKG: //5339203/00310166C04A/CCAPI/ccIFCallSetupRequestPrivate:
3780871: Aug 13 11:46:27.057 HKG: //5339203/00310166C04A/CCAPI/ccCallSetContext:
   Context=0x31966E78
3780872: Aug 13 11:46:27.057 HKG: //5339202/00310166C04A/CCAPI/ccSaveDialpeerTag:
3780873: Aug 13 11:46:27.061 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3780874: Aug 13 11:46:27.837 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780875: Aug 13 11:46:27.841 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_call_cut_progress:
   Interface=0x2968961C, Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
3780876: Aug 13 11:46:27.841 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_call_cut_progress:
3780877: Aug 13 11:46:27.841 HKG: //5339201/3AC524C588CF/CCAPI/ccIsInfoRingback:
   Returning dpRingBack=0
3780878: Aug 13 11:46:27.841 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_set_called_ccm_detected:
3780879: Aug 13 11:46:27.841 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_call_alert:
3780880: Aug 13 11:46:27.841 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_call_alert:
3780881: Aug 13 11:46:27.841 HKG: //5339200/3AC524C588CF/CCAPI/ccCallCutProgress:
   Progress Indication=NOT END TO END ISDN(1), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=FALSE)
3780882: Aug 13 11:46:27.841 HKG: //5339200/3AC524C588CF/CCAPI/ccCallCutProgress:
   Call CallAlert;
3780883: Aug 13 11:46:27.841 HKG: //5339200/3AC524C588CF/CCAPI/ccCallAlert:
3780884: Aug 13 11:46:27.841 HKG: //5339200/3AC524C588CF/CCAPI/ccCallAlert:
3780885: Aug 13 11:46:27.841 HKG: //5339200/3AC524C588CF/CCAPI/ccGenerateToneInfo:
   Tone Direction=Network, Params=0x0, Call Id=5339200
3780886: Aug 13 11:46:27.841 HKG: //5339200/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A5C2F6C, callID1=0x517840, callID2=0x517841, tag=0x0)
3780887: Aug 13 11:46:27.841 HKG: //5339200/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A5C2F6C, callID1=0x517840, gcid=3AC524C5-21D311E4-88CF503D-E547D270, tag=0x0)
3780888: Aug 13 11:46:27.841 HKG: //5339201/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A5C2F6C, callID2=0x517841, gcid=3AC524C5-21D311E4-88CF503D-E547D270, tag=0x0)
3780889: Aug 13 11:46:27.841 HKG: //5339200/3AC524C588CF/CCAPI/ccConferenceCreate:
   Conference Id=0x2A5C2F6C, Call Id1=5339200, Call Id2=5339201, Tag=0x0
3780890: Aug 13 11:46:27.845 HKG: //5339200/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B8, Source Interface=0x29D868EC, Source Call Id=5339200,
   Destination Call Id=5339201, Disposition=0x0, Tag=0xFFFFFFFF
3780891: Aug 13 11:46:27.845 HKG: //5339201/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3780892: Aug 13 11:46:27.845 HKG: cc_api_get_xcode_stream : 4534
3780893: Aug 13 11:46:27.845 HKG: //5339201/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B8, Source Interface=0x2968961C, Source Call Id=5339201,
   Destination Call Id=5339200, Disposition=0x0, Tag=0x0
3780894: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/cc_generic_bridge_done:
3780895: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B8, Destination Call Id=5339201)
3780896: Aug 13 11:46:27.845 HKG: //5339201/3AC524C588CF/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B8, Destination Call Id=5339200)
3780897: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339201, Source Call Id=5339200,
3780898: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_caps_ind:
3780899: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/ccCallAlert:
3780900: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/ccCallAlert:
3780901: Aug 13 11:46:27.845 HKG: //5339200/3AC524C588CF/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B8, Call Id1=5339200, Call Id2=5339201
3780902: Aug 13 11:46:27.845 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_set_called_ccm_detected:
3780903: Aug 13 11:46:27.845 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_call_notify:
   Data Bitmask=0x5, Interface=0x2968961C, Call Id=5339201
3780904: Aug 13 11:46:27.849 HKG: //5339203/00310166C04A/CCAPI/cc_api_call_proceeding:
   Interface=0x29CCE8B8, Progress Indication=NULL(0)
3780905: Aug 13 11:46:27.849 HKG: //5339203/00310166C04A/CCAPI/cc_api_call_alert:
3780906: Aug 13 11:46:27.849 HKG: //5339203/00310166C04A/CCAPI/cc_api_call_alert:
3780907: Aug 13 11:46:27.849 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_get_ssCTreRoutingNotSupported:
3780908: Aug 13 11:46:27.849 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_get_ccm_detected:
3780909: Aug 13 11:46:27.849 HKG: //5339200/3AC524C588CF/CCAPI/ccCallNotify:
   Data Bitmask=0x5, Call Id=5339200
3780910: Aug 13 11:46:28.509 HKG: //5339202/00310166C04A/CCAPI/ccCallAlert:
3780911: Aug 13 11:46:28.509 HKG: //5339202/00310166C04A/CCAPI/ccCallAlert:
3780912: Aug 13 11:46:28.509 HKG: //5339203/00310166C04A/CCAPI/cc_api_get_called_ccm_detected:
3780913: Aug 13 11:46:28.509 HKG: //5339202/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x316BA454, callID1=0x517842, callID2=0x517843, tag=0x0)
3780914: Aug 13 11:46:28.509 HKG: //5339202/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x316BA454, callID1=0x517842, gcid=0-0-0-0, tag=0x0)
3780915: Aug 13 11:46:28.509 HKG: //5339203/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x316BA454, callID2=0x517843, gcid=0-0-0-0, tag=0x0)
3780916: Aug 13 11:46:28.509 HKG: //5339202/00310166C04A/CCAPI/ccConferenceCreate:
   Conference Id=0x316BA454, Call Id1=5339202, Call Id2=5339203, Tag=0x0
3780917: Aug 13 11:46:28.509 HKG: //5339202/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3780918: Aug 13 11:46:28.509 HKG: cc_api_get_xcode_stream : 4534
3780919: Aug 13 11:46:28.509 HKG: //5339202/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B9, Source Interface=0x2968961C, Source Call Id=5339202,
   Destination Call Id=5339203, Disposition=0x0, Tag=0x0
3780920: Aug 13 11:46:28.509 HKG: //5339203/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006B9, Source Interface=0x29CCE8B8, Source Call Id=5339203,
   Destination Call Id=5339202, Disposition=0x0, Tag=0xFFFFFFFF
3780921: Aug 13 11:46:28.509 HKG: //5339202/00310166C04A/CCAPI/cc_generic_bridge_done:
3780922: Aug 13 11:46:28.509 HKG: //5339202/00310166C04A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B9, Destination Call Id=5339203)
3780923: Aug 13 11:46:28.509 HKG: //5339203/00310166C04A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006B9, Destination Call Id=5339202)
3780924: Aug 13 11:46:28.509 HKG: //5339203/00310166C04A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339202, Source Call Id=5339203,
3780925: Aug 13 11:46:28.509 HKG: //5339203/00310166C04A/CCAPI/cc_api_caps_ind:
3780926: Aug 13 11:46:28.509 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3780927: Aug 13 11:46:28.509 HKG: //5339202/00310166C04A/CCAPI/cc_api_get_delay_xport:
3780928: Aug 13 11:46:28.513 HKG: //5339202/00310166C04A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006B9, Call Id1=5339202, Call Id2=5339203
3780929: Aug 13 11:46:28.513 HKG: //5339202/00310166C04A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339202
3780930: Aug 13 11:46:28.513 HKG: //5339203/00310166C04A/CCAPI/cc_api_get_called_ccm_detected:
3780931: Aug 13 11:46:29.285 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29D868EC, Destination Call Id=5339200, Source Call Id=5339201,
3780932: Aug 13 11:46:29.285 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_caps_ind:
3780933: Aug 13 11:46:29.285 HKG: //5339201/3AC524C588CF/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=9006)
3780934: Aug 13 11:46:29.285 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_caps_ack:
3780935: Aug 13 11:46:29.285 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3780936: Aug 13 11:46:29.289 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_voice_mode_event:
   Call Id=5339200
3780937: Aug 13 11:46:29.289 HKG: //5339200/3AC524C588CF/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x2A936328)
3780938: Aug 13 11:46:30.069 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3780939: Aug 13 11:46:30.081 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3780940: Aug 13 11:46:30.305 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3780941: Aug 13 11:46:30.345 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3780942: Aug 13 11:46:30.513 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3780943: Aug 13 11:46:30.809 HKG: //-1/3F14A5B588D1/CCAPI/cc_api_display_ie_subfields:
   cisco-username=
   cisco-ani=7622198
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7523047
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780944: Aug 13 11:46:30.809 HKG: //-1/3F14A5B588D1/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x29CCE8B8, Call Info(
   Calling Number=7622198,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7523047(TON=Unknown, NPI=Unknown),
   Incoming Dial-peer=700001, Progress Indication=ORIGINATING SIDE IS NON ISDN(3), Calling IE Present=TRUE,
3780945: Aug 13 11:46:30.809 HKG: //-1/3F14A5B588D1/CCAPI/ccCheckClipClir:
   In: Calling Number=7622198(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780946: Aug 13 11:46:30.809 HKG: //-1/3F14A5B588D1/CCAPI/ccCheckClipClir:
   Out: Calling Number=7622198(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3780947: Aug 13 11:46:30.809 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780948: Aug 13 11:46:30.809 HKG: :cc_get_feature_vsa malloc success
3780949: Aug 13 11:46:30.809 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780950: Aug 13 11:46:30.809 HKG:  cc_get_feature_vsa count is 85
3780951: Aug 13 11:46:30.809 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780952: Aug 13 11:46:30.809 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835100384,feature_id:5342276
3780953: Aug 13 11:46:30.809 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7622198(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7523047(TON=Unknown, NPI=Unknown))
3780954: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/cc_process_call_setup_ind:
   Event=0x310E4DA0
3780955: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7523047
3780956: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallSetContext:
   Context=0x319F3D74
3780957: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339204 with tag 700001 to app "_ManagedAppProcess_Default"
3780958: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallProceeding:
3780959: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallSetupRequest:
   Outgoing Dial-peer=752005, Params=0x319E7F74, Progress Indication=ORIGINATING SIDE IS NON ISDN(3)
3780960: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCheckClipClir:
3780961: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCheckClipClir:
3780962: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallSetupRequest:
   Destination Pattern=7523047, Called Number=7523047, Digit Strip=FALSE
3780963: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=WLG Test
   Guid=3F14A5B5-21D3-11E4-88D1-503DE547D270, Outgoing Dial-peer=752005
3780964: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=
   cisco-ani=7622198
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7523047
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3780965: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x30D62BB0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=7622198,(Calling Name=WLG Test)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7523047(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE, Outgoing Dial-peer=752005, Call Count On=FALSE,
3780966: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780967: Aug 13 11:46:30.813 HKG: :cc_get_feature_vsa malloc success
3780968: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780969: Aug 13 11:46:30.813 HKG:  cc_get_feature_vsa count is 86
3780970: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3780971: Aug 13 11:46:30.813 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835105760,feature_id:5342277
3780972: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x314047C0) with key=[4703] to table
3780973: Aug 13 11:46:30.813 HKG: //5339205/000000000000/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_NONE, SUBSTATE_NONE)  to (STATE_IDLE, SUBSTATE_NONE)
3780974: Aug 13 11:46:30.813 HKG: //5339205/000000000000/SIP/Info/ccsip_call_setup_request: Before processing SETUP REQccb->pld.flags_ipip = 200
3780975: Aug 13 11:46:30.813 HKG: //5339205/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 5339205, peer_callID = 5339204
3780976: Aug 13 11:46:30.813 HKG: //5339205/000000000000/SIP/Info/ccsip_call_setup_request: This is a TDM-IP call: callID= 5339205, peer_callID = 5339204
3780977: Aug 13 11:46:30.813 HKG: //5339205/000000000000/SIP/Info/ccsip_call_setup_request: After processing SETUP REQccb->pld.flags_ipip = 200
3780978: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : 22.121.6.1 target_port : 5060
3780979: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_SETUP
3780980: Aug 13 11:46:30.813 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_call_setup_request: Incrementing call counter in dial-peer [752005]
3780981: Aug 13 11:46:30.813 HKG: //5339205/3F14A5B588D1/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
3780982: Aug 13 11:46:30.813 HKG: //5339205/3F14A5B588D1/CCAPI/ccCallSetContext:
   Context=0x319E7F24
3780983: Aug 13 11:46:30.813 HKG: //5339204/3F14A5B588D1/CCAPI/ccSaveDialpeerTag:
3780984: Aug 13 11:46:30.813 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 2
3780985: Aug 13 11:46:30.813 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUaddccCallIdToTable: Adding call id 517845 to table
3780986: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallConfig: preferred_codec set[0] type :No Codec    bytes: 0
3780987: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallConfig: Media forking disabled
3780988: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICanSetFallbackFlag: Local Fallback is not active
3780989: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallConfig: Using Voice Class Codec, tag = 1
3780990: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
3780991: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetModemConfig:
From Config: Modem NSE payload = 100, Passthrough = 4, Modem relay = 0, Gw-Xid = 1
SPRT latency 200, SPRT Retries = 12, Dict Size = 1024
 String Len = 32, Compress dir = 3
3780992: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallConfig: xcoder high-density disabled
3780993: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallConfig: Flow Mode set to FLOW_THROUGH
3780994: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallConfig: Media forking disabled
3780995: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/preprocessSetup:
 This is a not a SIGO Call -, could be DM call
3780996: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIValidateAndCopyOutboundHost: CCSIP: copy target_host to outbound_host
3780997: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3780998: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 18450 for stream 1
3780999: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
3781000: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
3781001: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_generate_sdp_xcaps_list: Modem Relay and T38 disabled. X-cap not needed
3781002: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIOutgoingCallSDP: Creating recv-only stream for outbound call
3781003: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
3781004: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIProcessRtpSessions: No active streams.
