dtmf-relay on default dial-peer...
I'm not sure I'm going about this the right way. I have a system that dials across an IP WAN connection into my CME. It dials 1001 which I have setup as the number for an ephone-dn. The system automatically prompts the user to press a button to accept the call. The system doesn't recognize the digit dialed.
When I pick up that same line (1001) and dial the system I can dial digits and the system recognizes it just fine. I have dtmf-relay configured on the outgoing dial-peer for the system.
My question is: how do you add dtmf-relay for an incoming default dial-peer? Or, how else would I accomplish this? TIA.
1 REPLY
Re: dtmf-relay on default dial-peer...
Alright, I answered my own question. I needed to use incoming called-number because that is applied before destination-pattern.
170