3781005: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_gw_pre_setup_add_sdp_container: SDP container added
3781006: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
3781007: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
3781008: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIAddMLPPServicesInfo: No MLP Info available on incoming leg
3781009: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIPreprocessUriFormat: Url cfg for 1: 2,phone-ctxt=FALSE
3781010: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIShrlGetInstanceInfo: Obtained the call instance 0 for non-shared-line '7523047' with callid: 5339205
3781011: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIAddCiscoGcid: Gcid value not set - not adding header.
3781012: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIAddPrivacyandIdentityInfo: Removing "id" value from Privacy
3781013: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Error/sipSPI_ipip_set_history_info_header: Not SIP2SIP mode
3781014: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/act_idle_continue_call_setup:
3781015: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIRscmsmAvail: Value returned by check is = 0
3781016: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUaddCcbToUACTable: ****Adding to UAC table.
3781017: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUaddCcbToTable: Added to table. ccb=0x314047C0 key=3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.4
3781018: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUsetBillingProfile: sipCallId for billing records = 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.4
3781019: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_proceeding:
   Interface=0x30D62BB0, Progress Indication=NULL(0)
3781020: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 5060, Transport 2, SentBy Port 5060
3781021: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781022: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIgetRegistrarHost: registrar is not configured
3781023: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
SIP: (5339205) Group (a= group line) attribute, level 65535 instance 1 not found.
3781024: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp dont have anat
3781025: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/addAllowHeaderKpml: KPML Subscriptions allowed.
3781026: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISendInvite: Associated container=0x3150ADF8 to Invite
3781027: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPISendInvite: Sending Invite to the transport layer
3781028: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
3781029: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: msg=0x30242E94, addr=22.121.6.1, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x249C1B6C
3781030: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781031: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781032: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x30242E94
3781033: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x30242E94, addr=22.121.6.1, port=5060, connId=3 for TCP
3781034: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sentInviteRequest: Sent Invite in state STATE_IDLE
3781035: Aug 13 11:46:30.817 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sentInviteRequest: Transaction active. Facilities will be queued.
3781036: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_IDLE, SUBSTATE_NONE)  to (STATE_SENT_INVITE, SUBSTATE_NONE)
3781037: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
3781038: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 5339205) to the VOIP RTP library
3781039: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781040: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781041: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
3781042: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 22.121.5.4, lport = 18450, raddr = 0.0.0.0, rport=0, do_rtcp=FALSE
    src_callid = 5339205, dest_callid = -1, stream type = voice+dtmf, stream direction = RECVONLY
    media_ip_addr =  - , vrf tableid = 0 media_addr_type = 1
3781043: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtcpSession: No rtp session, creating a new one
3781044: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICreateRtpSession: sess: 3027B8B4 do_rtcp:0
3781045: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPICreateRtpSession: stun is disabled
3781046: Aug 13 11:46:30.817 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeStreamState: Stream (callid =  5339205)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
3781047: Aug 13 11:46:30.821 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:7523047@22.121.6.1:5060 SIP/2.0
Via: SIP/2.0/TCP 22.121.5.4:5060;branch=z9hG4bK35C5122
Remote-Party-ID: "WLG Test" <sip:7622198@22.121.5.4>;party=calling;screen=yes;privacy=off
From: "WLG Test" <sip:7622198@22.121.5.4>;tag=9BD47898-123
To: <sip:7523047@22.121.6.1>
Date: Wed, 13 Aug 2014 03:46:30 GMT
Call-ID: 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.4
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1058317749-0567480804-2295418941-3846689392
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1407901590
Contact: <sip:7622198@22.121.5.4:5060;transport=tcp>
Expires: 180
Allow-Events: kpml, telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 349
v=0
o=CiscoSystemsSIP-GW-UserAgent 6978 4791 IN IP4 22.121.5.4
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
m=audio 18450 RTP/AVP 0 8 18 100 101
c=IN IP4 22.121.5.4
a=rtpmap:0 PCMU/8000
a=rtpmap:8 PCMA/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
3781048: Aug 13 11:46:31.593 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781049: Aug 13 11:46:31.593 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781050: Aug 13 11:46:31.593 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781051: Aug 13 11:46:31.593 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781052: Aug 13 11:46:31.597 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Allow-Events: presence
Content-Length: 0
CSeq: 101 INVITE
3781053: Aug 13 11:46:31.597 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
3781054: Aug 13 11:46:31.597 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_SENT_INVITE, SUBSTATE_NONE)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
3781055: Aug 13 11:46:31.601 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 0, Bytes Remaining 1319
3781056: Aug 13 11:46:31.601 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 208, Bytes Remaining 542
3781057: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: HEADER LINE READ FAILURE DUE TO RS->EOF
3781058: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
3781059: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
3781060: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 208, Bytes Remaining 233
3781061: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: HEADER LINE READ FAILURE DUE TO RS->EOF
3781062: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
3781063: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
3781064: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781065: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781066: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781067: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781068: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
P-Asserted-Identity: "Meeting Place " <sip:3050@22.121.6.1>
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Remote-Party-ID: "Meeting Place " <sip:3050@22.121.6.1>;party=called;screen=yes;privacy=off
Content-Length: 0
To: <sip:7523047@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
Contact: <sip:7523047@22.121.6.1:5060;transport=tcp>
CSeq: 101 INVITE
3781069: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
3781070: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Meeting Place , current remote number: 3050
3781071: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
3781072: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
3781073: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3781074: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentSDP: No SDP found in inbound container
3781075: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_api_call_alert: SDP Body either absent or ignored in 180 RINGING:- will wait for 200 OK to do negotiation.
3781076: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
3781077: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
3781078: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
3781079: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
3781080: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_alert:
   Interface=0x30D62BB0, Progress Indication=NULL(0), Signal Indication=SIGNAL RINGBACK(1)
3781081: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_alert:
3781082: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/HandleSIP1xxRinging: ccsip_api_call_alert returned: SIP_SUCCESS
3781083: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
3781084: Aug 13 11:46:31.605 HKG: //5339205/3F14A5B588D1/SIP/Info/HandleSIP1xxRinging: Transaction Complete. Lock on Facilities released.
3781085: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781086: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781087: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781088: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781089: Aug 13 11:46:31.605 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Allow-Events: presence, kpml
Content-Length: 208
CSeq: 101 INVITE
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 22.121.6.1
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
m=audio 20372 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
3781090: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
3781091: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Meeting Place , current remote number: 3050
3781092: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
3781093: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_api_update_allowed: UPDATE(1) allowed
3781094: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3781095: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: Attribute mid, level 1 instance 1 not found.
3781096: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781097: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781098: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3781099: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3781100: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3781101: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3781102: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3781103: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3781104: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckDynPayloadUse: Dynamic payload(101) could not be reserved.
3781105: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
3781106: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3781107: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3781108: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3781109: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
    stream_type=voice+dtmf (1), dest_ip_address=22.121.7.3, dest_port=20372
3781110: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3781111: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3781112: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3781113: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Preferred Codec        : g711ulaw, bytes :160
    Preferred  DTMF relay  : sip-kpml
    Preferred NTE payload  : 101
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : No
    New Media              : No
    DSP DNLD Reqd          : No
3781114: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781115: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781116: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Stream type            : voice+dtmf
      Media line             : 1
      State                  : STREAM_ADDING (2)
      Stream address type    : 1
      Callid                 : 5339205
      Negotiated Codec       : g711ulaw, bytes :160
      Nego. Codec payload    : 0 (tx), 0 (rx)
      Negotiated DTMF relay  : rtp-nte
      Negotiated NTE payload : 101 (tx), 101 (rx)
      Negotiated CN payload  : 0
      Media Srce Addr/Port   : [22.121.5.4]:18450
      Media Dest Addr/Port   : [22.121.7.3]:20372
3781117: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
3781118: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
3781119: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
3781120: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
3781121: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_cut_progress:
   Interface=0x30D62BB0, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1),
   Cause Value=0
3781122: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_cut_progress:
   Call Entry(Responsed=TRUE)
3781123: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/HandleSIP1xxSessionProgress: ccsip_api_call_cut_progress returned: SIP_SUCCESS
3781124: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)
3781125: Aug 13 11:46:31.609 HKG: //5339205/3F14A5B588D1/SIP/Info/HandleSIP1xxSessionProgress: Transaction Complete. Lock on Facilities released.
3781126: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781127: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3781128: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3781129: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:7622198@22.121.5.4:5060;transport=tcp SIP/2.0
From: <sip:7523047@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
Event: kpml
Content-Length: 370
User-Agent: Cisco-CUCM7.1
To: "WLG Test" <sip:7622198@22.121.5.4>;tag=9BD47898-123
Contact: <sip:22.121.6.1:5060;transport=tcp>
Expires: 7200
Content-Type: application/kpml-request+xml
Accept: application/kpml-response+xml
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4a13ff55be0
CSeq: 101 SUBSCRIBE
Max-Forwards: 70
<?xml version="1.0" encoding="UTF-8" ?>
<kpml-request xmlns="urn:ietf:params:xml:ns:kpml-request" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:ietf:params:xml:ns:kpml-request kpml-request.xsd" version="1.0">
  <pattern interdigittimer="7260000" persist="persist">
    <regex tag="dtmf">[x*#ABCD]</regex>
  </pattern>
</kpml-request>
3781130: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
3781131: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781132: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781133: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781134: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromServerTable: Searching for SCB in server table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781135: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPINewIncomingSubscription: Entering ...
3781136: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIAddContextToTable: Added context(0x29FFF0A8) with key=[4704] to table
3781137: Aug 13 11:46:31.609 HKG: //0/000000000000/SIP/Info/ccsip_new_scb: Created new scb: 0x29FFF0A8 with id: -1
3781138: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPINewIncomingSubscription: Changing from State: SUBSCRIBE_STATE_IDLE to state SUBSCRIBE_STATE_IDLE
3781139: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
3781140: Aug 13 11:46:31.609 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_IDLE]
3781141: Aug 13 11:46:31.609 HKG: //0/000000000000/SIP/Info/sipSPIHandleIncomingRequest: This is a Call-Context Subscription on CCB(0x314047C0)
3781142: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781143: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sipSPIPutSCBInServerTable: Inserting SCB with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946 into ServerTable
3781144: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x29FFD71C
3781145: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBServerMarker: Server TCB's Marker Updated to: 101SUBSCRIBEz9hG4bK4e4a13ff55be0
3781146: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781147: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_subscribe_idle_new_message: TCB 0x29FFD71C's parent is 0x29FFF0A8
3781148: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBLastRequest: TCB(0x29FFD71C) has claimed possesion of lastReq (0x31C1046C)
3781149: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_subscribe_idle_new_message: TCB 0x29FFD71C's method is 112
3781150: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
3781151: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_edb: Created new edb(0x31426ECC)
3781152: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateEDBEvent: EDB updated with Event Name: kpml Event ID:
3781153: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sipSPICreateNewEDB: Q'd EDB(0x31426ECC) on SCB(0x29FFF0A8)
3781154: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sipSPICreateNewEDB: There are 1 EDB's on edbQ
3781155: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x29FFD71C) on EDB(0x31426ECC)
3781156: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
3781157: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sip_kpml_process_pattern: processing parsed pattern, ptr=0x2A48A8D4
3781158: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sip_kpml_process_regex: processed parsed regex, ptr=0x2A48A928
3781159: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sip_gw_subscribe_server_set_expires_timer: Starting Subscription timer with value: 7200000
3781160: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
3781161: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
3781162: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/act_subscribe_idle_new_message: ccsip_api_subscribe_ind returned: SIP_SUCCESS
3781163: Aug 13 11:46:31.613 HKG: //0/000000000000/SIP/Info/sipSPIPutSCBInSubIDTable: Inserting SCB with key 8 into SubIDTable
3781164: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_subscribe_idle_new_message: Changing from State: SUBSCRIBE_STATE_IDLE to state SUBSCRIBE_STATE_ACTIVE
3781165: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781166: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781167: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781168: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781169: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Supported: replaces
Content-Length: 208
Require:  timer
CSeq: 101 INVITE
Session-Expires:  1800;refresher=uas
v=0
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
a=ptime:20
a=fmtp:101 0-15
3781170: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
3781171: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Meeting Place , current remote number: 3050
3781172: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
3781173: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3781174: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIhandle200OKInvite: Transaction active. Facilities will be queued.
3781175: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIhandle200OKInvite: *** This ccb is the parent
3781176: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
3781177: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUACSessionTimer:
Session-Expires value: 1800 refresher: 2
3781178: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUACSessionTimer:
UAS refresher Timer interval is 1768000
3781179: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIProcessHistoryInfoHeader: No HI headers recvd from app container
3781180: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
3781181: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781182: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781183: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3781184: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3781185: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3781186: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3781187: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3781188: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3781189: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of full named event(NE) match in fmtp list of events.
3781190: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3781191: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3781192: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3781193: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
3781194: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3781195: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=20372 new=20372
3781196: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIGetNewLocalMediaDirection:
    New Remote Media Direction = SENDRECV
    Present Local Media Direction = RECVONLY
    New Local Media Direction = SENDRECV
    retVal = 1
3781197: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:31B80924
3781198: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
3781199: Aug 13 11:46:31.613 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
3781200: Aug 13 11:46:31.613 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3781201: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3781202: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : No
    New Media              : No
    DSP DNLD Reqd          : No
3781203: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781204: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781205: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Media line             : 1
      Callid                 : 5339205
3781206: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
3781207: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connect_media returned: SIP_SUCCESS
3781208: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_PROCEEDING_PROCEEDING)  to (STATE_RECD_PROCEEDING, SUBSTATE_NONE)
3781209: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQSIG: No QSIG Body found in inbound container
3781210: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentQ931: No RawMsg Body found in inbound container
3781211: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateNewRawMsg: No Data to form The Raw Message
3781212: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIShrlCall: Check peer: 752005 for Shared-Line call, callid: 5339205
3781213: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_connected:
   Interface=0x30D62BB0, Data Bitmask=0x81000001, Progress Indication=NULL(0),
   Connection Handle=0
3781214: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_connected:
   Call Entry(Connected=TRUE, Responsed=TRUE, Retry Count=0)
3781215: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIOptionsPing: Session Timer negotiated, not doing Options Ping
3781216: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIhandle200OKInvite: ccsip_api_call_connected returned: SIP_SUCCESS
3781217: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISendAck: Associated container=0x31510338 to Ack
3781218: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
3781219: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
3781220: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: msg=0x297E4430, addr=22.121.6.1, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x249C2F1C
3781221: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781222: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781223: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x297E4430
3781224: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x297E4430, addr=22.121.6.1, port=5060, connId=3 for TCP
3781225: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_RECD_PROCEEDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
3781226: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x314047C0
State of The Call        : STATE_ACTIVE
TCP Sockets Used         : YES
Calling Number           : 7622198
Called Number            : 7523047
Source IP Address (Sig  ): 22.121.5.4
Destn SIP Req Addr:Port  : 22.121.6.1:5060
Destn SIP Resp Addr:Port : 22.121.6.1:5060
Destination Name         : 22.121.6.1
3781227: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 22.121.5.4
Source IP Port    (Media): 18450
Destn  IP Address (Media): 22.121.7.3
Destn  IP Port    (Media): 20372
Orig Destn IP Address:Port (Media): [ - ]:0
3781228: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICallActive: Transaction Complete. Lock on Facilities released.
3781229: Aug 13 11:46:31.617 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
3781230: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 203
3781231: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_SUBSCRIBE_RESP] received in State [SUBSCRIBE_STATE_ACTIVE]
3781232: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781233: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_resp_event: TCB 0x29FFD71C's method is 112
3781234: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x29FFD71C) has claimed possesion of package (0x31AE7630)
3781235: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x29FFD71C and parent: 0x29FFF0A8
3781236: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x31AE7630, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x248DB478
3781237: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781238: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781239: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31AE7630, addr=22.121.6.1, port=39173, connId=2 for TCP
3781240: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBServer: Entering ...
3781241: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
3781242: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x29FFD71C) from EDB(0x31426ECC)
3781243: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x29FFD71C) for reuse
3781244: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
3781245: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
3781246: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x314240E0
3781247: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x314240E0's parent is 0x29FFF0A8
3781248: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 22.121.6.1,Port 5060, Port Present: TRUE, Transport 2, FQDN 651758288
3781249: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781250: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x314240E0's method is 111
3781251: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x314240E0) has claimed possesion of package (0x2A4DBBE0)
3781252: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK35C7101A
3781253: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
3781254: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x314240E0) on EDB(0x31426ECC)
3781255: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
3781256: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
3781257: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x314240E0 and parent: 0x29FFF0A8
3781258: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x2A4DBBE0, addr=22.121.6.1, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x248D9D08
3781259: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781260: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781261: Aug 13 11:46:31.617 HKG: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2A4DBBE0
3781262: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A4DBBE0, addr=22.121.6.1, port=5060, connId=3 for TCP
3781263: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBClient: Entering ...
3781264: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIKickoffTcbReTxTimer: Kicking off ReTx Timer for Client TCB (0x314240E0) with 0 retries and 32000 milliseconds initial retx
3781265: Aug 13 11:46:31.617 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_timer_context: Created timer context(0x31510A70)
3781266: Aug 13 11:46:31.617 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallAlert:
3781267: Aug 13 11:46:31.617 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallAlert:
   Call Entry(Responsed=TRUE, Alert Sent=TRUE)
3781268: Aug 13 11:46:31.621 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3781269: Aug 13 11:46:31.621 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:7523047@22.121.6.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 22.121.5.4:5060;branch=z9hG4bK35C620FE
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
3781270: Aug 13 11:46:31.621 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 13 Aug 2014 03:46:31 GMT
CSeq: 101 SUBSCRIBE
Content-Length: 0
Expires: 7200
3781271: Aug 13 11:46:31.621 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:22.121.6.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 22.121.5.4:5060;branch=z9hG4bK35C7101A
CSeq: 102 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: active
Content-Length: 0
3781272: Aug 13 11:46:31.621 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781273: Aug 13 11:46:31.625 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781274: Aug 13 11:46:31.625 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781275: Aug 13 11:46:31.625 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781276: Aug 13 11:46:31.625 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Supported: replaces
Content-Length: 208
Require:  timer
CSeq: 101 INVITE
v=0
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
a=ptime:20
a=fmtp:101 0-15
3781277: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckResponseExt: INVITE response with no RSEQ - disable IS_REL1XX
3781278: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received current remote name: Meeting Place , current remote number: 3050
3781279: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetInfoFromRpid: Received ;screen=yes ;privacy=off -> Setting Octet3A 0x81, extended_privacy 0x00
3781280: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISendAck: Associated container=0x31510338 to Ack
3781281: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPISendAck: Sending ACK to the transport layer
3781282: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
3781283: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: msg=0x2A12298C, addr=22.121.6.1, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x0
3781284: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781285: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781286: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x2A12298C
3781287: Aug 13 11:46:31.625 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A12298C, addr=22.121.6.1, port=5060, connId=3 for TCP
3781288: Aug 13 11:46:31.625 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallCutProgress:
   Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1), Cause Value=0
   Voice Call Send Alert=TRUE, Call Entry(Alert Sent=TRUE)
3781289: Aug 13 11:46:31.625 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallCutProgress:
3781290: Aug 13 11:46:31.625 HKG: //5339204/3F14A5B588D1/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Network, Params=0x0, Call Id=5339204
3781291: Aug 13 11:46:31.625 HKG: //5339204/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A5C2CE4, callID1=0x517844, callID2=0x517845, tag=0x0)
3781292: Aug 13 11:46:31.625 HKG: //5339204/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A5C2CE4, callID1=0x517844, gcid=3F14A5B5-21D311E4-88D1503D-E547D270, tag=0x0)
3781293: Aug 13 11:46:31.625 HKG: //5339205/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x2A5C2CE4, callID2=0x517845, gcid=3F14A5B5-21D311E4-88D1503D-E547D270, tag=0x0)
3781294: Aug 13 11:46:31.625 HKG: //5339204/3F14A5B588D1/CCAPI/ccConferenceCreate:
   Conference Id=0x2A5C2CE4, Call Id1=5339204, Call Id2=5339205, Tag=0x0
3781295: Aug 13 11:46:31.625 HKG: //5339204/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006BA, Source Interface=0x29CCE8B8, Source Call Id=5339204,
   Destination Call Id=5339205, Disposition=0x0, Tag=0xFFFFFFFF
3781296: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_bridge: confID = 2098874, srcCallID = 5339205, dstCallID = 5339204
3781297: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUupdateCcCallIds: Old src/dest ccCallids: -1/-1, new src/dest ccCallids: 5339205/5339204
3781298: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUupdateCcCallIds: Old streamcallid=5339205, new streamcallid=5339205
3781299: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_gw_set_sipspi_mode: Setting SPI mode to SIP-TDM
3781300: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_bridge: xcoder_attached = 0, xmitFunc = 614665076, ccb xmitFunc = 614665076
3781301: Aug 13 11:46:31.625 HKG: //5339205/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3781302: Aug 13 11:46:31.625 HKG: cc_api_get_xcode_stream : 4534
3781303: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIProcessRtpSessions: sipSPIProcessRtpSessions
3781304: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIAddStream: Adding stream 1 of type voice+dtmf (callid 5339205) to the VOIP RTP library
3781305: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781306: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781307: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtcpSession: sipSPIUpdateRtcpSession for m-line 1
3781308: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtcpSession: rtcp_session info
    laddr = 22.121.5.4, lport = 18450, raddr = 22.121.7.3, rport=20372, do_rtcp=TRUE
    src_callid = 5339205, dest_callid = 5339204, stream type = voice+dtmf, stream direction = SENDRECV
    media_ip_addr = 22.121.7.3, vrf tableid = 0 media_addr_type = 1
3781309: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtcpSession: RTP session already created - update
3781310: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:31C26138
3781311: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICreateAndStartRtpTimer:
3781312: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
3781313: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIGetNewLocalMediaDirection:
    Present Local Media Direction = SENDRECV
    retVal = 0
3781314: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeStreamState: Stream (callid =  5339205)  State changed from (STREAM_ADDING) to (STREAM_ACTIVE)
3781315: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_bridge: really can't find peer_stream for
                                                dtmf-relay interworking
3781316: Aug 13 11:46:31.625 HKG: //5339205/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006BA, Source Interface=0x30D62BB0, Source Call Id=5339205,
   Destination Call Id=5339204, Disposition=0x0, Tag=0x0
3781317: Aug 13 11:46:31.625 HKG: //5339204/3F14A5B588D1/CCAPI/cc_generic_bridge_done:
3781318: Aug 13 11:46:31.625 HKG: //5339204/3F14A5B588D1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006BA, Destination Call Id=5339205)
3781319: Aug 13 11:46:31.625 HKG: //5339205/3F14A5B588D1/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006BA, Destination Call Id=5339204)
3781320: Aug 13 11:46:31.629 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x30D62BB0, Destination Call Id=5339205, Source Call Id=5339204,
   Caps(Codec=0x1, Fax Rate=0x1, Vad=0x1,
   Modem=0x2, Codec Bytes=20, Signal Type=3)
3781321: Aug 13 11:46:31.629 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_caps_ind:
   Caps(Playout Mode=1, Playout Initial=60(ms), Playout Min=40(ms),
   Playout Max=1000(ms), Fax Nom=300(ms))
3781322: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ind: Entry
3781323: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_get_rtcp_session_parameters: CURRENT VALUES: stream_callid=5339205, current_seq_num=0x923
3781324: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_get_rtcp_session_parameters: NEW VALUES: stream_callid=5339205, current_seq_num=0x0
3781325: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ind: Load DSP with negotiated codec: g711ulaw, Bytes=160
3781326: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ind: Set forking flag to 0x0
3781327: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISetDTMFRelayMode: Set DSP for dtmf-relay = CC_CAP_DTMF_RELAY_NTE_AND_OOB with rx payload = 101, tx payload = 101
3781328: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_set_modem_caps: Preferred (or the one that came from DSM) modem relay=1, from CLI config=0
3781329: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_set_modem_caps: Disabling Modem Relay...
3781330: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_set_modem_caps: Negotiation already Done. Set negotiated Modem caps and generate SDP Xcap list
3781331: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_set_modem_caps: Modem Relay & Passthru both disabled
3781332: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sip_set_modem_caps: nse payload = 0, ptru mode = 0, ptru-codec=1, redundancy=0, xid=0, relay=0, sprt-retry=12, latecncy=200, compres-dir=3, dict=1024, strnlen=32
3781333: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetStreamInfo: 1 Active Streams
3781334: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetStreamInfo: Adding stream type (voice+dtmf) from media
line 1 codec g711ulaw
3781335: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetStreamInfo:
caps.stream_count=1,caps.stream[0].stream_type=0x3, caps.stream_list.xmitFunc=
3781336: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetStreamInfo: voip_rtp_xmit, caps.stream_list.context=
3781337: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPISetStreamInfo: 0x3022D4E0 (gccb)
3781338: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ind: Load DSP with codec : g711ulaw, Bytes=160, payload = 0
3781339: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ind: ccsip_caps_ind: ccb->pld.flags_ipip = 0x281
3781340: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISrtpTranscoder:
 Checking if transcoder is needed for SRTP-RTP
3781341: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29CCE8B8, Destination Call Id=5339204, Source Call Id=5339205,
   Caps(Codec=0x1, Fax Rate=0x2, Vad=0x1,
   Modem=0x0, Codec Bytes=160, Signal Type=2)
3781342: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_caps_ind:
3781343: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ind: Calling cc_api_caps_ack()
3781344: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_caps_ack:
   Caps(Codec=g711ulaw(0x1), Fax Rate=FAX_RATE_VOICE(0x2), Vad=OFF(0x1),
   Modem=OFF(0x0), Codec Bytes=160, Signal Type=2, Seq Num Start=1)
3781345: Aug 13 11:46:31.629 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_caps_ack:
3781346: Aug 13 11:46:31.629 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_caps_ack: Set forking flag to 0x7
3781347: Aug 13 11:46:31.629 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_voice_mode_event:
   Call Id=5339204
3781348: Aug 13 11:46:31.629 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x319F3D74)
3781349: Aug 13 11:46:31.629 HKG: //5339204/3F14A5B588D1/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006BA, Call Id1=5339204, Call Id2=5339205
3781350: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
3781351: Aug 13 11:46:31.633 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x81000001
3781352: Aug 13 11:46:31.633 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallConnect:
   Call Entry(Connected=TRUE, Responsed=TRUE)
3781353: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781354: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781355: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781356: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
3781357: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781358: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781359: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781360: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromServerTable: Searching for SCB in server table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781361: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
CSeq: 102 NOTIFY
3781362: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
3781363: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
3781364: Aug 13 11:46:31.633 HKG: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x314240E0) on SCB(0x29FFF0A8)
3781365: Aug 13 11:46:31.633 HKG: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
3781366: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
3781367: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x314240E0) from EDB(0x31426ECC)
3781368: Aug 13 11:46:31.633 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x314240E0) for reuse
3781369: Aug 13 11:46:31.633 HKG: //0/000000000000/SIP/Info/sipSPIReportRequestSendStatus: ccsip_api_notify_result returned: SIP_SUCCESS
3781370: Aug 13 11:46:31.633 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7622198 N/A
3781371: Aug 13 11:46:32.357 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3781372: Aug 13 11:46:32.361 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:23 is now connected to 7573260 N/A
3781373: Aug 13 11:46:32.361 HKG: //5339203/00310166C04A/CCAPI/cc_api_call_connected:
   Interface=0x29CCE8B8, Data Bitmask=0x1, Progress Indication=NULL(0),
   Connection Handle=0
3781374: Aug 13 11:46:32.361 HKG: //5339203/00310166C04A/CCAPI/cc_api_call_connected:
3781375: Aug 13 11:46:32.365 HKG: //5339202/00310166C04A/CCAPI/ccCallConnect:
   Progress Indication=NULL(0), Data Bitmask=0x1
3781376: Aug 13 11:46:32.365 HKG: //5339203/00310166C04A/CCAPI/cc_api_get_called_ccm_detected:
   CallInfo(ccm detected=0)
3781377: Aug 13 11:46:32.365 HKG: //5339202/00310166C04A/CCAPI/ccCallConnect:
3781378: Aug 13 11:46:32.365 HKG: //5339202/00310166C04A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339202
3781379: Aug 13 11:46:32.365 HKG: //5339203/00310166C04A/CCAPI/cc_api_get_called_ccm_detected:
3781380: Aug 13 11:46:33.045 HKG: //5339202/00310166C04A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x29CCE8B8, Destination Call Id=5339203, Source Call Id=5339202,
   Modem=0x2, Codec Bytes=160, Signal Type=2)
3781381: Aug 13 11:46:33.045 HKG: //5339202/00310166C04A/CCAPI/cc_api_caps_ind:
3781382: Aug 13 11:46:33.045 HKG: //5339202/00310166C04A/CCAPI/cc_api_caps_ack:
   Modem=ON(0x2), Codec Bytes=160, Signal Type=2, Seq Num Start=7817)
3781383: Aug 13 11:46:33.045 HKG: //5339203/00310166C04A/CCAPI/cc_api_caps_ack:
   Destination Interface=0x2968961C, Destination Call Id=5339202, Source Call Id=5339203,
3781384: Aug 13 11:46:33.049 HKG: //5339203/00310166C04A/CCAPI/cc_api_voice_mode_event:
   Call Id=5339203
3781385: Aug 13 11:46:33.049 HKG: //5339203/00310166C04A/CCAPI/cc_api_voice_mode_event:
   Call Entry(Context=0x31966E78)
3781386: Aug 13 11:46:33.829 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3781387: Aug 13 11:46:33.833 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339205, proc_id=9
3781388: Aug 13 11:46:34.589 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3781389: Aug 13 11:46:34.589 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3781390: Aug 13 11:46:34.589 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3781391: Aug 13 11:46:34.597 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3781392: Aug 13 11:46:35.189 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3781393: Aug 13 11:46:35.193 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2968961C, Call Id=5339187
3781394: Aug 13 11:46:35.193 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
3781395: Aug 13 11:46:35.193 HKG: //5339187/0061EE52BD4A/CCAPI/ccConferenceDestroy:
   Conference Id=0x2006B3, Tag=0x0
3781396: Aug 13 11:46:35.193 HKG: //5339187/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2006B3, Source Interface=0x2968961C, Source Call Id=5339187,
   Destination Call Id=5339188, Disposition=0x0, Tag=0x0
3781397: Aug 13 11:46:35.193 HKG: //5339188/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2006B3, Source Interface=0x29CCE8B8, Source Call Id=5339188,
   Destination Call Id=5339187, Disposition=0x0, Tag=0x0
3781398: Aug 13 11:46:35.193 HKG: //5339187/0061EE52BD4A/CCAPI/cc_generic_bridge_done:
3781399: Aug 13 11:46:35.197 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3781400: Aug 13 11:46:35.197 HKG: //5339188/0061EE52BD4A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
3781401: Aug 13 11:46:35.197 HKG: //5339188/0061EE52BD4A/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
3781402: Aug 13 11:46:35.197 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
3781403: Aug 13 11:46:35.197 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
3781404: Aug 13 11:46:35.197 HKG: //5339187/0061EE52BD4A/CCAPI/ccCallDisconnect:
3781405: Aug 13 11:46:35.197 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_get_transfer_info:
3781406: Aug 13 11:46:35.197 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_get_transfer_info:
3781407: Aug 13 11:46:35.197 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5339187,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
3781408: Aug 13 11:46:35.197 HKG: //5339187/0061EE52BD4A/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
3781409: Aug 13 11:46:35.197 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781410: Aug 13 11:46:35.197 HKG: :cc_free_feature_vsa freeing 31C6B138
3781411: Aug 13 11:46:35.197 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781412: Aug 13 11:46:35.197 HKG:  vsacount in free is 85
3781413: Aug 13 11:46:35.817 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29CCE8B8, Tag=0x0, Call Id=5339188,
3781414: Aug 13 11:46:35.817 HKG: //5339188/0061EE52BD4A/CCAPI/cc_api_call_disconnect_done:
3781415: Aug 13 11:46:35.817 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781416: Aug 13 11:46:35.817 HKG: :cc_free_feature_vsa freeing 31C6B058
3781417: Aug 13 11:46:35.817 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781418: Aug 13 11:46:35.817 HKG:  vsacount in free is 84
3781419: Aug 13 11:46:36.601 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339205, proc_id=9
3781420: Aug 13 11:46:37.053 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3781421: Aug 13 11:46:37.057 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3781422: Aug 13 11:46:37.057 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3781423: Aug 13 11:46:37.061 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3781424: Aug 13 11:46:38.945 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3781425: Aug 13 11:46:38.961 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3781426: Aug 13 11:46:39.065 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3781427: Aug 13 11:46:39.533 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339205, proc_id=9
3781428: Aug 13 11:46:40.089 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3781429: Aug 13 11:46:41.045 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3781430: Aug 13 11:46:41.081 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3781431: Aug 13 11:46:41.569 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3781432: Aug 13 11:46:41.573 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3781433: Aug 13 11:46:41.885 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3781434: Aug 13 11:46:42.645 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3781435: Aug 13 11:46:42.709 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3781436: Aug 13 11:46:42.805 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2968961C, Call Id=5339193
3781437: Aug 13 11:46:42.805 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_disconnected:
3781438: Aug 13 11:46:42.805 HKG: //5339192/2EECF1E588CC/CCAPI/ccConferenceDestroy:
   Conference Id=0x2006B5, Tag=0x0
3781439: Aug 13 11:46:42.809 HKG: //5339192/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2006B5, Source Interface=0x29E03770, Source Call Id=5339192,
   Destination Call Id=5339193, Disposition=0x0, Tag=0x0
3781440: Aug 13 11:46:42.809 HKG: //5339193/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2006B5, Source Interface=0x2968961C, Source Call Id=5339193,
   Destination Call Id=5339192, Disposition=0x0, Tag=0x0
3781441: Aug 13 11:46:42.809 HKG: //5339192/2EECF1E588CC/CCAPI/cc_generic_bridge_done:
3781442: Aug 13 11:46:42.809 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallDisconnect:
3781443: Aug 13 11:46:42.809 HKG: //5339192/2EECF1E588CC/CCAPI/ccCallDisconnect:
3781444: Aug 13 11:46:42.809 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_get_transfer_info:
3781445: Aug 13 11:46:42.809 HKG: //5339193/2EECF1E588CC/CCAPI/ccCallDisconnect:
3781446: Aug 13 11:46:42.809 HKG: //5339193/2EECF1E588CC/CCAPI/ccCallDisconnect:
3781447: Aug 13 11:46:42.809 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_get_transfer_info:
3781448: Aug 13 11:46:43.449 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_get_transfer_info:
3781449: Aug 13 11:46:43.449 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5339193,
3781450: Aug 13 11:46:43.449 HKG: //5339193/2EECF1E588CC/CCAPI/cc_api_call_disconnect_done:
3781451: Aug 13 11:46:43.449 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781452: Aug 13 11:46:43.449 HKG: :cc_free_feature_vsa freeing 31C6B9F8
3781453: Aug 13 11:46:43.453 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781454: Aug 13 11:46:43.453 HKG:  vsacount in free is 83
3781455: Aug 13 11:46:43.453 HKG: %ISDN-6-DISCONNECT: Interface Serial0/1/0:6  disconnected from 7513612 , call lasted 30 seconds
3781456: Aug 13 11:46:43.457 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_call_feature:
   Feature Type=6, Interface=0x29E03770, Call Id=5339192
3781457: Aug 13 11:46:43.457 HKG: //-1/00998A6FC14A/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=Matthew LAM
   ----- ccCallInfo IE subfields -----
   cisco-ani=7528211
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7513755
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
3781458: Aug 13 11:46:43.461 HKG: //-1/00998A6FC14A/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x2968961C, Call Info(
   Calling Number=7528211,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513755(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=752001, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=5339206
3781459: Aug 13 11:46:43.461 HKG: //-1/00998A6FC14A/CCAPI/ccCheckClipClir:
   In: Calling Number=7528211(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3781460: Aug 13 11:46:43.461 HKG: //-1/00998A6FC14A/CCAPI/ccCheckClipClir:
   Out: Calling Number=7528211(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
3781461: Aug 13 11:46:43.461 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3781462: Aug 13 11:46:43.461 HKG: :cc_get_feature_vsa malloc success
3781463: Aug 13 11:46:43.461 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3781464: Aug 13 11:46:43.461 HKG:  cc_get_feature_vsa count is 84
3781465: Aug 13 11:46:43.461 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3781466: Aug 13 11:46:43.461 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835107328,feature_id:5342278
3781467: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=7528211(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513755(TON=Unknown, NPI=Unknown))
3781468: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/cc_process_call_setup_ind:
   Event=0x310E6BB8
3781469: Aug 13 11:46:43.461 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 7513755
3781470: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCallSetContext:
   Context=0x31AB44F4
3781471: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/cc_process_call_setup_ind:
   >>>>CCAPI handed cid 5339206 with tag 752001 to app "_ManagedAppProcess_Default"
3781472: Aug 13 11:46:43.461 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3781473: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCallProceeding:
3781474: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=700001, Params=0x301DBAAC, Progress Indication=NULL(0)
3781475: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCheckClipClir:
3781476: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCheckClipClir:
3781477: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCallSetupRequest:
   Destination Pattern=7T, Called Number=7513755, Digit Strip=TRUE
3781478: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccCallSetupRequest:
   Redirect Number=, Display Info=Matthew LAM
   Account Number=Matthew LAM, Final Destination Flag=TRUE,
   Guid=00998A6F-A3DF-A13E-C14A-9B0316792AC4, Outgoing Dial-peer=700001
3781479: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-ani=7528211
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=7513755
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-lastrdn=
   cisco-rdntype=-1
   cisco-rdnplan=-1
   cisco-rdnpi=-1
   cisco-rdnsi=-1
3781480: Aug 13 11:46:43.461 HKG: //5339206/00998A6FC14A/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x29CCE8B8, Interface Type=6, Destination=, Mode=0x0,
   Call Params(Calling Number=7528211,(Calling Name=Matthew LAM)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=7513755(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=700001, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
3781481: Aug 13 11:46:43.465 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3781482: Aug 13 11:46:43.465 HKG: :cc_get_feature_vsa malloc success
3781483: Aug 13 11:46:43.465 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3781484: Aug 13 11:46:43.465 HKG:  cc_get_feature_vsa count is 85
3781485: Aug 13 11:46:43.465 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
3781486: Aug 13 11:46:43.465 HKG: :FEATURE_VSA attributes are: feature_name:0,feature_time:835104864,feature_id:5342279
3781487: Aug 13 11:46:43.465 HKG: //5339207/00998A6FC14A/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=6, FlowMode=1
3781488: Aug 13 11:46:43.465 HKG: //5339207/00998A6FC14A/CCAPI/ccCallSetContext:
   Context=0x301DBA5C
3781489: Aug 13 11:46:43.465 HKG: //5339206/00998A6FC14A/CCAPI/ccSaveDialpeerTag:
3781490: Aug 13 11:46:43.465 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3781491: Aug 13 11:46:44.229 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29E03770, Tag=0x0, Call Id=5339192,
3781492: Aug 13 11:46:44.229 HKG: //5339192/2EECF1E588CC/CCAPI/cc_api_call_disconnect_done:
3781493: Aug 13 11:46:44.229 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781494: Aug 13 11:46:44.229 HKG: :cc_free_feature_vsa freeing 31C6B918
3781495: Aug 13 11:46:44.229 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781496: Aug 13 11:46:44.229 HKG:  vsacount in free is 84
3781497: Aug 13 11:46:44.233 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_call_proceeding:
   Interface=0x29CCE8B8, Progress Indication=NULL(0)
3781498: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_call_alert:
   Interface=0x29CCE8B8, Progress Indication=INBAND(8), Signal Indication=SIGNAL RINGBACK(1)
3781499: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_call_alert:
   Call Entry(Retry Count=0, Responsed=TRUE)
3781500: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/ccCallAlert:
3781501: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/ccCallAlert:
3781502: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_get_called_ccm_detected:
3781503: Aug 13 11:46:44.237 HKG: //5339206/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x31989D64, callID1=0x517846, callID2=0x517847, tag=0x0)
3781504: Aug 13 11:46:44.237 HKG: //5339206/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x31989D64, callID1=0x517846, gcid=0-0-0-0, tag=0x0)
3781505: Aug 13 11:46:44.237 HKG: //5339207/xxxxxxxxxxxx/CCAPI/ccConferenceCreate:
   (confID=0x31989D64, callID2=0x517847, gcid=0-0-0-0, tag=0x0)
3781506: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/ccConferenceCreate:
   Conference Id=0x31989D64, Call Id1=5339206, Call Id2=5339207, Tag=0x0
3781507: Aug 13 11:46:44.237 HKG: //5339206/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
3781508: Aug 13 11:46:44.237 HKG: cc_api_get_xcode_stream : 4534
3781509: Aug 13 11:46:44.237 HKG: //5339206/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006BB, Source Interface=0x2968961C, Source Call Id=5339206,
   Destination Call Id=5339207, Disposition=0x0, Tag=0x0
3781510: Aug 13 11:46:44.237 HKG: //5339207/xxxxxxxxxxxx/CCAPI/cc_api_bridge_done:
   Conference Id=0x2006BB, Source Interface=0x29CCE8B8, Source Call Id=5339207,
   Destination Call Id=5339206, Disposition=0x0, Tag=0xFFFFFFFF
3781511: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/cc_generic_bridge_done:
3781512: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006BB, Destination Call Id=5339207)
3781513: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/ccConferenceCreate:
   Call Entry(Conference Id=0x2006BB, Destination Call Id=5339206)
3781514: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_caps_ind:
   Destination Interface=0x2968961C, Destination Call Id=5339206, Source Call Id=5339207,
3781515: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_caps_ind:
3781516: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/ccCallNotify:
   Data Bitmask=0x7, Call Id=5339206
3781517: Aug 13 11:46:44.237 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_get_called_ccm_detected:
3781518: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_get_delay_xport:
   CallInfo(delay xport=FALSE)
3781519: Aug 13 11:46:44.237 HKG: //5339206/00998A6FC14A/CCAPI/cc_process_notify_bridge_done:
   Conference Id=0x2006BB, Call Id1=5339206, Call Id2=5339207
3781520: Aug 13 11:46:45.073 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3781521: Aug 13 11:46:45.785 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3781522: Aug 13 11:46:45.793 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339205, proc_id=9
3781523: Aug 13 11:46:46.029 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3781524: Aug 13 11:46:46.157 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3781525: Aug 13 11:46:46.425 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3781526: Aug 13 11:46:46.829 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7622198 , call lasted 15 seconds
3781527: Aug 13 11:46:46.829 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_call_disconnected:
   Cause Value=34, Interface=0x29CCE8B8, Call Id=5339204
3781528: Aug 13 11:46:46.833 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=34, Retry Count=0)
3781529: Aug 13 11:46:46.833 HKG: //5339204/3F14A5B588D1/CCAPI/ccConferenceDestroy:
   Conference Id=0x2006BA, Tag=0x0
3781530: Aug 13 11:46:46.833 HKG: //5339204/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=5339205, Disposition=0x0, Tag=0x0
3781531: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIUpdateRtpSession: stun is disabled for stream:31C26138
3781532: Aug 13 11:46:46.833 HKG: //5339205/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
3781533: Aug 13 11:46:46.833 HKG: //5339204/3F14A5B588D1/CCAPI/cc_generic_bridge_done:
3781534: Aug 13 11:46:46.833 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=34)
3781535: Aug 13 11:46:46.833 HKG: //5339204/3F14A5B588D1/CCAPI/ccCallDisconnect:
   Cause Value=34, Call Entry(Responsed=TRUE, Cause Value=34)
3781536: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_call_statistics: Requesting stats for callid=5339205
3781537: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/CCAPI/ccCallDisconnect:
   Cause Value=34, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
3781538: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/CCAPI/ccCallDisconnect:
3781539: Aug 13 11:46:46.833 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
3781540: Aug 13 11:46:46.833 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
3781541: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIValidateGtd: Signal Forward disabled
3781542: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIValidateTunnelData: RawMsg/QSIG Tunneling Not Enabled
3781543: Aug 13 11:46:46.833 HKG: //5339205/3F14A5B588D1/SIP/Info/act_active_disconnect: Disconnect deferred, as stats request pending
3781544: Aug 13 11:46:47.257 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339205, proc_id=1
3781545: Aug 13 11:46:47.257 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_CALL_DISCONNECT
3781546: Aug 13 11:46:47.257 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 7
3781547: Aug 13 11:46:47.257 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3781548: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3781549: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPISendBye: Associated container=0x315097F8 to Bye
3781550: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPISendBye: Sending BYE to the transport layer
3781551: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPIGetSwitchTransportFlag: Return the Dial peer configuration, Switch Transport is FALSE
3781552: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: msg=0x31B17B98, addr=22.121.6.1, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x249C2928
3781553: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781554: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781555: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x31B17B98
3781556: Aug 13 11:46:47.261 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x31B17B98, addr=22.121.6.1, port=5060, connId=3 for TCP
3781557: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/Info/sentByeDisconnecting: Sent Bye Request, starting DisconnectTimer
3781558: Aug 13 11:46:47.261 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_DISCONNECTING, SUBSTATE_NONE)
3781559: Aug 13 11:46:47.261 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:7523047@22.121.6.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 22.121.5.4:5060;branch=z9hG4bK35C80
From: "WLG Test" <sip:7622198@22.121.5.4>;tag=9BD47898-123
To: <sip:7523047@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
Date: Wed, 13 Aug 2014 03:46:30 GMT
Call-ID: 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.4
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1407901607
CSeq: 103 BYE
Reason: Q.850;cause=34
Content-Length: 0
3781560: Aug 13 11:46:47.261 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 208, Bytes Remaining 91
3781561: Aug 13 11:46:47.261 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
3781562: Aug 13 11:46:47.261 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
3781563: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781564: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3781565: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3781566: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7571929@22.121.5.4:5060;transport=tcp SIP/2.0
Date: Wed, 13 Aug 2014 03:46:46 GMT
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
From: <sip:7523050@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68742297
Allow-Events: presence, kpml
P-Asserted-Identity: "Meeting Place " <sip:3050@22.121.6.1>
Supported: timer,resource-priority,replaces
Min-SE:  1800
Cisco-Guid: 0809335049-0567349732-2286833725-3846689392
Remote-Party-ID: "Meeting Place " <sip:3050@22.121.6.1>;party=calling;screen=yes;privacy=off
Content-Length: 208
User-Agent: Cisco-CUCM7.1
To: "Vijay Korlam" <sip:7571929@22.121.5.4>;tag=9BC6FBD8-145C
Contact: <sip:7523050@22.121.6.1:5060;transport=tcp>;isfocus
Expires: 180
Content-Type: application/sdp
Call-ID: 303E1531-21D111E4-BB10D61B-FD97BF00@22.121.5.4
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4a37ba7a3f5
CSeq: 101 INVITE
Session-Expires:  1800;refresher=uac
Max-Forwards: 70
v=0
o=CiscoSystemsCCM-SIP 2000 1 IN IP4 22.121.6.1
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
m=audio 18824 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
3781567: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781568: Aug 13 11:46:47.265 HKG: //5338950/303D7909884E/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313F4E90
3781569: Aug 13 11:46:47.265 HKG: //5338950/303D7909884E/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3781570: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781571: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781572: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781573: Aug 13 11:46:47.265 HKG: //5338950/303D7909884E/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
3781574: Aug 13 11:46:47.265 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Name to Meeting Place
3781575: Aug 13 11:46:47.265 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 3050
3781576: Aug 13 11:46:47.265 HKG: //5338949/303D7909884E/CCAPI/ccGenerateToneInfo:
   Tone Direction=Sum Network, Params=0x0, Call Id=5338949
3781577: Aug 13 11:46:47.265 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3781578: Aug 13 11:46:47.265 HKG: //5338950/303D7909884E/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
3781579: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPINegotiateSessionExpires: Min-SE Header: 1800
3781580: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPINegotiateSessionExpires:
Session-Expires value: 1800 refresher: 1
3781581: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPI_ipip_Add_SessionExpiresParamsToContainer: Session-refresh parameters added to container minse = 1800 session expire = 1800 refresher = 1
3781582: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
3781583: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
3781584: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
SIP: Attribute mid, level 1 instance 1 not found.
3781585: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781586: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781587: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3781588: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3781589: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3781590: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3781591: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3781592: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3781593: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
3781594: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
3781595: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3781596: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3781597: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3781598: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    payload_type=0, codec_bytes=160, codec=g711ulaw, dtmf_relay=rtp-nte
    stream_type=voice+dtmf (1), dest_ip_address=22.121.7.3, dest_port=18824
3781599: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3781600: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=18824 new=18824
3781601: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPIGetNewLocalMediaDirection:
    retVal = 0
3781602: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
3781603: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
3781604: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: Entry
3781605: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
3781606: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
3781607: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3781608: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3781609: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Preferred Codec        : g711ulaw, bytes :160
    Preferred  DTMF relay  : rtp-nte
    Preferred NTE payload  : 101
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : Yes
    New Media              : No
    DSP DNLD Reqd          : No
3781610: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781611: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781612: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Stream type            : voice+dtmf
      Media line             : 1
      State                  : STREAM_ACTIVE (5)
      Stream address type    : 1
      Callid                 : 5338950
      Negotiated Codec       : g711ulaw, bytes :160
      Nego. Codec payload    : 0 (tx), 0 (rx)
      Negotiated DTMF relay  : rtp-nte
      Negotiated NTE payload : 101 (tx), 101 (rx)
      Negotiated CN payload  : 0
      Media Srce Addr/Port   : [22.121.5.4]:24200
      Media Dest Addr/Port   : [22.121.7.3]:18824
3781613: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/is_call_held: Remote media IP addr: 22.121.7.3
3781614: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/is_call_held: Media IP Addr 22.121.7.3, RTCP Type 3
3781615: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
3781616: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
3781617: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=24200
3781618: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
3781619: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 24200
3781620: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
 SIP update src sdp, negoitated codec 5, payload type 0
3781621: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
3781622: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/ccsip_api_request_offer: Deffering QoS
                                reservation for MID-CALL Invite
3781623: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/ccsip_api_request_offer: Response 200 OK for TDM
3781624: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
3781625: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateSDPQoSAttributes: 4 a-line(s) found for stream 1
3781626: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 348, curr send SDP size =
              240
3781627: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size and curr send SDP size
              is not same.. so no comparision is done..
3781628: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID incremented old version id = 5858,
                         new version id = 5859
3781629: Aug 13 11:46:47.269 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
3781630: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIUpdateCallInfoforDelayReconnect:
sipSPIUpdateCallInfoforDelayReconnect: callID 5338950
3781631: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/State/sipSPIChangeState: 0x313F4E90 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
3781632: Aug 13 11:46:47.269 HKG: //5338950/303D7909884E/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
3781633: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPISendInviteResponse: Associated container=0x3150DB58 to Invite Response 100
3781634: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipSPITransportSendMessage: msg=0x30184AC4, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x0
3781635: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781636: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781637: Aug 13 11:46:47.273 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x30184AC4, addr=22.121.6.1, port=39173, connId=2 for TCP
3781638: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPIProcessContactInfo: Previous Hop 22.121.6.1:5060
3781639: Aug 13 11:46:47.273 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
3781640: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/act_handle_app_media_event: method = 102 state = 16
3781641: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
3781642: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 22.121.7.3, RTCP Type 3
3781643: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3781644: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5338950
3781645: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5338950
3781646: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
3781647: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
3781648: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sipSPISendInviteResponse: Associated container=0x31509A60 to Invite Response 200
3781649: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
3781650: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipSPITransportSendMessage: msg=0x2A4DBBE0, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x249C2C40
3781651: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781652: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781653: Aug 13 11:46:47.273 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x2A4DBBE0, addr=22.121.6.1, port=39173, connId=2 for TCP
3781654: Aug 13 11:46:47.273 HKG: //5338950/303D7909884E/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
3781655: Aug 13 11:46:47.273 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3781656: Aug 13 11:46:47.273 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Wed, 13 Aug 2014 03:46:47 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
3781657: Aug 13 11:46:47.273 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Remote-Party-ID: "Vijay Korlam" <sip:7571929@22.121.5.4>;party=called;screen=yes;privacy=off
Contact: <sip:3050@22.121.5.4:5060;transport=tcp>
Supported: replaces
Supported: sdp-anat
Require: timer
Content-Length: 240
v=0
o=CiscoSystemsSIP-GW-UserAgent 896 5859 IN IP4 22.121.5.4
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
m=audio 24200 RTP/AVP 0 101
c=IN IP4 22.121.5.4
a=fmtp:101 0-16
a=ptime:20
3781658: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781659: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781660: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781661: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781662: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList: via branch list is:
3781663: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Error/debugPrintBranchList:     end of list
3781664: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
CSeq: 103 BYE
3781665: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPICheckResponseExt: non-INVITE response with no RSEQ - do not disable IS_REL1XX
3781666: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIIcpifUpdate: CallState: 4 Playout: 13190 DiscTime:1120434403 ConnTime 1120432837
3781667: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Media/sipSPIDestroyRtpSession: stream:31C26138
3781668: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x30D62BB0, Tag=0x0, Call Id=5339205,
   Call Entry(Disconnect Cause=34, Voice Class Cause Code=0, Retry Count=0)
3781669: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/CCAPI/cc_api_call_disconnect_done:
3781670: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781671: Aug 13 11:46:47.277 HKG: :cc_free_feature_vsa freeing 31C6B3D8
3781672: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781673: Aug 13 11:46:47.277 HKG:  vsacount in free is 83
3781674: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/State/sipSPIChangeState: 0x314047C0 : State change from (STATE_DISCONNECTING, SUBSTATE_NONE)  to (STATE_DEAD, SUBSTATE_NONE)
3781675: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x314047C0
State of The Call        : STATE_DEAD
TCP Sockets Used         : YES
Calling Number           : 7622198
Called Number            : 7523047
Source IP Address (Sig  ): 22.121.5.4
Destn SIP Req Addr:Port  : 22.121.6.1:5060
Destn SIP Resp Addr:Port : 22.121.6.1:5060
Destination Name         : 22.121.6.1
3781676: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec Bytes   : 160
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 22.121.5.4
Source IP Port    (Media): 18450
Destn  IP Address (Media): 22.121.7.3
Destn  IP Port    (Media): 20372
Orig Destn IP Address:Port (Media): [ - ]:0
3781677: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 34
Disconnect Cause (SIP)   : 200
3781678: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUdeleteccCallIdFromTable: Removing call id 517845
3781679: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[4703] removed.
3781680: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUdeleteCcbFromUACTable: ****Deleting from UAC table.
3781681: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x314047C0 key=3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.4
3781682: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
3781683: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/ccsip_qos_cleanup: Entry
3781684: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3781685: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
3781686: Aug 13 11:46:47.277 HKG: //5339205/3F14A5B588D1/SIP/Info/sipSPIUfreeOneCCB: Freeing ccb 314047C0
3781687: Aug 13 11:46:47.277 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContextFromTable: NO context for key[4703]
3781688: Aug 13 11:46:47.277 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3781689: Aug 13 11:46:47.281 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29CCE8B8, Tag=0x0, Call Id=5339204,
3781690: Aug 13 11:46:47.281 HKG: //5339204/3F14A5B588D1/CCAPI/cc_api_call_disconnect_done:
3781691: Aug 13 11:46:47.281 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781692: Aug 13 11:46:47.281 HKG: :cc_free_feature_vsa freeing 31C69ED8
3781693: Aug 13 11:46:47.281 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781694: Aug 13 11:46:47.281 HKG:  vsacount in free is 82
3781695: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781696: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3781697: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3781698: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SUBSCRIBE sip:7622198@22.121.5.4:5060;transport=tcp SIP/2.0
From: <sip:7523047@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
Event: kpml
Content-Length: 0
To: "WLG Test" <sip:7622198@22.121.5.4>;tag=9BD47898-123
Contact: <sip:22.121.6.1:5060;transport=tcp>
Expires: 0
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4a673f658e2
CSeq: 102 SUBSCRIBE
Max-Forwards: 70
3781699: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
3781700: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781701: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781702: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781703: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromServerTable: Searching for SCB in server table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781704: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
3781705: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
3781706: Aug 13 11:46:48.097 HKG: //0/000000000000/SIP/Info/sipGenCheckCseq: Difference in CSEQ numbers: 1
3781707: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x29FFD0CC
3781708: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBServerMarker: Server TCB's Marker Updated to: 102SUBSCRIBEz9hG4bK4e4a673f658e2
3781709: Aug 13 11:46:48.097 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781710: Aug 13 11:46:48.101 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIHandleSubscribeOnExistingDialog: TCB 0x29FFD0CC's parent is 0x29FFF0A8
3781711: Aug 13 11:46:48.101 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBLastRequest: TCB(0x29FFD0CC) has claimed possesion of lastReq (0x29CB330C)
3781712: Aug 13 11:46:48.101 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
3781713: Aug 13 11:46:48.101 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x29FFD0CC) on EDB(0x31426ECC)
3781714: Aug 13 11:46:48.101 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
3781715: Aug 13 11:46:48.101 HKG: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_subscribe_response: Queued event from SIP SPI : SIPSPI_EV_CC_SUBSCRIBE_RESP
3781716: Aug 13 11:46:48.101 HKG: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_call_notify_event: Queued event from SIP SPI : SIPSPI_EV_CC_NOTIFY
3781717: Aug 13 11:46:48.101 HKG: //-1/xxxxxxxxxxxx/SIP/Event/ccsip_api_initiate_subscription_termination: Queued event from SIP SPI : SIPSPI_EV_SUBSCRIPTION_TERMINATED
3781718: Aug 13 11:46:48.101 HKG: //0/000000000000/SIP/Info/sipSPIHandleSubscribeOnExistingDialog: ccsip_api_resubscribe_ind returned: SIP_SUCCESS
3781719: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 203
3781720: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_SUBSCRIBE_RESP] received in State [SUBSCRIBE_STATE_ACTIVE]
3781721: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781722: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_resp_event: TCB 0x29FFD0CC's method is 112
3781723: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x29FFD0CC) has claimed possesion of package (0x3169E668)
3781724: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x29FFD0CC and parent: 0x29FFF0A8
3781725: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x3169E668, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x248DB478
3781726: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781727: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781728: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x3169E668, addr=22.121.6.1, port=39173, connId=2 for TCP
3781729: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBServer: Entering ...
3781730: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
3781731: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x29FFD0CC) from EDB(0x31426ECC)
3781732: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x29FFD0CC) for reuse
3781733: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 204
3781734: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_CC_NOTIFY] received in State [SUBSCRIBE_STATE_ACTIVE]
3781735: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_tcb: Created TCB: 0x31423A90
3781736: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x31423A90's parent is 0x29FFF0A8
3781737: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateTCBRequestInfo: Dialog Transaction Address 22.121.6.1,Port 5060, Port Present: TRUE, Transport 2, FQDN 651758288
3781738: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781739: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/act_dialog_active_notify_event: TCB 0x31423A90's method is 111
3781740: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBPackage: TCB(0x31423A90) has claimed possesion of package (0x301FE288)
3781741: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIUpdateTCBClientMarker: Client TCB's Marker Updated to: z9hG4bK35C91810
3781742: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: Entering ...
3781743: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIQueTcb: Q'd TCB(0x31423A90) on EDB(0x31426ECC)
3781744: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Info/sipSPIQueTcb: There are 1 TCB's on tcbQ
3781745: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendClientPackage: Entering ...
3781746: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPITCBSendPackage: Sending Package on tcb: 0x31423A90 and parent: 0x29FFF0A8
3781747: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: msg=0x301FE288, addr=22.121.6.1, port=5060, sentBy_port=0, is_req=1, transport=2, switch=0, callBack=0x248D9D08
3781748: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781749: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781750: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Transport/sipTransportLogicSendMsg: Set to send the msg=0x301FE288
3781751: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x301FE288, addr=22.121.6.1, port=5060, connId=3 for TCP
3781752: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISentTCBClient: Entering ...
3781753: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIKickoffTcbReTxTimer: Kicking off ReTx Timer for Client TCB (0x31423A90) with 0 retries and 32000 milliseconds initial retx
3781754: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_timer_context: Created timer context(0x31506F10)
3781755: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 7 for event 210
3781756: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_app_subscribe_event: Event [SIPSPI_EV_SUBSCRIPTION_TERMINATED] received in State [SUBSCRIBE_STATE_ACTIVE]
3781757: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Info/act_subscription_terminated: Resetting server EDB flag
3781758: Aug 13 11:46:48.105 HKG: //0/000000000000/SIP/Info/sipSPITerminateEvent: 1 Transactions still active on Event:kpml ID:
3781759: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781760: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3781761: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3781762: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:3050@22.121.5.4:5060;transport=tcp SIP/2.0
Content-Length: 0
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4a85c08be00
CSeq: 101 ACK
Max-Forwards: 70
3781763: Aug 13 11:46:48.105 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781764: Aug 13 11:46:48.105 HKG: //5338950/303D7909884E/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313F4E90
3781765: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3781766: Aug 13 11:46:48.109 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781767: Aug 13 11:46:48.109 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781768: Aug 13 11:46:48.109 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781769: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
3781770: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/State/sipSPIChangeState: 0x313F4E90 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
3781771: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPICreateAndStartRtpTimer:
3781772: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
3781773: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start resume start notifivation
3781774: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPIResumeStartNotificationRequest: sipSPIResumeStartNotificationRequest: Resume Type=Unknown
3781775: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/CCAPI/cc_api_call_facility:
   Interface=0x30D62BB0, Call Id=5338950
3781776: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
3781777: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPIProcessRsvp: Entry
3781778: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
3781779: Aug 13 11:46:48.109 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 13 Aug 2014 03:46:48 GMT
CSeq: 102 SUBSCRIBE
Content-Length: 0
Contact: <sip:7622198@22.121.5.4:5060;transport=tcp>
Expires: 0
3781780: Aug 13 11:46:48.109 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
NOTIFY sip:22.121.6.1:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 22.121.5.4:5060;branch=z9hG4bK35C91810
CSeq: 104 NOTIFY
Max-Forwards: 70
Event: kpml
Subscription-State: terminated
Content-Type: application/kpml-response+xml
Content-Length: 109
<?xml version="1.0" encoding="UTF-8"?><kpml-response version="1.0" code="487" text="Subscription Expired"/>
3781781: Aug 13 11:46:48.109 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3781782: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781783: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x30D6009C
3781784: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=5060, connid=3, transport=TCP
3781785: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Subscribe Dialog
3781786: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781787: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromClientTable: Searching for SCB in client table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.49BD47898-123
3781788: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICreateSubscribeKey: Generated Subscribe Key : 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781789: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetSCBFromServerTable: Searching for SCB in server table with key 3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946
3781790: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Content-Length: 0
CSeq: 104 NOTIFY
3781791: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetAnalogousSubscribeEvent: Event entering: 1
3781792: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_spi_process_event: Event [SIPSPI_EV_NEW_MSG] received in State [SUBSCRIBE_STATE_ACTIVE]
3781793: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPIFindTCBonSCB: Found TCB(0x31423A90) on SCB(0x29FFF0A8)
3781794: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/act_dialog_active_new_msg_response: Entering ...
3781795: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: Sizeof tcbQ: 1
3781796: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: DeQ'd TCB(0x31423A90) from EDB(0x31426ECC)
3781797: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneTCB: EnQing TCB(0x31423A90) for reuse
3781798: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: There are 1 EDBs on edbQ
3781799: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPIFreeOneEDB: DeQ'd EDB(0x31426ECC)
3781800: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIFreeOneEDB: EnQing EDB(0x31426ECC) for reuse
3781801: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPITerminateEvent: Freeing SCB(0x29FFF0A8), 0 active events present
3781802: Aug 13 11:46:48.885 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIDeleteContextFromTable: Context for key=[4704] removed.
3781803: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPIRemoveSCBFromServerTable: Removing SCB(0x29FFF0A8) with Key(3F15DE05-21D311E4-BCC1D61B-FD97BF00@22.121.5.490a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68743946) from Server Table
3781804: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPIRemoveSCBFromSubIDTable: Removing SCB(0x29FFF0A8) with Key(8) from SubID Table
3781805: Aug 13 11:46:48.885 HKG: //0/000000000000/SIP/Info/sipSPIFreeOneSCB: EnQing SCB(0x29FFF0A8) for reuse
3781806: Aug 13 11:46:48.885 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3781807: Aug 13 11:46:49.645 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3781808: Aug 13 11:46:49.645 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3781809: Aug 13 11:46:50.408 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3781810: Aug 13 11:46:50.520 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x2968961C, Call Id=5339206
3781811: Aug 13 11:46:50.520 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_call_disconnected:
   Call Entry(Responsed=TRUE, Cause Value=16, Retry Count=0)
3781812: Aug 13 11:46:50.520 HKG: //5339206/00998A6FC14A/CCAPI/ccConferenceDestroy:
   Conference Id=0x2006BB, Tag=0x0
3781813: Aug 13 11:46:50.520 HKG: //5339206/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
3781814: Aug 13 11:46:50.520 HKG: //5339207/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Destination Call Id=5339206, Disposition=0x0, Tag=0x0
3781815: Aug 13 11:46:50.520 HKG: //5339206/00998A6FC14A/CCAPI/cc_generic_bridge_done:
3781816: Aug 13 11:46:51.100 HKG: //5339207/00998A6FC14A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
3781817: Aug 13 11:46:51.104 HKG: //5339207/00998A6FC14A/CCAPI/ccCallDisconnect:
   Cause Value=16, Call Entry(Responsed=TRUE, Cause Value=16)
3781818: Aug 13 11:46:51.104 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_get_transfer_info:
   Transfer Number Is Null
3781819: Aug 13 11:46:51.108 HKG: //5339206/00998A6FC14A/CCAPI/ccCallDisconnect:
   Cause Value=16, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=16)
3781820: Aug 13 11:46:51.108 HKG: //5339206/00998A6FC14A/CCAPI/ccCallDisconnect:
3781821: Aug 13 11:46:51.108 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_get_transfer_info:
3781822: Aug 13 11:46:51.112 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_get_transfer_info:
3781823: Aug 13 11:46:51.112 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5339206,
   Call Entry(Disconnect Cause=16, Voice Class Cause Code=0, Retry Count=0)
3781824: Aug 13 11:46:51.112 HKG: //5339206/00998A6FC14A/CCAPI/cc_api_call_disconnect_done:
   Call Disconnect Event Sent
3781825: Aug 13 11:46:51.112 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781826: Aug 13 11:46:51.112 HKG: :cc_free_feature_vsa freeing 31C6B9F8
3781827: Aug 13 11:46:51.112 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781828: Aug 13 11:46:51.112 HKG:  vsacount in free is 81
3781829: Aug 13 11:46:51.112 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3781830: Aug 13 11:46:51.112 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3781831: Aug 13 11:46:51.884 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3781832: Aug 13 11:46:51.892 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29CCE8B8, Tag=0x0, Call Id=5339207,
3781833: Aug 13 11:46:51.892 HKG: //5339207/00998A6FC14A/CCAPI/cc_api_call_disconnect_done:
3781834: Aug 13 11:46:51.892 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781835: Aug 13 11:46:51.892 HKG: :cc_free_feature_vsa freeing 31C6B058
3781836: Aug 13 11:46:51.892 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781837: Aug 13 11:46:51.892 HKG:  vsacount in free is 80
3781838: Aug 13 11:46:52.652 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3781839: Aug 13 11:46:52.652 HKG: //-1/xxxxxxxxxxxx/SIP/Info/httpish_msg_process_network_msg: Content Length 208, Bytes Remaining 109
3781840: Aug 13 11:46:52.652 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_network_message: process_network_msg: not complete
3781841: Aug 13 11:46:52.652 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_tcp_newmsg_to_spi: process_network_msg: not complete
3781842: Aug 13 11:46:52.656 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3781843: Aug 13 11:46:52.656 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3781844: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781845: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3781846: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3781847: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:3050@22.121.5.4:5060;transport=tcp SIP/2.0
Date: Wed, 13 Aug 2014 03:46:52 GMT
From: <sip:7523050@22.121.6.1>;tag=90a4ee41-c7cf-4863-9a6d-b9d67ba5f617-68737262
Min-SE:  1800
Cisco-Guid: 3927917934-0566890980-2261930045-3846689392
Content-Length: 208
To: <sip:65350828@22.121.5.4>;tag=9B9DDDE4-ED1
Expires: 180
Call-ID: EA1FE195-21CA11E4-B5B9D61B-FD97BF00@22.121.5.4
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4ab16b7791d
CSeq: 104 INVITE
Max-Forwards: 70
v=0
s=SIP Call
c=IN IP4 22.121.7.3
t=0 0
m=audio 17024 RTP/AVP 0 101
a=ptime:20
a=fmtp:101 0-15
3781848: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781849: Aug 13 11:46:52.656 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313E0250
3781850: Aug 13 11:46:52.656 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3781851: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781852: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781853: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781854: Aug 13 11:46:52.656 HKG: //5338153/EA1F456E86D2/SIP/Info/sact_active_new_message_request: Case of Mid-Call INVITE/UPDATE in ACTIVE STATE
3781855: Aug 13 11:46:52.656 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Name to Meeting Place
3781856: Aug 13 11:46:52.656 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateIdentity: SIP->PSTN: Setting Calling Number to 3050
3781857: Aug 13 11:46:52.656 HKG: //5338152/EA1F456E86D2/CCAPI/ccGenerateToneInfo:
   Stop Tone On Digit=FALSE, Tone=Null,
   Tone Direction=Sum Network, Params=0x0, Call Id=5338152
3781858: Aug 13 11:46:52.656 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPIGetContentGTD: No GTD found in inbound container
3781859: Aug 13 11:46:52.656 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_api_request_offer: ccsip_api_request_offer.
3781860: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPINegotiateSessionExpires: Min-SE Header: 1800
3781861: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPINegotiateSessionExpires:
3781862: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPI_ipip_Add_SessionExpiresParamsToContainer: Session-refresh parameters added to container minse = 1800 session expire = 1800 refresher = 1
3781863: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_api_request_offer: Incoming/Outgoing updates for callerid is globally disabled
3781864: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Error/sipSPIProcessNotifyCallInfoHeader: Call-Info header with for Unsolicited Notify Absent,Disabling Unsolicited Notifies
3781865: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoMediaNegotiation: Number of m-lines = 1
3781866: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781867: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781868: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoAudioNegotiation: Codec (g711ulaw) Negotiation Successful on Static Payload for m-line 1
3781869: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoPtimeNegotiation: One ptime attribute found - value:20
3781870: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_ptime_to_codec_bytes: Values :Codec: g711ulaw ptime :20, codecbytes: 160
3781871: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/convert_codec_bytes_to_ptime: Values :Codec: g711ulaw codecbytes :160, ptime: 20
3781872: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPIDoPtimeNegotiation: Offered ptime:20, Negotiated ptime:20 Negotiated codec bytes: 160 for codec g711ulaw
3781873: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoDTMFRelayNegotiation: m-line index 1
3781874: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoDTMFRelayNegotiation: RTP-NTE DTMF relay option
3781875: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoDTMFRelayNegotiation: Case of partial named event(NE) match in fmtp list of events.
3781876: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sip_sdp_get_modem_relay_cap_params: NSE payload from X-cap = 0
3781877: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sip_select_modem_relay_params: X-tmr not present in SDP. Disable modem relay
3781878: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIGetSDPDirectionAttribute: No direction attribute present or multiple direction attributes that can't be handled for m-line:1 and num-a-lines:0
3781879: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoAudioNegotiation: Codec negotiation successful for media line 1
    stream_type=voice+dtmf (1), dest_ip_address=22.121.7.3, dest_port=17024
3781880: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/State/sipSPIChangeStreamState: Stream (callid =  -1)  State changed from (STREAM_DEAD) to (STREAM_ADDING)
3781881: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPICompareStreams: stream 1 dest_port: old=17024 new=17024
3781882: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPIGetNewLocalMediaDirection:
    New Remote Media Direction = SENDRECV
    Present Local Media Direction = SENDRECV
    New Local Media Direction = SENDRECV
    retVal = 0
3781883: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPICompareStreams: Flags set for stream 1: RTP_CHANGE=No CAPS_CHANGE=No RSVP_ADDR_CHANGE=No RSVP_MEDIA_CHANGE=No
3781884: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPICompareSDP: Flags set for call: NEW_MEDIA=No DSPDNLD_REQD=No IPIP_MEDIA=No
3781885: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: Entry
3781886: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoQoSNegotiationWithMediaLine: QOS negotiation for mline_index 1
3781887: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIDoStreamQoSNegotiation: Best effort
3781888: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISipSdpFree:
3781889: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPIReplaceSDP: Main stream got changed & it's Flow Around
3781890: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPIUpdCallWithSdpInfo:
    Early Media            : No
    Delayed Media          : No
    Bridge Done            : Yes
    New Media              : No
    DSP DNLD Reqd          : No
3781891: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/resolve_media_ip_address_to_bind: Media already bound, use existing source_media_ip_addr
3781892: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 22.121.5.4
3781893: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Media/sipSPIUpdCallWithSdpInfo:
      Media line             : 1
      Callid                 : 5338153
      Media Srce Addr/Port   : [22.121.5.4]:29596
      Media Dest Addr/Port   : [22.121.7.3]:17024
3781894: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/is_call_held: Remote media IP addr: 22.121.7.3
3781895: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/is_call_held: Media IP Addr 22.121.7.3, RTCP Type 3
3781896: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIProcessMediaChanges: sipSPIProcessMediaChanges
3781897: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIIncomingCallSDP: SDP already there use old SDP and update media if needed
3781898: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateSrcSdpFixedPart: RTP port already reserved for stream 1, src_port=29596
3781899: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetMediaDirectionForStream: Setting Media direction SENDRECV for stream 1
3781900: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Setting stream 1 portnum to 29596
3781901: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateSrcSdpVariablePart:
3781902: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateSrcSdpVariablePart: Negotiated method of dtmf relayand pyld: 6 101
3781903: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_api_request_offer: Deffering QoS
3781904: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_api_request_offer: Response 200 OK for TDM
3781905: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateSDPQoSAttributes: Entry
3781906: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateSDPQoSAttributes: 4 a-line(s) found for stream 1
3781907: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP size = 241, curr send SDP size =
              241
3781908: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPICheckForSDPModification: prev send SDP and curr send SDP are
                  same
3781909: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIHandleSDPOwnerVersionIDChange: SDP owner_version ID not incremented ..
3781910: Aug 13 11:46:52.660 HKG: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_CC_MEDIA_EVENT
3781911: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIUpdateCallInfoforDelayReconnect:
sipSPIUpdateCallInfoforDelayReconnect: callID 5338153
3781912: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/State/sipSPIChangeState: 0x313E0250 : State change from (STATE_ACTIVE, SUBSTATE_NONE)  to (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)
3781913: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIHandleIncomingMidCallInvite: ccsip_api_request_offer returned: SIP_SUCCESS
3781914: Aug 13 11:46:52.660 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
3781915: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPISendInviteResponse: Associated container=0x3150D420 to Invite Response 100
3781916: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipSPITransportSendMessage: msg=0x311DD404, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x0
3781917: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781918: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781919: Aug 13 11:46:52.664 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x311DD404, addr=22.121.6.1, port=39173, connId=2 for TCP
3781920: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIProcessContactInfo: Previous Hop 22.121.6.1:5060
3781921: Aug 13 11:46:52.664 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 29
3781922: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/act_handle_app_media_event: method = 102 state = 16
3781923: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/act_handle_app_media_event: Received media sip event SIP_RESPONSE_ANSWER
3781924: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIProcessHoldTimerForCall: Media IP Addr 22.121.7.3, RTCP Type 3
3781925: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIStopHoldTimer: Stopping hold timer
3781926: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIAppUpdateToTag: This is hold/resume request, so skip update, call with callid: 5338153
3781927: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIAppAddCallInfoUI: This is hold/resume request, so skip update, call with callid: 5338153
3781928: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIPushSubsqTransMsgContainerIntoHolder: Response Container Holder is above threshold...trimming
3781929: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Event/sipSPICreateRpid: Received Octet3A=0x81 -> Setting ;screen=yes ;privacy=off
3781930: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIGetCallExtensionSupported: anat enabled, src_sdp and dest_sdp available, should be a midcall request
3781931: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPISendInviteResponse: Associated container=0x315109C0 to Invite Response 200
3781932: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
3781933: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipSPITransportSendMessage: msg=0x319BAE20, addr=22.121.6.1, port=39173, sentBy_port=5060, is_req=0, transport=2, switch=0, callBack=0x249C2C40
3781934: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
3781935: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
3781936: Aug 13 11:46:52.664 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x319BAE20, addr=22.121.6.1, port=39173, connId=2 for TCP
3781937: Aug 13 11:46:52.664 HKG: //5338153/EA1F456E86D2/SIP/Info/sentResponseStartConnectTimer: Sent Response, start ConnectTimer
3781938: Aug 13 11:46:52.664 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 104 INVITE
Content-Length: 0
3781939: Aug 13 11:46:52.664 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 104 INVITE
Remote-Party-ID: <sip:65350828@22.121.5.4>;party=called;screen=yes;privacy=off
Supported: replaces
Supported: sdp-anat
Require: timer
Content-Length: 241
v=0
o=CiscoSystemsSIP-GW-UserAgent 5235 5067 IN IP4 22.121.5.4
s=SIP Call
c=IN IP4 22.121.5.4
t=0 0
m=audio 29596 RTP/AVP 0 101
c=IN IP4 22.121.5.4
a=fmtp:101 0-16
a=ptime:20
3781940: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 1
3781941: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportProcessNWNewConnMsg: context=0x0
3781942: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipConnectionManagerProcessNewConnMsg: gConnTab=0x30D6009C, addr=22.121.6.1, port=39173, connid=2, transport=TCP
3781943: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Content-Length: 0
Via: SIP/2.0/TCP 22.121.6.1:5060;branch=z9hG4bK4e4acb2c38e0
CSeq: 104 ACK
Max-Forwards: 70
3781944: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
3781945: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPICheckFromToRequest: Found matching CB 313E0250
3781946: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPILocateInviteDialogCCB: ****Found CCB in UAC table
3781947: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781948: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Converting TimeZone HKG to SIP default timezone = GMT
3781949: Aug 13 11:46:53.116 HKG: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Dialog Transaction Address 22.121.6.1,Port 39173, Transport 2, SentBy Port 5060
3781950: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIProcessIncomingAckForMidCall: Processing MidCall ACK
3781951: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/State/sipSPIChangeState: 0x313E0250 : State change from (STATE_MIDCALL_LOCAL_RESP_PENDING, SUBSTATE_NONE)  to (STATE_ACTIVE, SUBSTATE_NONE)
3781952: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPICreateAndStartRtpTimer:
3781953: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPICreateAndStartRtpTimer: Media Inactivity Timer is disabled.
3781954: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_api_modify_session_done: ccsip_api_modify_session_done: start resume start notifivation
3781955: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIResumeStartNotificationRequest: sipSPIResumeStartNotificationRequest: Resume Type=Unknown
3781956: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/CCAPI/cc_api_call_facility:
   Interface=0x30D62BB0, Call Id=5338153
3781957: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_api_modify_session_done: Handling Deffered QoS reservation for
                MID-CALL INVITE
3781958: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIProcessRsvp: Entry
3781959: Aug 13 11:46:53.116 HKG: //5338153/EA1F456E86D2/SIP/Info/sipSPIProcessIncomingAckForMidCall: ccsip_api_modify_session_done returned: SIP_SUCCESS
3781960: Aug 13 11:46:53.840 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3781961: Aug 13 11:46:53.852 HKG: //5338403/EB8996408745/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338403, proc_id=9
3781962: Aug 13 11:46:54.864 HKG: //5339137/9F2D5CB988B2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339137, proc_id=9
3781963: Aug 13 11:46:55.000 HKG: //5339039/D65AB599887E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5339039, proc_id=9
3781964: Aug 13 11:46:55.300 HKG: //5338153/EA1F456E86D2/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338153, proc_id=9
3781965: Aug 13 11:46:55.360 HKG: //5338913/13AD873A883D/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338913, proc_id=9
3781966: Aug 13 11:46:55.664 HKG: //5338957/40B8CB938851/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338957, proc_id=9
3781967: Aug 13 11:46:55.668 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:27  disconnected from 7616188 , call lasted 38 seconds
3781968: Aug 13 11:46:55.668 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_disconnected:
   Cause Value=16, Interface=0x29CCE8B8, Call Id=5339195
3781969: Aug 13 11:46:55.668 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_disconnected:
3781970: Aug 13 11:46:55.668 HKG: //5339194/00C9775CBE4A/CCAPI/ccConferenceDestroy:
   Conference Id=0x2006B6, Tag=0x0
3781971: Aug 13 11:46:55.668 HKG: //5339194/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2006B6, Source Interface=0x2968961C, Source Call Id=5339194,
   Destination Call Id=5339195, Disposition=0x0, Tag=0x0
3781972: Aug 13 11:46:55.668 HKG: //5339195/xxxxxxxxxxxx/CCAPI/cc_api_bridge_drop_done:
   Conference Id=0x2006B6, Source Interface=0x29CCE8B8, Source Call Id=5339195,
   Destination Call Id=5339194, Disposition=0x0, Tag=0x0
3781973: Aug 13 11:46:55.668 HKG: //5339194/00C9775CBE4A/CCAPI/cc_generic_bridge_done:
3781974: Aug 13 11:46:55.668 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallDisconnect:
3781975: Aug 13 11:46:55.668 HKG: //5339194/00C9775CBE4A/CCAPI/ccCallDisconnect:
3781976: Aug 13 11:46:55.668 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_get_transfer_info:
3781977: Aug 13 11:46:55.668 HKG: //5339195/00C9775CBE4A/CCAPI/ccCallDisconnect:
3781978: Aug 13 11:46:55.668 HKG: //5339195/00C9775CBE4A/CCAPI/ccCallDisconnect:
3781979: Aug 13 11:46:55.668 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_get_transfer_info:
3781980: Aug 13 11:46:56.044 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_get_transfer_info:
3781981: Aug 13 11:46:56.044 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x2968961C, Tag=0x0, Call Id=5339194,
3781982: Aug 13 11:46:56.044 HKG: //5339194/00C9775CBE4A/CCAPI/cc_api_call_disconnect_done:
3781983: Aug 13 11:46:56.044 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781984: Aug 13 11:46:56.044 HKG: :cc_free_feature_vsa freeing 31C6DB38
3781985: Aug 13 11:46:56.044 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781986: Aug 13 11:46:56.044 HKG:  vsacount in free is 79
3781987: Aug 13 11:46:56.816 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x29CCE8B8, Tag=0x0, Call Id=5339195,
3781988: Aug 13 11:46:56.816 HKG: //5339195/00C9775CBE4A/CCAPI/cc_api_call_disconnect_done:
3781989: Aug 13 11:46:56.816 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781990: Aug 13 11:46:56.816 HKG: :cc_free_feature_vsa freeing 31C6B678
3781991: Aug 13 11:46:56.816 HKG: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
3781992: Aug 13 11:46:56.816 HKG:  vsacount in free is 78
3781993: Aug 13 11:46:56.824 HKG: //5337895/A17D4EFB8655/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5337895, proc_id=9
3781994: Aug 13 11:46:57.608 HKG: //5338898/F579AB958836/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338898, proc_id=9
3781995: Aug 13 11:46:57.620 HKG: //5338950/303D7909884E/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338950, proc_id=9
3781996: Aug 13 11:46:57.624 HKG: //5338900/FAA003498837/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338900, proc_id=9
3781997: Aug 13 11:46:58.536 HKG: //5338401/EB4D2A738744/SIP/Info/ccsip_indicate_rt_packet_stats: Processing stats for callid=5338401, proc_id=9
3781998: Aug 13 11:47:07.420 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 7511470 , call lasted 872 seconds
3781999: Aug 13 11:47:10.460 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:29 is now connected to 7511862 N/A
3782000: Aug 13 11:47:21.344 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:14 is now connected to 62102565 N/A
3782001: Aug 13 11:47:26.608 HKG: %ISDN-6-CONNECT: Interface Serial0/0/0:16 is now connected to 7544848 N/A
3782002: Aug 13 11:47:27.368 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:14  disconnected from 62102565 , call lasted 6 seconds
3782003: Aug 13 11:47:29.788 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:16  disconnected from 7544848 , call lasted 3 seconds
3782004: Aug 13 11:47:30.924 HKG: %ISDN-6-DISCONNECT: Interface Serial0/0/0:2  disconnected from 7513157 , call lasted 288 seconds
1 REPLY
Hi Ben,In debug logs i cannot
Hi Ben,
In debug logs i cannot find DTMF events from inbound direction i.e. from QSIG -> ISR2 router. When you enable debug voice ccapi inout on router there are two events that occurs to relay DTMF message from QSIG leg  i.e. cc_api_call_digit_begin and cc_api_call_digit_end.
First you need to check on ISR1 for DTMF events and check whether ISR1 relaying those messages or not.
And one more point removed all the extra DTMFs on the SIP dial-peer towards CUCM and keep it only RTP-NTE.
Manish
126
